As I mentioned in the title, the newly installed KDE desktop, when using widgets such as CPU usage, or memory usage, they do not show anything, it's like they cannot detect any sensors whatsoever. Does anyone have an idea what might be the issue? I have lm_sensors installed
System: Kernel: 5.10.28-1-lts x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=8ed53bac-aff7-4011-a9e8-ccb8fb2376b8 rw
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter> UEFI: American Megatrends v: F51 date: 07/29/2020
CPU: Info: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1 stepping: 1
microcode: 8001138 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 95805
Speed: 2556 MHz min/max: 1550/3000 MHz boost: enabled Core speeds (MHz): 1: 2556 2: 2971 3: 2632 4: 2758 5: 2561
6: 2580 7: 3154 8: 2944 9: 2558 10: 2555 11: 2566 12: 2845 13: 2945 14: 2571 15: 2558 16: 3014
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com. driver: nvidia v: 460.67
alternate: nouveau,nvidia_drm bus-ID: 07:00.0 chip-ID: 10de:1b06 class-ID: 0300
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67 direct render: Yes
Audio: Device-1: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus-ID: 07:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.10.28-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:3 chip-ID: 0b05:17cb
Report: This feature requires one of these tools: hciconfig/bt-adapter
Drives: Local Storage: total: 2.73 TiB used: 9.17 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 1B2QEXE7 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC47 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SKC600512G size: 476.94 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0104 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Kingston model: SUV500240G size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 56RI scheme: GPT
Partition: ID-1: / raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 9.17 GiB (3.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 9.17 GiB (3.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 9.17 GiB (3.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 9.17 GiB (3.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-1: swap-1 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-13: swap-13 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-14: swap-14 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-15: swap-15 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-16: swap-16 type: zram size: 1.96 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 61 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
Info: Processes: 357 Uptime: 37m wakeups: 0 Memory: 31.37 GiB used: 4.75 GiB (15.1%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 880 lib: 237 Shell: Zsh v: 5.8 running-in: yakuake inxi: 3.3.03
