System Lags/Jitters/Hangs in Plasma+ Nvidia+ Wayland
  Kernel: 6.10.6-1-clear arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-clear
    root=UUID=3ee3cf54-033c-4a9a-be77-5c0fc57e51da rw rootflags=subvol=@ quiet loglevel=3 splash
    mitigations=off plymouth.enable=1 plymouth.theme=spinner ibt=off
  Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0 wm: kwin_wayland vt: 1
  Type: Laptop System: Acer product: Nitro AN515-54 v: V1.33 serial: <superuser required>
  Mobo: CFL model: Octavia_CFS v: V1.33 serial: <superuser required> part-nu: 0000000000000000
    uuid: <superuser required> UEFI: Insyde v: 1.33 date: 11/17/2020
  ID-1: BAT1 charge: 43.1 Wh (100.0%) condition: 43.1/57.5 Wh (75.0%) volts: 16.7 min: 15.4
    model: LGC AP18E8M type: Li-ion serial: <filter> status: full
  Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 level: v3
    note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
    microcode: 0xF8
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1800 min/max: 800/4100 scaling: driver: intel_pstate governor: powersave
    cores: 1: 1800 2: 1800 3: 1800 4: 1800 5: 1800 6: 1800 7: 1800 8: 1800 bogomips: 38400
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Acer Incorporated ALI driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
    bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Acer Incorporated ALI
    driver: nvidia v: 560.35.03 alternate: nvidiafb,nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
  Device-3: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 1-5:2 chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2 compositor: kwin_wayland
    driver: X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
    gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: LG Display 0x065a built: 2019 res: 1920x1080 dpi: 142 gamma: 1.2
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel UHD Graphics 630
    (CFL GT2) driver: mesa intel v: 24.2.1-arch1.1 device-ID: 8086:3e9b surfaces: xcb,xlib,wayland
    device: 1 type: discrete-gpu name: NVIDIA GeForce GTX 1650 driver: nvidia v: 560.35.03
    device-ID: 10de:1f91 surfaces: xcb,xlib,wayland device: 2 type: cpu name: llvmpipe (LLVM
    18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.1-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
  API: ALSA v: k6.10.6-1-clear status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse status: active
    tools: pactl,pw-cat,pw-cli
,wpctl
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp8s0 state: up mac: <filter>
  Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0029 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
    discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 1.2 TiB used: 771.07 GiB (62.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200 MTFDHBA256TCK size: 238.47 GiB
    fw-rev: P1MA003 temp: 63.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
    fw-rev: ACM1 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: USB 3.2Gen1 size: 57.28 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 238.38 GiB size: 238.38 GiB (100.00%) used: 34.74 GiB (14.6%) fs: btrfs
    dev: /dev/nvme0n1p5 maj-min: 259:2
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 572 KiB (0.6%) fs: vfat
  ID-3: /home raw-size: 238.38 GiB size: 238.38 GiB (100.00%) used: 34.74 GiB (14.6%) fs: btrfs
  ID-4: /var/log raw-size: 238.38 GiB size: 238.38 GiB (100.00%) used: 34.74 GiB (14.6%)
    fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:2
  ID-5: /var/tmp raw-size: 238.38 GiB size: 238.38 GiB (100.00%) used: 34.74 GiB (14.6%)
  ID-1: swap-1 type: zram size: 15.45 GiB used: 9 MiB (0.1%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc max-streams: 8 dev: /dev/zram0
  System Temperatures: cpu: 80.0 C pch: 78.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.45 GiB used: 4.91 GiB (31.8%)
  Processes: 343 Power: uptime: 3h 21m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 6.11 GiB
    services: org_kde_powerdevil, power-profiles-daemon, thermald, upowerd Init: systemd v: 256
  Packages: pm: pacman pkgs: 1243 libs: 371 tools: pamac,yay pm: flatpak pkgs: 0 Compilers:
    gcc: 14.2.1 Client: shell wrapper v: 5.2.32-release inxi: 3.3.35
  System install date:     2024-08-24
  Last full system update: 2024-09-04 ↻
  Failed units:            pamac-daemon.service
Using KDE PLASMA on wayland with nvidia , system suddenly starts lagging too much , i have to use other tty to use killall kwin_wayland to fix it , cursor movement starts leaving a trail which if moved enough covers all the window with its icons of trails of cursor .
I have even set power-profiles from battery submenu in kde to performance and it happens during general usage 5 to 6 tabs in firefox , one terminal open and one vlc video playing .
System has enough RAM (16GB) and enough computing too (i5 9th gen)
Kindly tell all steps to fix this nuisance.
This is a combination known to have issues still. For some specific hardware it’s working fine and others not. You may have a more stable experience on X11. You can always try again in a few months and see if it’s any better.
Try a different kernel. The Clear kernel is aggressively optimized for performance on Intel hardware. It is not optimized for stability, and is not necessarily accommodating for mixed hardware types (especially when it comes to hardware configurations that deviate from Intel’s ecosystem). If you are having issues of any kind, this is one of the first things I would change.
^ This. There has been issues with kernels just prior to 6.10.7 (which also includes the prior LTS version; as the issues that originated from those kernel versions made it over to LTS at the time). A good number of people were having freezing (where REISUB wouldn’t work) or random reboots. I had the freezing issues, and one time KDE did have a hard time starting correctly even. The Zen 6.10.7 kernel seems great so far though :smile:
Be sure to try something that offers 6.10.7 (like Zen) or the most latest LTS (currently 6.6.48-1).
Okay
First I am going to switch to linux-zen and if lags dont stop then I will switch from wayland to x11
Lag and jittering have stopped since i went back to linux-zen and x11
linux-clear is not fit for daily use or has some serious bugs
