I just installed garuda linux dragonized edition on my razer blade pro 17 (early 2021) with nvidia rtx 3060 graphics card. I noticed that under monitor settings, it shows that the only available refresh rate is 60 Hz although the monitor supports 165 Hz. How can I enable the higher refresh rate ?
Welcome to the forum
Please post your garuda-inxi
as requested by the template.
thanks for the fast response and sorry for forgetting to post the required output. here it is:
Kernel: 6.6.33-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=1c11ac10-7b61-4305-a54b-4b4fd8bc9e81 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: Razer product: Blade Pro 17 (Early 2021) - RZ09-0368
v: 6.04 serial: <superuser required> Chassis: type: 10
Mobo: Razer model: DA760 v: 4 serial: <superuser required>
part-nu: RZ09-0368AEA2 uuid: <superuser required> UEFI: Razer v: 1.01
date: 01/05/2021
ID-1: BAT0 charge: 63.5 Wh (97.4%) condition: 65.2/70.6 Wh (92.5%)
volts: 16.8 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
Info: model: Intel Core i7-10875H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 802 high: 842 min/max: 800/5100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 842 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 bogomips: 73625
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Razer USA
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Razer USA driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm
non-free: 550.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
active: none empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:2 chip-ID: 13d3:56d5
Monitor-1: eDP-1 res: 1707x960 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1
device-ID: 8086:9bc4 memory: 7.56 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia
v: 550.90.07 device-ID: 10de:2520 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Comet Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
Device-2: NVIDIA GA106 High Definition Audio vendor: Razer USA
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
API: ALSA v: k6.6.33-1-lts status: kernel-api tools: N/A
Device-1: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 3d:00.0
IF: enp61s0 state: down mac: <filter>
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3f:00.0
IF: wlp63s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0032
Local Storage: total: 1.38 TiB used: 813.01 GiB (57.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVMe CA5-8D512 size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: CQ20904 temp: 33.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 37.9 C
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 16.11 GiB (32.2%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
used: 96 MiB (100.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 50 GiB size: 50 GiB (100.00%)
used: 16.11 GiB (32.2%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C pch: 45.0 C mobo: N/A
Memory: total: 16 GiB available: 15.48 GiB used: 4.43 GiB (28.6%)
Processes: 401 Power: uptime: 1h 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1403 libs: 415 tools: octopi,pamac,paru
Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-06-16
Last full system update: 2024-06-17
Nvidia and wayland is not a good idea, try switching to x11: Login screen → bottom left you can switch from plasma-wayland to plasma-x11.
Then try changing the display settings again in the plasma system settings.
I changed it to x11. Still in the setting shows that 60Hz is the only option supported by the monitor
Try in konsole
sudo nvidia-settings
Maybe must be installed.
I ran the mentioned command : here is what it showed:
** (nvidia-settings:4554): WARNING **: 17:49:51.162: Unable to connect to dbus: Error spawning command line “dbus-launch --autolaunch=bc319c1a04914a1eb31d823a736af331 --binary-syntax --close-stderr”: Child process exitedwith code 1
(nvidia-settings:4554): GLib-GObject-CRITICAL **: 17:49:51.211: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(nvidia-settings:4554): GLib-GObject-CRITICAL **: 17:49:51.401: g_object_ref: assertion 'G_IS_OBJECT (object)'failed
(nvidia-settings:4554): GLib-GIO-CRITICAL **: 17:49:51.401: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(nvidia-settings:4554): GLib-GObject-CRITICAL **: 17:49:51.402: g_object_ref: assertion 'G_IS_OBJECT (object)'failed
(nvidia-settings:4554): GLib-GIO-CRITICAL **: 17:49:51.402: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(nvidia-settings:4554): GLib-GIO-CRITICAL **: 17:49:51.402: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
but it also open the window for nvidia settings
