Hello,
I’ve recently installed Garuda linux and appear to be having hardware issues. I’m fairly certain that these issues persisted with my prior Windows 10 installation, but I never observed any direct crashes on Windows 10. I’ve directly observed the issue once while simply having a web browser open on Garuda. The workstation itself completely resets as if someone pushed the reset switch or power button. No shutdown, no error, just all of a sudden back to the BIOS startup screen.
The remainder of the times I suspect the issue has occurred, I have come into the room with the workstation sitting at the drive encryption prompt waiting for me to enter my password to continue the boot process.
After the restart occurs, the computer normally runs for 15-18 hours until the restart occurs. My current thinking was possibly overheating. But I’m not sure since it appears to happen even with the computer seemingly in a low usage state.
After some research, I found the following errors using journalctl -p 0:
Nov 08 13:51:45 darktower kernel: mce: [Hardware Error]: CPU 8: Machine Check: 0 Bank 0: baa0000000060135
Nov 08 13:51:45 darktower kernel: mce: [Hardware Error]: TSC 0 MISC d012000100000000 SYND 2d031000 IPID b000000000
Nov 08 13:51:45 darktower kernel: mce: [Hardware Error]: PROCESSOR 2:800f11 TIME 1699473100 SOCKET 0 APIC 5 microcode 8001138
-- Boot ac898a0da7a04adb872a4547c9ba32d6 --
Nov 08 13:53:07 darktower kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 5: bea0000000000108
Nov 08 13:53:07 darktower kernel: mce: [Hardware Error]: TSC 0 ADDR 1ffff915e5bc4 MISC d012000100000000 SYND 4d000000 IPID 500b000000000
Nov 08 13:53:07 darktower kernel: mce: [Hardware Error]: PROCESSOR 2:800f11 TIME 1699473183 SOCKET 0 APIC 0 microcode 8001138
Below is my garuda-inxi output:
root=UUID=70764d0b-735a-4846-b555-0971a6e37c5b rw rootflags=subvol=@
quiet rd.luks.uuid=822d6c14-00d9-424c-9b62-15b591595818 quiet
Type: Desktop Mobo: ASRock model: X370 Taichi serial: <superuser required>
UEFI: American Megatrends v: P7.00 date: 01/15/2022
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1664 high: 3200 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 3200
3: 1550 4: 1550 5: 1550 6: 1378 7: 1550 8: 1550 9: 1442 10: 1550 11: 1550
12: 1550 bogomips: 76795
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 ports:
active: DVI-D-1 empty: DP-1,HDMI-A-1 bus-ID: 0d:00.0 chip-ID: 1002:699f
class-ID: 0300 temp: 46.0 C
Device-2: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 046d:081b
Monitor-1: DVI-D-1 mapped: DVI-D-0 model: LG (GoldStar) EW224
serial: <filter> built: 2011 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:699f
memory: 3.91 GiB unified: no
API: Vulkan v: 1.3.269 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 550 / 550 Series (RADV POLARIS12) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:699f surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
lanes: 8 bus-ID: 0d:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0f:00.3
Device-3: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:2 chip-ID: 8087:0aa7
rfk-block: hardware: no software: no address: <filter> bt-v: 4.2 lmp-v: 8
Local Storage: total: 2.74 TiB used: 321.18 GiB (11.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: ECFM12.1 temp: 20.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DL004 HD204UI
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
tech: SSD serial: <filter> fw-rev: 3B6Q
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 250GB
used: 12.87 GiB (2.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-822d6c14-00d9-424c-9b62-15b591595818
used: 205.65 GiB (11.0%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-010718dd-95dc-49ee-9adf-2e813e3fb5ca
System Temperatures: cpu: 39.0 C mobo: 34.0 C gpu: amdgpu temp: 45.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1746 fan-3: 0 fan-4: 0 fan-5: 654
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.26 gpu: amdgpu watts: 8.20
Processes: 377 Uptime: 1h 53m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 3.74 GiB (24.1%) Init: systemd v: 254
Packages: 1279 pm: pacman pkgs: 1264 libs: 372 tools: octopi,paru
pm: flatpak pkgs: 15 Shell: fish v: 3.6.1 default: Bash v: 5.2.15
Garuda (2.6.17-1):
System install date: 2023-10-15
Last full system update: 2023-11-08 ↻
Any information or suggestions that can point me toward a solution is greatly appreciated.
Thank You!
