─zucni@ETNA in ~
╰─λ garuda-inxi
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b78f0ace-4b76-4ecb-911e-371d2a924668 rw rootflags=subvol=@
resume=UUID=fad1c9fd-e4b0-4830-9857-17676d6daf30 loglevel=3 ibt=off
Type: Laptop System: Acer product: Swift SFX14-42G v: V1.00
serial:
Mobo: BC model: Orion_BCU v: V1.00 serial:
UEFI: Insyde v: 1.00 date: 01/27/2022
ID-1: BAT1 charge: 55.7 Wh (100.0%) condition: 55.7/58.8 Wh (94.8%)
volts: 17.3 min: 15.4 model: SMP AP18E7M type: Li-ion serial:
status: full
Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1962 high: 2000 min/max: 1600/4547 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1397 2: 2000
3: 2000 4: 2000 5: 2000 6: 2000 7: 2000 8: 2000 9: 2000 10: 2000 11: 2000
12: 2000 13: 2000 14: 2000 15: 2000 16: 2000 bogomips: 63880
Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 535.104.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a0 class-ID: 0302
Device-2: AMD Barcelo vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 40.0 C
Device-3: Quanta Acer FHD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0408:4036
class-ID: fe01 serial:
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1408 built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.12-zen1-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
IF: wlp3s0 state: up mac:
Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04ca:3802
class-ID: e001 serial:
rfk-block: hardware: no software: yes address: bt-v: 5.2 lmp-v: 11
Local Storage: total: 476.94 GiB used: 232.07 GiB (48.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
lanes: 4 tech: SSD serial: fw-rev: 41020C20 temp: 36.9 C
ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
used: 232.07 GiB (50.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 14.98 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 49.1 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 393 Uptime: 4h 18m wakeups: 101 Memory: total: 16 GiB note: est.
available: 14.98 GiB used: 6.13 GiB (40.9%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 15.0.7 Packages: pm: pacman pkgs: 2058 libs: 566 tools: octopi,paru
inxi: 3.3.29
System install date: 2023-04-14
Last full system update: 2023-08-25
╭─zucni@ETNA in ~ took 2s
╰─λ
I still new to Linux so I might not have known the best search terms for this problem but when I tried looking up my error I was just getting posts that were not relevant.
I got a notification from garuda-system-maintenance that my system is outdated. So I attempted to run and update:
:: Synchronizing package databases…
garuda downloading…
core downloading…
extra downloading…
multilib downloading…
chaotic-aur downloading…
blackarch downloading…
:: Starting full system upgrade…
:: Replace exa with extra/eza? [Y/n] y
warning: paru: local (1.11.2-1) is newer than chaotic-aur (1.11.1-1.3)
warning: python-pynput: local (1.7.6-3) is newer than chaotic-aur (1.7.6-2.3)
warning: qemu-base: ignoring package upgrade (8.0.4-2 => 8.1.0-2)
resolving dependencies…
warning: ignoring package qemu-base-8.1.0-2
warning: cannot resolve “qemu-base=8.1.0-2”, a dependency of “qemu-desktop”
:: The following package cannot be upgraded due to unresolvable dependencies:
qemu-desktop
:: Do you want to skip the above package for this upgrade? [y/N] n
:: unable to satisfy dependency ‘qemu-base=8.1.0-2’ required by qemu-desktop
Press enter to exit
Skipping the packages just leads to exiting out without updating and I still have the outdated notification. I am not sure what gemu-desktop is or if I could uninstall it
