System Monitor Import Bug?
Hello Garuda users. As of yesterday I switched back to Garuda -gaming from nobara linux. I wanted to import my saved system monitor tabs/.pages but when i do they show up blank my nobara setup was as up to date as it could be. Ill add a picture of what I see an one of the saved presets I exported.
Is there anyway to address this?
Operating System: Garuda Linux
KDE Plasma Version: 5.27.8
KDE Frameworks Version: 5.110.0
Qt Version: 5.15.11
Kernel Version: 6.5.6-zen2-1-zen (64-bit)
Graphics Platform: X11
[Face-93882209323744][Appearance]
chartFace=org.kde.ksysguard.textonly
title=Usage
[Face-93882209323744][Sensors]
lowPrioritySensorIds=["cpu/all/system","cpu/all/usage","cpu/all/user"]
[Face-93882228026672][Appearance]
showTitle=false
[Face-93882228026672][Sensors]
lowPrioritySensorIds=["cpu/all/wait","cpu/loadaverages/loadaverage1","cpu/loadaverages/loadaverage5"]
[Face-94578397436080][Appearance]
chartFace=org.kde.ksysguard.barchart
title=CPU
[Face-94578397436080][FaceGrid][Appearance]
chartFace=org.kde.ksysguard.linechart
showTitle=false
[Face-94578397436080][FaceGrid][SensorColors]
cpu/cpu0/usage=57,136,180
cpu/cpu1/usage=180,62,57
cpu/cpu10/usage=57,180,85
cpu/cpu11/usage=57,140,180
cpu/cpu12/usage=180,102,57
cpu/cpu13/usage=57,163,180
cpu/cpu14/usage=57,81,180
cpu/cpu15/usage=57,180,78
cpu/cpu2/usage=57,180,71
cpu/cpu3/usage=57,162,180
cpu/cpu4/usage=57,180,177
cpu/cpu5/usage=57,59,180
cpu/cpu6/usage=88,180,57
cpu/cpu7/usage=180,57,175
cpu/cpu8/usage=57,180,93
cpu/cpu9/usage=57,180,159
cpu/cpu\\/usage=57,180,89
[Face-94578397436080][FaceGrid][Sensors]
highPrioritySensorIds=["cpu/cpu15/usage"]
[Face-94578397436080][SensorColors]
cpu/cpu\\+/usage=57,180,89
[Face-94578397436080][Sensors]
highPrioritySensorIds=["cpu/cpu\\\\d+/usage"]
lowPrioritySensorIds=[]
[Face-94578422997552][Appearance]
title=Temp -  Frequency
[Face-94578422997552][SensorLabels]
cpu/all/averageTemperature=CPU Temperature
[Face-94578422997552][Sensors]
lowPrioritySensorIds=["cpu/all/averageTemperature","cpu/all/averageFrequency"]
totalSensors=["cpu/all/averageTemperature"]
[page]
Title=CPU
actionsFace=
icon=cpu
loadType=
margin=1
[page][row-0]
Title=
heightMode=balanced
isTitle=false
name=row-0
[page][row-0][column-0]
name=column-0
noMargins=
showBackground=true
[page][row-0][column-0][section-0]
face=Face-94578397436080
isSeparator=false
name=section-0
[page][row-1]
Title=
heightMode=minimum
isTitle=false
name=row-1
[page][row-1][column-0]
name=column-0
noMargins=
showBackground=false
[page][row-1][column-0][section-0]
face=Face-94578422997552
isSeparator=false
name=section-0
[page][row-2]
Title=
heightMode=minimum
isTitle=false
name=row-2
[page][row-2][column-0]
name=column-0
noMargins=false
[page][row-2][column-0][section-0]
face=Face-93882209323744
isSeparator=false
name=section-0
[page][row-3]
Title=
heightMode=minimum
isTitle=false
name=row-3
[page][row-3][column-0]
name=column-0
noMargins=
[page][row-3][column-0][section-0]
face=Face-93882228026672
isSeparator=false
name=section-0
garuda-inxi, please. Just exactly as the template states, please.
