System locks up when Emulating Xenoblade Chronicles Definitive Edition with Ryujinx
When Emulating Xenoblade Chronicles Definitive Edition with Ryujinx the emulator sometimes locks up and takes the entire system with it, Audio continues to play and i can still ssh into the system although killing Ryujinx does not fix the system and the system requires a restart.
12System:
  12Kernel 6.10.3-zen1-1-zen 12arch x86_64 12bits 64 12compiler gcc 12v 14.2.1 12clocksource tsc
    12avail hpet,acpi_pm 12parameters BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=0b8d6f27-1f7f-4474-9e3e-aad0794eb3ef rw rootflags=subvol=@ quiet loglevel=3 ibt=off
  12Desktop KDE Plasma 12v 6.1.3 12tk Qt 12v N/A 12info frameworks 12v 6.4.0 12wm kwin_wayland 12vt 1 12dm SDDM
    12Distro Garuda 12base Arch Linux
12Machine:
  12Type Desktop 12Mobo Gigabyte 12model B650M AORUS ELITE 12serial <superuser required>
    12uuid <superuser required> 12UEFI American Megatrends LLC. 12v F8c 12date 08/16/2023
12CPU:
  12Info 12model AMD Ryzen 5 7600X 12bits 64 12type MT MCP 12arch Zen 4 12gen 5 12level v4 12note check 12built 2022+
    12process TSMC n5 (5nm) 12family 0x19 (25) 12model-id 0x61 (97) 12stepping 2 12microcode 0xA601203
  12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 384 KiB
    12desc d-6x32 KiB; i-6x32 KiB 12L2 6 MiB 12desc 6x1024 KiB 12L3 32 MiB 12desc 1x32 MiB
  12Speed (MHz) 12avg 4612 12high 5413 12min/max 400/5453 12scaling 12driver amd-pstate-epp
    12governor performance 12cores 121 4310 122 5413 123 4544 124 4350 125 4312 126 4351 127 4348 128 5367 129 5402 1210 4306
    1211 4296 1212 4351 12bogomips 112596
  12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  12Vulnerabilities <filter>
12Graphics:
  12Device-1 AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT] 12vendor ASUSTeK
    12driver amdgpu 12v kernel 12arch RDNA-2 12code Navi-2x 12process TSMC n7 (7nm) 12built 2020-22 12pcie 12gen 4
    12speed 16 GT/s 12lanes 16 12ports 12active DP-2,DP-3 12off HDMI-A-1 12empty DP-1,Writeback-1
    12bus-ID 03:00.0 12chip-ID 1002:73df 12class-ID 0300
  12Device-2 AMD Raphael 12vendor Gigabyte 12driver amdgpu 12v kernel 12arch RDNA-2 12code Navi-2x
    12process TSMC n7 (7nm) 12built 2020-22 12pcie 12gen 4 12speed 16 GT/s 12lanes 16 12ports 12active none
    12empty Writeback-2 12bus-ID 12:00.0 12chip-ID 1002:164e 12class-ID 0300 12temp 37.0 C
  12Display wayland 12server X.org 12v 1.21.1.13 12with Xwayland 12v 24.1.1 12compositor kwin_wayland 12driver
    12X 12loaded amdgpu 12unloaded modesetting,radeon 12alternate fbdev,vesa 12dri radeonsi 12gpu amdgpu,amdgpu
    12d-rect 5760x3240 12display-ID 0
  12Monitor-1 DP-2 12pos bottom-r 12res 1920x1080 12size N/A 12modes N/A
  12Monitor-2 DP-3 12pos primary,top-left 12res 3840x2160 12size N/A 12modes N/A
  12API EGL 12v 1.5 12hw 12drv amd radeonsi 12platforms 12device 0 12drv radeonsi 12device 1 12drv radeonsi
    12device 2 12drv swrast 12gbm 12drv kms_swrast 12surfaceless 12drv radeonsi 12wayland 12drv radeonsi 12x11
    12drv radeonsi
  12API OpenGL 12v 4.6 12compat-v 4.5 12vendor amd mesa 12v 24.1.5-arch1.1 12glx-v 1.4 12direct-render yes
    12renderer AMD Radeon RX 6750 XT (radeonsi navi22 LLVM 18.1.8 DRM 3.57 6.10.3-zen1-1-zen)
    12device-ID 1002:73df 12memory 11.72 GiB 12unified no 12display-ID :1.0
  12API Vulkan 12v 1.3.279 12layers 15 12device 0 12type discrete-gpu 12name AMD Radeon RX 6750 XT (RADV
    NAVI22) 12driver mesa radv 12v 24.1.5-arch1.1 12device-ID 1002:73df 12surfaces xcb,xlib,wayland
    12device 1 12type integrated-gpu 12name AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) 12driver mesa radv
    12v 24.1.5-arch1.1 12device-ID 1002:164e 12surfaces xcb,xlib,wayland 12device 2 12type cpu 12name llvmpipe
    (LLVM 18.1.8 256 bits) 12driver mesa llvmpipe 12v 24.1.5-arch1.1 (LLVM 18.1.8) 12device-ID 10005:0000
12Audio:
  12Device-1 AMD Navi 21/23 HDMI/DP Audio 12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s
    12lanes 16 12bus-ID 03:00.1 12chip-ID 1002:ab28 12class-ID 0403
  12Device-2 AMD Rembrandt Radeon High Definition Audio 12driver snd_hda_intel 12v kernel 12pcie 12gen 4
    12speed 16 GT/s 12lanes 16 12bus-ID 12:00.1 12chip-ID 1002:1640 12class-ID 0403
  12Device-3 AMD Family 17h/19h HD Audio 12vendor Gigabyte 12driver snd_hda_intel 12v kernel 12pcie 12gen 4
    12speed 16 GT/s 12lanes 16 12bus-ID 12:00.6 12chip-ID 1022:15e3 12class-ID 0403
  12Device-4 Realtek LG Monitor HP MIC 12driver hid-generic,usbhid 12type USB 12rev 2.0 12speed 480 Mb/s
    12lanes 1 12mode 2.0 12bus-ID 1-4.2.4:7 12chip-ID 0bda:4027 12class-ID 0300 12serial <filter>
  12Device-5 C-Media AT9934USB 12driver hid-generic,snd-usb-audio,usbhid 12type USB 12rev 1.1
    12speed 12 Mb/s 12lanes 1 12mode 1.1 12bus-ID 7-1.1:3 12chip-ID 0d8c:016c 12class-ID 0300 12serial <filter>
  12API ALSA 12v k6.10.3-zen1-1-zen 12status kernel-api 12with aoss 12type oss-emulator 12tools N/A
  12Server-1 PipeWire 12v 1.2.2 12status active 12with 121 pipewire-pulse 12status active 122 wireplumber
    12status active 123 pipewire-alsa 12type plugin 124 pw-jack 12type plugin 12tools pactl,pw-cat,pw-cli,wpctl
12Network:
  12Device-1 Realtek RTL8125 2.5GbE 12vendor Gigabyte 12driver r8169 12v kernel 12pcie 12gen 2 12speed 5 GT/s
    12lanes 1 12port e000 12bus-ID 0e:00.0 12chip-ID 10ec:8125 12class-ID 0200
  12IF enp14s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12IF-ID-1 br-1733dc3b9dcf 12state down 12mac <filter>
  12IF-ID-2 docker0 12state down 12mac <filter>
  12IF-ID-3 virbr0 12state down 12mac <filter>
  12Info 12services NetworkManager, smbd, sshd, systemd-timesyncd
12Bluetooth:
  12Device-1 Realtek Bluetooth Radio 12driver btusb 12v 0.8 12type USB 12rev 1.1 12speed 12 Mb/s 12lanes 1
    12mode 1.1 12bus-ID 1-2:2 12chip-ID 0bda:8771 12class-ID e001 12serial <filter>
  12Report btmgmt 12ID hci0 12rfk-id 0 12state up 12address <filter> 12bt-v 5.1 12lmp-v 10 12status
    12discoverable no 12pairing no 12class-ID 6c0104
12Drives:
  12Local Storage 12total 18.7 TiB 12used 1.65 TiB (8.8%)
  12SMART Message Unable to run smartctl. Root privileges required.
