Hello.
When i first installed Garuda (Cinnamon Edition), the System Settings Netowrk module worked just fine (I tested it then because I was re-installing because of this error). Once I did the initial update, I ran "cinnamon-settings" and got the following results:
$ cinnamon-settings
(cinnamon-settings.py:94778): Gtk-WARNING **: 00:02:42.015: Theme parsing error: gtk.css:5822:26: '-shadow' is not a valid color name
(cinnamon-settings.py:94778): Gtk-WARNING **: 00:02:42.015: Theme parsing error: gtk.css:5825:14: not a number
(cinnamon-settings.py:94778): Gtk-WARNING **: 00:02:42.015: Theme parsing error: gtk.css:5826:13: not a number
(cinnamon-settings.py:94778): Gtk-WARNING **: 00:02:42.015: Theme parsing error: gtk.css:5827:11: Expected a length
Using pam module (python3-pampy)
Loading Effects module
Loading General module
Loading Screensaver module
/usr/lib/python3.10/site-packages/gi/overrides/Gio.py:42: Warning: invalid unclassed pointer in cast to 'NMACertChooserButton'
return Gio.Application.run(self, *args, **kwargs)
/usr/lib/python3.10/site-packages/gi/overrides/Gio.py:42: Warning: g_type_instance_get_private: assertion 'instance != NULL && instance->g_class != NULL' failed
Segmentation fault (core dumped)
I can see it's a Python error, but I'm not a Python coder. I'm a Perl and Java coder. Plus, I figured that if I'm having this error, other people are, too.
The only thing I did to fix this was a fresh install -- which didn't work. (wry grin)
Here is my "garuda-inxi -Faz" output
# garuda-inxi -Faz
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c23b2e10-cd96-42ab-9754-c271bcbfb5f3 rw rootflags=subvol=@
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.31 wm: Muffin dm: LightDM 1.30.0
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-eb0xxx
v: N/A serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: HP model: 86E5 v: 01.33 serial: <filter> UEFI: AMI v: F.12
date: 07/29/2021
ID-1: BAT0 charge: 67.6 Wh (100.0%) condition: 67.6/67.6 Wh (100.0%)
volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: Full cycles: 13
Device-1: hid-0018:04F3:2A4F.0007-battery model: ELAN2514:00 04F3:2A4F
serial: N/A charge: N/A status: N/A
Device-2: hidpp_battery_0 model: Logitech Wireless Gaming Mouse
status: Discharging
Info: model: Intel Core i7-10510U socket: BGA1528 (U3E1) note: check
bits: 64 type: MT MCP arch: Comet/Whiskey Lake note: check family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 666 high: 700 min/max: 400/4900 base/boost: 2574/8300
ext-clock: 100 MHz cores: 1: 600 2: 600 3: 634 4: 700 5: 700 6: 700
7: 700 8: 700 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Hewlett-Packard
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 3b:00.0
chip-ID: 10de:1d16 class-ID: 0302
Device-3: Quanta HP True Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-8:5 chip-ID: 0408:5440 class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.3 driver: loaded: modesetting,nvidia
Screen-1: 0 s-res: 7680x1440 s-dpi: 48 s-size: 4064x762mm (160.0x30.0")
s-diag: 4135mm (162.8")
Monitor-1: eDP-1 res: 2560x1440 dpi: 189 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Monitor-2: DP-1 res: 2560x1440 hz: 60 dpi: 93
size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
Monitor-3: DP-2 res: 2560x1440 hz: 60 dpi: 93
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 4-1.4:3 chip-ID: 0bda:8153 class-ID: 0000
IF: enp58s0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.14 TiB used: 40.32 GiB (3.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: GE8QT size: 238.5 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 38.9 C scheme: GPT
ID-1: / raw-size: 399.71 GiB size: 399.71 GiB (100.00%)
used: 17.46 GiB (4.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
used: 29.8 MiB (31.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 399.71 GiB size: 399.71 GiB (100.00%)
maj-min: 259:6
ID-4: /var/log raw-size: 399.71 GiB size: 399.71 GiB (100.00%)
maj-min: 259:6
ID-5: /var/tmp raw-size: 399.71 GiB size: 399.71 GiB (100.00%)
maj-min: 259:6
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.25 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 39.0 C mobo: N/A
Processes: 302 Uptime: 43m wakeups: 7 Memory: 15.25 GiB
used: 3.63 GiB (23.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1385 lib: 357
Shell: Bash (sudo) v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
Garuda:
System install date: 2022-01-24
Last full system update: 2022-01-24
Using TLP: No
Windows dual boot: Yes
