System is not using dracut for initramfs
$ garuda-inxi
  Kernel: 6.12.41-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=3caa4a96-5787-457b-817a-8117f05250c4 rw rootflags=subvol=@
    cryptdevice=UUID=ec3ee267-8732-4cc4-8960-c39fbbf5c306:luks-ec3ee267-8732-4cc4-8960-c39fbbf5c306
    root=/dev/mapper/luks-ec3ee267-8732-4cc4-8960-c39fbbf5c306
    resume=/dev/mapper/luks-22d6ffdc-91a9-4c97-ac75-1f30bca3e10c loglevel=1
    quiet ibt=off
    with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
  Type: Desktop System: MSI product: MS-7917 v: 1.0
  Mobo: MSI model: Z97 GAMING 5 (MS-7917) v: 1.0
    UEFI: American Megatrends v: 1.13 date: 02/16/2016
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: N/A
  Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
  Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 64023
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Micro-Star MSI driver: i915 v: kernel arch: Gen-7.5
    process: Intel 22nm built: 2013 ports: active: none
    empty: HDMI-A-1,HDMI-A-2,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0412
    class-ID: 0380
  Device-2: Advanced Micro Devices [AMD/ATI] RV790 [Radeon HD 4890]
    vendor: ASUSTeK driver: radeon v: kernel alternate: amdgpu arch: TeraScale
    code: R6xx/RV6xx/RV7xx process: TSMC 55-65nm built: 2005-13 pcie: gen: 2
    speed: 5 GT/s lanes: 16 ports: active: HDMI-A-3 off: DVI-I-1
    empty: DIN-1,VGA-2 bus-ID: 01:00.0 chip-ID: 1002:9460 class-ID: 0300
    temp: 66.5 C
  Display: x11 server: X.Org v: 21.1.18 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: modesetting,radeon alternate: fbdev,intel,vesa dri: r600,crocus
    gpu: radeon display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
    s-diag: 584mm (22.99")
  Monitor-1: DVI-I-1 mapped: DVI-0 note: disabled model: HP E243i
    serial: <filter> built: 2019 res: N/A dpi: 94 gamma: 1.2
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
    max: 1920x1200 min: 720x400
  Monitor-2: HDMI-A-3 mapped: HDMI-2 pos: primary model: ViewSonic VX2858Sml
    serial: <filter> built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 79 gamma: 1.2 size: 621x341mm (24.45x13.43") diag: 708mm (27.9")
  API: Vulkan v: 1.4.321 layers: 11 device: 0 type: integrated-gpu
    name: Intel HD Graphics 4600 (HSW GT2) driver: mesa intel v: 25.1.7-arch1.1
    device-ID: 8086:0412 surfaces: N/A device: 1 type: cpu name: llvmpipe
    (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
  Info: Tools: api: vulkaninfo de: xfce4-display-settings
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
  Device-3: Advanced Micro Devices [AMD/ATI] RV770 HDMI Audio [Radeon HD
    4850/4870] vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa30 class-ID: 0403
  API: ALSA v: k6.12.41-1-lts status: kernel-api tools: N/A
  Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 1969:e091 class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 2550:8761
  Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
    bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: class-ID: 0104
  Supported mdraid levels: raid1
  Device-1: md124 maj-min: 9:124 type: mdraid level: mirror status: active
  Info: report: 2/2 UU blocks: 976759808 chunk-size: N/A
  Components: Online:
  0: sdd maj-min: 8:48 size: 931.51 GiB
  1: sdc maj-min: 8:32 size: 931.51 GiB
  Device-2: md125 maj-min: 9:125 type: mdraid level: mirror status: active
  Components: Online:
  0: sdb maj-min: 8:16 size: 931.51 GiB
  1: sda maj-min: 8:0 size: 931.51 GiB
  Device-3: md126 maj-min: 9:126 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 5552 chunk-size: N/A
  Components: Online: N/A Spare:
  0: sdc maj-min: 8:32 size: 931.51 GiB state: S
  1: sdd maj-min: 8:48 size: 931.51 GiB state: S
  Device-4: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
  0: sda maj-min: 8:0 size: 931.51 GiB state: S
  1: sdb maj-min: 8:16 size: 931.51 GiB state: S
  Local Storage: total: raw: 3.87 TiB usable: -1703911688 used: 174.31 GiB
    model: WD10EZEX-75ZF5A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
    model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    fw-rev: 1A01
  ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD1002FAEX-00Z3A0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
  ID-5: /dev/sde maj-min: 8:64 vendor: Seagate model: ST240HM000-1G5152
    size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: C675 scheme: GPT
  ID-6: /dev/sdf maj-min: 8:80 vendor: SanDisk model: Ultra size: 14.48 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
    used: 174.31 GiB (84.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ec3ee267-8732-4cc4-8960-c39fbbf5c306
    used: 776 KiB (0.3%) fs: vfat dev: /dev/sde1 maj-min: 8:65
  ID-3: /home raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
  ID-4: /var/log raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
  ID-5: /var/tmp raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.07 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
    mapped: luks-22d6ffdc-91a9-4c97-ac75-1f30bca3e10c
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: radeon temp: 66.0 C
  Memory: total: 16 GiB note: est. available: 15.07 GiB used: 1.81 GiB (12.0%)
  Processes: 287 Power: uptime: 2h 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.98 GiB services: upowerd,xfce4-power-manager
  Packages: pm: pacman pkgs: 1812 libs: 503 tools: pamac,paru,yay Compilers:
    clang: 20.1.8 gcc: 15.1.1 Shell: Bash v: 5.3.3 running-in: xfce4-terminal
    inxi: 3.3.38
Garuda (2.7.5-1):
  System install date:     2023-02-21
  Last full system update: 2025-08-13 ↻
20/21 checks run in 0.83 seconds āŒ›
Powered by garuda-health šŸ¦…
--- LOW ---
--- INFO ---
 - System is not using dracut for initramfs (fix available)
System updated! 🐧
20/21 checks run in 0.84 seconds āŒ›
--- LOW ---
--- INFO ---
Specifically I am getting this message when I am running garuda-update. I am wondering what it is and if it is something I should configure? What are the benefits if any? Seemed a bit involved (from a google search) and I don’t like to mess with my initramfs config if I do not have to. What say you?
At this time, dracut wasn’t implemented as default but garuda-health take a look on dracut → result is then this message.
That’s not a error. You can switch to dracut but not a must. (my mind)
Over garuda-health --fix you can do this.
So I attempted the install dracut and it was successful however when I reboot my system I got prompted multiple times for my luks decrypt pw. After I input the initial one (as usual), I got prompted for several more on different UUIDs (guessing there was some sort of mismatch).
Anyways, after inputting it again it just gave a wheel of death for several minutes with no timeout and no reboot. I was able to replicate this a couple times with each reboot.
Alas, snappertools to the rescue so here I am with initramfs again lol. Should have trusted my initial instincts but it was a good exercise I guess.
I was curious what benefits dracut offers. Why would it cause my system to ask for multiple decrypts upon boot?
That’s the reason why (my mind)
short explanation
dracut generate then multiple entrys for your lurks inside initramfs. (btrfs / subvolumes)