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Kingston 12model SKC3000D2048G 12size 1.86 TiB 12block-size
    12physical 512 B 12logical 512 B 12speed 63.2 Gb/s 12lanes 4 12tech SSD 12serial <filter> 12fw-rev EIFK31.6
    12temp 46.9 C 12scheme GPT
  12ID-2 /dev/sda 12maj-min 8:0 12vendor Crucial 12model CT2000MX500SSD1 12size 1.82 TiB 12block-size
    12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s 12tech SSD 12serial <filter> 12fw-rev 023 12scheme GPT
  12ID-3 /dev/sdb 12maj-min 8:16 12vendor Seagate 12model ST16000NM000J-2TW103 12size 14.55 TiB 12block-size
    12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s 12tech HDD 12rpm 7200 12serial <filter> 12fw-rev SN02
    12scheme GPT
  12ID-4 /dev/sdc 12maj-min 8:32 12vendor SanDisk 12model SDSSDXPS480G 12size 447.13 GiB 12block-size
    12physical 512 B 12logical 512 B 12speed 6.0 Gb/s 12tech SSD 12serial <filter> 12fw-rev 00RL 12scheme GPT
  12ID-5 /dev/sdd 12maj-min 8:48 12vendor Kingston 12model DataTraveler 3.0 12size 28.82 GiB 12block-size
    12physical 512 B 12logical 512 B 12type USB 12rev 3.2 12spd 5 Gb/s 12lanes 1 12mode 3.2 gen-1x1 12tech N/A
    12serial <filter> 12scheme MBR
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
  12ID-1 / 12raw-size 1.86 TiB 12size 1.86 TiB (100.00%) 12used 1.65 TiB (88.4%) 12fs btrfs
    12dev /dev/nvme0n1p2 12maj-min 259:2
  12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 584 KiB (0.2%) 12fs vfat
    12dev /dev/nvme0n1p1 12maj-min 259:1
  12ID-3 /home 12raw-size 1.86 TiB 12size 1.86 TiB (100.00%) 12used 1.65 TiB (88.4%) 12fs btrfs
  12ID-4 /var/log 12raw-size 1.86 TiB 12size 1.86 TiB (100.00%) 12used 1.65 TiB (88.4%) 12fs btrfs
  12ID-5 /var/tmp 12raw-size 1.86 TiB 12size 1.86 TiB (100.00%) 12used 1.65 TiB (88.4%) 12fs btrfs
12Swap:
  12Kernel 12swappiness 133 (default 60) 12cache-pressure 100 (default) 12zswap no
  12ID-1 swap-1 12type zram 12size 30.5 GiB 12used 59.8 MiB (0.2%) 12priority 100 12comp zstd
    12avail lzo,lzo-rle,lz4,lz4hc,842 12max-streams 12 12dev /dev/zram0
12Sensors:
  12System Temperatures 12cpu 63.1 C 12mobo 34.0 C
  12Fan Speeds (rpm) N/A
  12GPU 12device amdgpu 12temp 44.0 C 12mem 42.0 C 12fan 0 12watts 7.00 12device amdgpu 12temp 37.0 C
12Info:
  12Memory 12total 32 GiB 12note est. 12available 30.5 GiB 12used 7.07 GiB (23.2%)
  12Processes 403 12Power 12uptime 9m 12states freeze,mem,disk 12suspend deep 12avail s2idle 12wakeups 0
    12hibernate platform 12avail shutdown, reboot, suspend, test_resume 12image 12.19 GiB
    12services org_kde_powerdevil, power-profiles-daemon, upowerd 12Init systemd 12v 256
    12default graphical 12tool systemctl
  12Packages 2025 12pm pacman 12pkgs 1957 12libs 555 12tools octopi,paru 12pm flatpak 12pkgs 68 12Compilers
    12clang 18.1.8 12gcc 14.2.1 12Client shell wrapper 12v 5.2.32-release 12inxi 3.3.35
  System install date:     2024-05-12
  Last full system update: 2024-08-06
  Failed units:            mariadb.service systemd-vconsole-setup.service