Kernel: 6.5.6-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=2c314f01-6930-43e5-ae20-9cbddce1a512 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4802
date: 06/15/2023
Device-1: ps-controller-battery-90:fb:a6:d3:7c:ab model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3599 high: 3600 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600
12: 3600 13: 3600 14: 3600 15: 3600 16: 3590 bogomips: 115192
Device-1: NVIDIA GM204 [GeForce GTX 980] vendor: Gigabyte driver: nvidia
v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:13c0 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11")
s-diag: 868mm (34.19")
Monitor-1: DP-2 pos: primary res: 3440x1440 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
Monitor-2: None-1-1 size-res: N/A modes: N/A
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 980/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.264 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 980 driver: nvidia v: 535.113.01
device-ID: 10de:13c0 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GM204 High Definition Audio vendor: Gigabyte
bus-ID: 09:00.1 chip-ID: 10de:0fbb class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Texas Instruments PCM2900C Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 08bb:29c0 class-ID: 0300
API: ALSA v: k6.5.6-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b1 class-ID: 0280
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:5 chip-ID: 8087:07dc
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.86 TiB used: 1.83 TiB (63.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 32A0T2IA temp: 42.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX3 size: 111.79 GiB
serial: <filter> fw-rev: 2.22 scheme: GPT
model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 214.04 GiB size: 214.04 GiB (100.00%)
used: 88.18 GiB (41.2%) fs: btrfs dev: /dev/nvme0n1p13 maj-min: 259:13
ID-2: /boot/efi raw-size: 498 MiB size: 497 MiB (99.80%)
used: 334.9 MiB (67.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 214.04 GiB size: 214.04 GiB (100.00%)
ID-4: /var/log raw-size: 214.04 GiB size: 214.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 214.04 GiB size: 214.04 GiB (100.00%)
ID-2: swap-2 type: partition size: 9.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 36.0 C mobo: 39.0 C gpu: nvidia temp: 46 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 26%
Processes: 368 Uptime: 4m wakeups: 1 Memory: total: 16 GiB
available: 15.53 GiB used: 3.72 GiB (24.0%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2088 libs: 584 tools: octopi,pamac,paru
Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-09
Last full system update: 2023-10-11
Failed units:            packagekit.service
Either re-start, re-enable, mask or remove in systemd.
Is it explicitly installed by Garuda, or a dependency of what you may have installed? Was it added so that Discover can be used as a package manager?
Let’s see what/which packagekit/s are installed:
Please list the output of: sudo pacman -Ss packagekit
And: sudo pacman -Sii packagekit
Read: Making sure you're not a bot!
Let’s take care of this first, then worry about your monitor conf.
An yes I did install discover from the setup assistant.
  • sudo pacman -Ss packagekit
type or paste extra/apper 1.0.0-6 [installed]
An application and package manager using PackageKit
extra/cockpit-packagekit 302-1
Cockpit user interface for packages
extra/gnome-packagekit 43.0-1
Collection of graphical tools for PackageKit to be used in the GNOME desktop
extra/libpackagekit-glib 1.2.7-1 [installed]
GLib library for accessing PackageKit
extra/packagekit 1.2.7-1 [installed]
A system designed to make installation and updates of packages easier
extra/packagekit-qt5 1.1.1-1 [installed]
Qt5 bindings for PackageKit
extra/packagekit-qt6 1.1.1-1
Qt6 bindings for PackageKitcode here
  • sudo pacman -Sii packagekit
type or paste coRepository      : extra
Version         : 1.2.7-1
Description     : A system designed to make installation and updates of packages easier
Architecture    : x86_64
URL             : https://www.freedesktop.org/software/PackageKit/
Licenses        : GPL
Groups          : None
Provides        : None
Depends On      : libpackagekit-glib  pacman>=6.0.0  polkit  sqlite
Optional Deps   : bash-completion: command completion in bash
Required By     : cockpit-packagekit  gnome-packagekit  packagekit-qt5  packagekit-qt6  realmd
Optional For    : enlightenment
Conflicts With  : None
Replaces        : None
Download Size   : 530.37 KiB
Installed Size  : 2719.55 KiB
Packager        : Christian Hesse <eworm@archlinux.org>
Build Date      : Mon 28 Aug 2023 09:48:37 AM CDT
MD5 Sum         : 215755159d9a9313df6c83faa02c6f55
SHA-256 Sum     : 6b0872f705f976148148d95df2954b4e2713fc6ef009d8e0c2fb5a0cb1719b1f
Signatures      : 6D42BDD116E0068Fde here
That one, in particular, can be a real bugaboo in KDE. I would recommend removing all traces of packagekit. You don’t need it and, truly, shouldn’t have it in an Arch-based distribution. Packagekit is YAPM. Yet Another Package Manager. We have enough already. :slight_smile: It sounds like it’s a helpful utility, and in some distributions I suppose it is. But not in this realm of Linuxland. It can be safely removed. :slight_smile:
I don’t know what, if any, impact it might have on your monitor problems, but…
will get rid of it thank you!
Well I’m not sure what changed but i could add them again. Some of the sensor links were broken but that was simple to fix.
