System Health Check Report issue
Hi, after update I see this:
(14/14) Syncing all file systems...
--> Updating AUR packages with paru..
:: Looking for devel upgrades...
there is nothing to do
System updated! 🐧
21/21 checks run in 0.83 seconds ⌛
Powered by garuda-health 🦅
--- HIGH ---
- Root Btrfs filesystem has less than 5GB free space
--- LOW ---
- Failed systemd services found: nmb.service
--- INFO ---
╭─honza@honza in ~ took 6m5s
╰─λ
what does it mean and how do I fix it? I have 68.6 GiB free space so this is weird.
garuda-inxi:
╰─λ garuda-inxi
Kernel: 6.15.9-zen1-1.1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=e110a10c-a5b1-4454-9546-52f0a764cedf rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Laptop System: LENOVO product: 21KR v: ThinkBook 13x G4 IMH
serial: <superuser required> Chassis: type: 10 v: ThinkBook 13x G4 IMH
Mobo: LENOVO model: LNVNB161216 v: SDK0T76528 WIN
serial: <superuser required> part-nu: LENOVO_MT_21KR_BU_idea_FM_ThinkBook
13x G4 IMH uuid: <superuser required> UEFI: LENOVO v: MTCN51WW
date: 04/07/2025
ID-1: BAT1 charge: 49.5 Wh (66.4%) condition: 74.5/74.0 Wh (100.7%)
power: 16.9 W volts: 15.8 min: 15.6 model: Simplo BASE-BAT type: Li-poly
serial: <filter> status: discharging cycles: 16
Info: model: Intel Core Ultra 9 185H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x24
Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4800:5100:3800:2500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
bogomips: 135168
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
built: 2023+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
Monitor-1: eDP-1 model: California Institute of eDP-1-0x1319 built: 2023
res: mode: 2880x1920 hz: 120 scale: 170% (1.7) to: 1694x1129 dpi: 257
gamma: 1.2 size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2
modes: 2880x1920
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 30.22 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: integrated-gpu name: Intel
Arc Graphics (MTL) driver: mesa intel v: 25.1.7-arch1.1
device-ID: 8086:7d55 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
Device-1: Intel Meteor Lake IPU vendor: Lenovo driver: intel-ipu6
alternate: intel_ipu6 bus-ID: 00:05.0 chip-ID: 8086:7d19 class-ID: 0480
Device-2: Intel Meteor Lake-P HD Audio vendor: Lenovo
driver: sof-audio-pci-intel-mtl
alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
API: ALSA v: k6.15.9-zen1-1.1-zen status: kernel-api tools: N/A
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
Local Storage: total: 953.87 GiB used: 756.47 GiB (79.3%)
model: MZAL81T0HDLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 6L1QKXD7 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 826.8 GiB size: 826.8 GiB (100.00%)
used: 756.43 GiB (91.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 39 MiB (40.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 826.8 GiB size: 826.8 GiB (100.00%)
ID-4: /var/log raw-size: 826.8 GiB size: 826.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 826.8 GiB size: 826.8 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.95 GiB used: 173.5 MiB (0.5%)
Src: /sys System Temperatures: cpu: 42.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Memory: total: 32 GiB note: est. available: 30.95 GiB used: 5.93 GiB (19.2%)
Processes: 405 Power: uptime: 20m states: freeze,mem,disk suspend: s2idle
image: 12.35 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1518 libs: 426 tools: octopi,paru Compilers:
clang: 20.1.8 gcc: 15.1.1 Shell: Bash v: 5.3.3 default: fish v: 4.0.2
Garuda (2.7.5-1):
System install date:     2025-07-07
Last full system update: 2025-08-10 ↻
Failed units:            nmb.service
20/21 checks run in 0.84 seconds ⌛
--- HIGH ---
--- LOW ---
--- INFO ---
╭─honza@honza in ~ took 3s
Thanks for any tips in advance!
