System out of date warning
Good evening everyone,
I hope you are all doing great and that someone might be able to help me with this small issue. About two days ago i got a warning from garuda system maintenance saying that my system hasn't been updated in a long time, however i know for sure that this is not possible as i update my system every single day with the following commands.
pacman -Syyu
and
garuda-update
Although these commands run without any issue and the "System update" message is displayed, i
noticed these three errors after executing garuda-update
[2022-03-13 23:01:57] WARNING: failed to rate http(s) download (https://mirror.theash.xyz/arch/com
munity/os/x86_64/community.db): HTTP Error 403: Forbidden
[2022-03-13 23:02:02] WARNING: failed to rate http(s) download (https://archmirror.it/repos/commun
[2022-03-13 23:02:02] WARNING: failed to rate http(s) download (https://mirror.cyberbits.asia/arch
linux/community/os/x86_64/community.db): <urlopen error [Errno 101] Network is unreachable>
I tried to search through the forum for solutions but unfortunately none of them worked for me, also if by any chance i missed a post that has the same subject as this one i apologize...
In case it helps, you can find the inxi command below
  Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=734ce3ff-9d44-495d-8a77-f471aa022038 rw rootflags=subvol=@
    loglevel=3 quiet
  Type: Laptop System: LENOVO product: 81NC v: LENOVO S340-15API
    serial: <superuser required> Chassis: type: 10 v: LENOVO S340-15API
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    UEFI: LENOVO v: AMCN28WW(V1.11) date: 07/13/2020
  ID-1: BAT1 charge: 53.0 Wh (100.0%) condition: 53.0/52.5 Wh (101.0%)
    volts: 12.8 min: 11.3
    model: 0x4C 0x47 0x43 0x00 0x32 0x30 0x 0x4C 0x31 0x38 0x33 0x50 0x5250
    type: Li-ion serial: <filter> status: Full cycles: 840
  Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
    model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2552 high: 2769 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 2187 2: 1710
    3: 2687 4: 2767 5: 2761 6: 2768 7: 2768 8: 2769 bogomips: 33536
    vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0
    chip-ID: 1002:15d8 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-4:2 chip-ID: 04f2:b61e class-ID: 0e02 serial: <filter>
    loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
    s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
    diag: 394mm (15.5")
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.44.0
    5.16.14-zen1-1-zen LLVM 13.0.1)
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
    bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
    driver: snd_pci_acp3x v: kernel
    alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
    chip-ID: 0cf3:e500 class-ID: e001
    address: <filter>
  Local Storage: total: 476.94 GiB used: 143.2 GiB (30.0%)
    model: PC SN520 SDAPMUW-512G-1101 size: 476.94 GiB block-size:
    physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
    serial: <filter> rev: 20240001 temp: 49.9 C scheme: GPT
  ID-1: / raw-size: 476.7 GiB size: 476.7 GiB (100.00%)
    used: 143.2 GiB (30.0%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-2: /boot/efi raw-size: 245 MiB size: 241.2 MiB (98.46%)
    used: 282 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-3: /home raw-size: 476.7 GiB size: 476.7 GiB (100.00%)
  ID-4: /var/log raw-size: 476.7 GiB size: 476.7 GiB (100.00%)
  ID-5: /var/tmp raw-size: 476.7 GiB size: 476.7 GiB (100.00%)
  Alert: No swap data was found.
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 55.0 C
  Processes: 308 Uptime: 12h 27m wakeups: 2 Memory: 5.79 GiB
  used: 4.33 GiB (74.8%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1474 lib: 419 Shell: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.13
For everyone that spent their time reading this post and trying to help me with this issue, i am truly grateful, and for the ones that are looking for answers i hope this post might help you as well. Stay well, stay safe!
Can we have your
not
inxi
please
Do not use
just
or
update
There are warning, no errors, some mirrors are down, other do the work, no problem.
Seems like i don't have that command for some reason, am i doing something wrong?
bash: garuda-inxi: command not found
The system out of date warning does not go away even after updating the system several times with garuda-update
Also regarding those warnings, i would just need to change my mirrors right?
it look like you are doing a partial upgrade
haveyou tried
update
as sgs suggested
Yes, with garuda-update and update and everything seems to run fine
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur                  1614.7 KiB  1262 KiB/s 00:01 [--------------------------------] 100%
--> Refreshing mirrorlists using reflector, please be patient..
[2022-03-14 00:13:51] WARNING: failed to rate http(s) download (https://mirrors.neusoft.edu.cn/arc
hlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
################# Arch Linux mirrorlist generated by Reflector #################
# With:       reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pa
cman.d/mirrorlist
# When:       2022-03-14 00:13:55 UTC
# From:       https://archlinux.org/mirrors/status/json/
# Retrieved:  2022-03-14 00:09:07 UTC
# Last Check: 2022-03-14 00:04:33 UTC
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://archlinux.qern-industries.pw/$repo/os/$arch
Server = https://mirrors.neusoft.edu.cn/archlinux/$repo/os/$arch
core                          153.5 KiB   324 KiB/s 00:00 [--------------------------------] 100%
extra                        1711.4 KiB  1371 KiB/s 00:01 [--------------------------------] 100%
community                       6.5 MiB  2.08 MiB/s 00:03 [--------------------------------] 100%
multilib                      171.1 KiB   341 KiB/s 00:01 [--------------------------------] 100%
chaotic-aur                  1614.7 KiB   989 KiB/s 00:02 [--------------------------------] 100%
spawn pacman -Su
there is nothing to do
Parsing man pages and writing completions to /home/zalasz/.local/share/fish/generated_completions/
3554 / 3554 : zramctl.8.gz
Checking for plugin updates
Nothing to install / update
System updated! 
Hmm, that is very odd. Does it let you download it? paru garuda-inxi
Unfortunately no, apparently the package does not exist
no packages match search
The only reason why you would not have this command is if your system is not up to date :stuck_out_tongue:
I’m honestly not quite sure why this is happening to you… Did you remove garuda-common-settings by any chance?
That was the problem, for some reason my garuda-common-settings was not installed (probably something i did) thank you very much :slight_smile: .
Also regarding the warning from the mirrors, i am not quite sure how to change them, i tried to edit chaotic-mirrorlist from the dir /etc/pacman.d and refreshing the database with pacman -Sy but nothing changed, the warning from the reflector is still there
You can ignore that warning. Some mirrors are always expected to fail.
You should probably revert any changes you made to the chaotic mirrorlist.
Will do that, thanks everyone for the help hope you guys have a lovely day :slight_smile:
