"System Settings" app under KDE
Hello,
I assure you I have done my searches and not come up with anything pertinent, so!
Basically my issue is that if I ever fire up the ‘System Settings’ app, it comes up with the ‘Close’ window decoration disabled, and no ‘Quit’ or ‘Exit’ option on the main menu, and it is basically impossible to get rid of other than just minimising it.
I would love to learn how to fix this!
Here’s the obligatory garuda-inxi thing:
╰─λ garuda-inxi
root=UUID=360ddc4a-a310-4174-b63c-ffe8787a1f4c rw rootflags=subvol=@
rd.luks.uuid=1358f973-b13a-473d-843e-792ec54a2721 quiet
Type: Laptop System: HP product: HP EliteBook 840 G3 v: N/A
Mobo: HP model: 8079 v: KBC Version 85.77 serial: <superuser required>
UEFI: HP v: N75 Ver. 01.18 date: 10/17/2017
ID-1: BAT0 charge: 36.1 Wh (96.3%) condition: 37.5/37.5 Wh (100.0%)
volts: 12.6 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3343 high: 3386 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3350 2: 3288 3: 3350
4: 3386 bogomips: 22399
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
EliteBook 840 G3 driver: i915 v: kernel arch: Gen-9 process: Intel 14n
built: 2015-16 ports: active: DP-1 off: eDP-1
empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
Device-2: Lite-On HP HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 04ca:7054
Monitor-1: DP-1 pos: primary model: HP E24 G4 serial: <filter> built: 2022
res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 note: disabled model: LG Display 0x04f3 built: 2014
res: 1920x1080 dpi: 210 gamma: 1.2 size: 310x174mm (12.2x6.85")
diag: 355mm (14") ratio: 16:9 modes: 2560x1440
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 30.5 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:1916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard EliteBook
840 G3 driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Device-2: HP USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.2:6
chip-ID: 03f0:056b class-ID: 0300 serial: <filter>
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard EliteBook 840 G3
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.4:6
IF: enp0s20f0u3u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
Local Storage: total: 2.29 TiB used: 1011.95 GiB (43.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U-512G-1006
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0006 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: PSSD T7
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: PSSD T7
used: 39.6 GiB (8.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-1358f973-b13a-473d-843e-792ec54a2721
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 31.23 GiB used: 26.1 MiB (0.1%)
System Temperatures: cpu: 51.0 C pch: 38.0 C mobo: N/A
Processes: 242 Uptime: 1d 28m wakeups: 1 Memory: total: 32 GiB
available: 31.23 GiB used: 3.95 GiB (12.7%) Init: systemd v: 254
pm: pacman pkgs: 1459 libs: 421 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
Garuda (2.6.17-1):
System install date:     2023-09-21
Last full system update: 2023-11-04
Is partially upgraded:   Yes
For first fix try Ctrl+Shift+Q
or Ctrl+Q
Did you change the theme, or the panels? I wonder if you need to adjust this setting:
I’ve noticed a few similar glitches from the latest official dr460nized edition. Borders & buttons may be lacking for non-Garuda applications such as QTWebflix, which uses normal window framing in all respects in Arch, but not Garuda. It has been better-handled in earlier editions of Garuda. I suspect rapidly-changing KDE.
Rant:
I suspect we (KDE aficionados) will be experiencing–um, don’t know the politically correct words–a lot more than a few little glitches during & after the transition.
Everybody says different–that this KDE transition will be different, much smoother, much easier than every major chord of KDE that has gone before.
I call bullshit and I’m not going to be wrong.
Actually, and thanks, that does get rid of it.
I’m still puzzled why it would ‘disable’ the ‘close’ window decoration.
I shall look into the other response which was about messing with ~/.config/kwinrc as well (thanks for that[1]), but not tonight!
  1. https://forum.garudalinux.org/u/BluishHumility
:rofl: That is some festering dedication.
BTW, right there with you. Placing bet on ‘total shit-show.’
The suggested adjustment in ~/.config/kwinrc, if I remember correctly, is aimed to fix only (all) buttons not appearing in maximized windows. This problem might be different.
What theme are you using in Window Decoration? Is the close button appearing in the Titlebar Buttons tab?