After a restart I see this:
.%;888:8898898:                honza@honza-laptop-garuda
x;XxXB%89b8:b8%b88:              -------------------------
.8Xxd                8X:.           OS: Garuda Linux x86_64
.8Xx;                    8x:.         Host: 21KR (ThinkBook 13x G4 IMH)
.tt8x          .d            x88;       Kernel: 6.15.9-zen1-1.1-zen
.@8x8;          .db:              xx@;     Uptime: 23 seconds
,tSXX°          .bbbbbbbbbbbbbbbbbbbB8x@;    Packages: 1518 (pacman)[stable]
.SXxx            bBBBBBBBBBBBBBBBBBBBbSBX8;    Shell: fish 4.0.2
,888S                                     pd!    Resolution: 2880x1920
8X88/                                       q     DE: KDE Plasma 6.4.4
8X88/                                             WM: KWin (Wayland)
GBB.                                              WM Theme: Sweet-Dark
x%88        d888@8@X@X@X88X@@XX@@X@8@X.          Theme: Dr460nized (Sweet) [Qt], Sweet-Dark [GTK2/3/4]
dxXd    dB8b8b8B8B08bB88b998888b88x.           Icons: BeautyLine [Qt], BeautyLine [GTK2/3/4]
dxx8o                      .@@;.              Terminal: konsole 25.4.3
dx88                   .t@x.                Terminal Font: FiraCode Nerd Font Mono 12
d:SS@8ba89aa67a853Sxxad.                  CPU: Intel(R) Core(TM) Ultra 9 185H (22) @ 5.10 GHz
.d988999889889899dd.                    GPU: Intel Arc Graphics @ 2.35 GHz [Integrated]
Memory: 3373 MiB / 31691 MiB
╭─honza@honza in ~
╰─λ garuda-update -a
[sudo] password for honza:
garuda is up to date
core is up to date
extra is up to date
multilib        134.0 KiB   342 KiB/s 00:00 [-----------------------------------------------------------] 100%
chaotic-aur is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
System updated! 🐧
21/21 checks run in 0.78 seconds ⌛
--- HIGH ---
╭─honza@honza in ~ as 🧙 took 40s
╰─λ
Hello @honza! What do you need help with? You will need to free space on your system.
I booted up the computer 15 minutes ago. So there was no open reboot pending.
:: Paketdatenbanken werden synchronisiert …
 garuda ist aktuell
 core                            121,6 KiB   436 KiB/s 00:00 [--------------------------------] 100%
 extra                             7,9 MiB  15,4 MiB/s 00:01 [--------------------------------] 100%
 multilib                        134,0 KiB   511 KiB/s 00:00 [--------------------------------] 100%
 chaotic-aur                     639,8 KiB   591 KiB/s 00:01 [--------------------------------] 100%
spawn pacman -Su
:: Nach devel-Upgrades suchen...
 es gibt nichts zu tun
System updated! 🐧
21/21 checks run in 1.21 seconds ⌛
**--- INFO ---**
** - A reboot is pending (update applied since last reboot)**
Same thing I get in RANI(git).
It’s not delayed bro, that means after you sudo pacman -Syu or garuda-update it tells you to reboot so that the update can be applied or you can feel it
Not every update requires a restart. This is especially true if no updates have been performed after a restart and there is nothing to update.
I do that every time I update and it’s safe, it’s probably just a warning to restart if there might be a big update
I reboot more than necessary, but that’s not the point.
This implies that a reboot is necessary due to updates made since the last restart. However, this is not the case.
It’s nothing bro, just ask the founder admin or developer, it’s just a notification if there might be a big update
@TNE @Apocalypticus @DragoniaCompany1 thank you for the answers, but I feel like none of you talked about the - - - HIGH - - - priority issue. Now I see this:
core 121.5 KiB 614 KiB/s 00:00 [-----------------------------------------------------------] 100%
extra 7.9 MiB 11.3 MiB/s 00:01 [-----------------------------------------------------------] 100%
multilib 134.0 KiB 601 KiB/s 00:00 [-----------------------------------------------------------] 100%
chaotic-aur 639.1 KiB 825 KiB/s 00:01 [-----------------------------------------------------------] 100%
core downloading...
spawn pacman -Su
System updated! 🐧
21/21 checks run in 0.82 seconds ⌛
Powered by garuda-health 🦅e
--- HIGH ---
Press enter to exit
WHAT DOES IT MEAAAAN??? I have more than enough space on my drive :sob: I know that for sure because I can literally download (and then delete) youtube videos now.
Check your / (root) folder with
lsblk - f
The command I devised to display unallocated space is:
btrfs filesystem usage / 2> /dev/null | grep -i 'Device unallocated:' | awk '{print $3}'
You have only 8,5 % free space. (08-10)
That’s the reason why you read this message.
To become more free space clear the cache, your counts of snapshot.
use (example) paccache -vrk3 → that delete all packages inside /var/cache/pacman/pkg except the last 3 from each package.
Move files/folder from your home folder or where ever you store files to another drive (if possible)
You run in trouble if not → soon you won’t even be able to perform an update or the system won’t be able to create a snapshot anymore if you do not generate free space.
You only have 5gb of usable space remaining.
ooh alright thanks I get it now
