Here’s the garuda-inxi
output you requested. Just performed an update and rebooted:
Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
root=UUID=0caa7650-2e59-4207-b047-70916db78ef5 rw rootflags=subvol=@ quiet
resume=UUID=6efb65fc-69a1-4761-95e0-e87d2efc2b7d loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Micro-Star model: MAG Z790 TOMAHAWK WIFI (MS-7D91) v: 4.0
serial: <superuser required> uuid: <superuser required> UEFI: American Megatrends LLC. v: H.70
date: 07/10/2023
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP arch: Alder Lake gen: core 12
level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151)
stepping: 2 microcode: 0x35
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled cache: L1: 1024 KiB
desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/4900:5000:3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 799 10: 800
11: 800 12: 800 13: 800 14: 799 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
bogomips: 144383
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti GDDR6X] vendor: ASUSTeK driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-06; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none off: DP-1,DP-2 empty: DP-3,HDMI-A-1,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:24c9 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.2:14 chip-ID: 046d:085c class-ID: 0102
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1 compositor: kwin_wayland
driver: X: loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: nvidia
d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: swrast inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.1.4-arch1.2 glx-v: 1.4 direct-render: yes
renderer: llvmpipe (LLVM 18.1.8 256 bits) device-ID: ffffffff:ffffffff memory: 30.39 GiB
unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 18 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 3060 Ti
driver: nvidia v: 555.58.02 device-ID: 10de:24c9 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM 18.1.8)
Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:11 chip-ID: 0db0:a74b class-ID: 0300
Device-4: Blue Microphones Yeti Stereo Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.2:4 chip-ID: b58e:9e84
Device-5: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: 4000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
If I open Konsole and just enter systemsettings
, then navigate to the aforementioned section:
λ systemsettings
qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
qml: Page SubCategoryPage_QMLTYPE_60(0x5e1b5186f9f0) is already in the PageRow
qml: Pushed pages do not conform to the rules. Please check the documentation.
qml: push (file:///usr/lib/qt6/qml/org/kde/kirigami/PageRow.qml:223)
onActiveSubCategoryRowChanged (qrc:/qt/qml/org/kde/systemsettings/SubCategoryPage.qml:180)
expression for onClicked (qrc:/qt/qml/org/kde/systemsettings/CategoriesPage.qml:207)
Cannot mix incompatible Qt library (6.7.0) with this library (6.7.2)
fish: Job 1, 'systemsettings' terminated by signal SIGABRT (Abort)
QT6 packages that are installed:
λ pacman -Q | grep qt6
kdsoap-qt6 2.2.0-1
libqaccessibilityclient-qt6 0.6.0-1
phonon-qt6 4.12.0-4
phonon-qt6-vlc 0.12.0-2
polkit-qt6 0.200.0-1
poppler-qt6 24.06.1-1
python-pyqt6 6.7.1-1
python-pyqt6-sip 13.8.0-1
python-pyqt6-webengine 6.7.0-2
qca-qt6 2.3.9-2
qcoro-qt6 0.10.0-1
qgpgme-qt6 1.23.2-6
qt6-3d 6.7.2-1
qt6-5compat 6.7.2-1
qt6-base 6.7.2-1
qt6-connectivity 6.7.2-1
qt6-declarative 6.7.2-1
qt6-doc 6.7.2-1
qt6-examples 6.7.2-1
qt6-grpc 6.7.2-1
qt6-httpserver 6.7.2-1
qt6-imageformats 6.7.2-1
qt6-location 6.7.2-1
qt6-lottie 6.7.2-1
qt6-multimedia 6.7.2-1
qt6-multimedia-ffmpeg 6.7.2-1
qt6-multimedia-gstreamer 6.7.2-1
qt6-networkauth 6.7.2-1
qt6-positioning 6.7.2-1
qt6-quick3d 6.7.2-1
qt6-quick3dphysics 6.7.2-1
qt6-quickeffectmaker 6.7.2-1
qt6-quicktimeline 6.7.2-1
qt6-scxml 6.7.2-1
qt6-sensors 6.7.2-1
qt6-serialbus 6.7.2-1
qt6-serialport 6.7.2-1
qt6-shadertools 6.7.2-1
qt6-speech 6.7.2-1
qt6-svg 6.7.2-1
qt6-tools 6.7.2-2
qt6-translations 6.7.2-1
qt6-virtualkeyboard 6.7.2-1
qt6-wayland 6.7.2-4
qt6-webchannel 6.7.2-1
qt6-webengine 6.7.2-2
qt6-websockets 6.7.2-1
qt6-webview 6.7.2-1
qt6ct 0.9-9
qt6gtk2 0.2-10
qt6pas 6.2.7-2
qtkeychain-qt6 0.14.3-1
