Hello!
My system hangs and i need to physically reset it after sleep. this behavior started very recently, so i tried to restore to days back and it didn't fix the issue. I tried to roll forward as there were some updates available. it didn't help.
I also ran few tests by trying to boot from a snapshot and then going to sleep mode and trying to wake up the system. I went as far back as beginning of May, where i know for a fact it was working ok. Actually i'm pretty sure it was working ok just few days back.
But my tests gave negative results - the system stops responding, mouse and keyboard are not working. Only reset helps...
I had to turn off automatic sleep and seems like will have to shutdown the system manually, until this problem is fixed...
output of journalctl -r -b -1 right after reboot/reset is available here:
[🔍] × garuda-inxi
Kernel: 5.17.5-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=cfa490e8-fc51-4b99-b39e-9e21021d7ed1 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0702
date: 07/04/2019
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3667 high: 4208 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3598 2: 3591
3: 3585 4: 3707 5: 3443 6: 3482 7: 3538 8: 4174 9: 3591 10: 3589 11: 3622
12: 3593 13: 3592 14: 3783 15: 3594 16: 3592 17: 3837 18: 4074 19: 3753
20: 3577 21: 3618 22: 3903 23: 3544 24: 3587 25: 4017 26: 3590 27: 3581
28: 3596 29: 3509 30: 4208 31: 3503 32: 3385 bogomips: 223583
mitigation: Retpolines, IBPB: conditional, STIBP: always-on, RSB filling
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2,DP-3 empty: DP-1,HDMI-A-1 bus-ID: 0e:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Afatech NarviCapture U3 HD60 4K Device type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1:2 chip-ID: 1b80:e104
Screen-1: 0 s-res: 5120x2880 s-dpi: 96 s-size: 1354x762mm (53.31x30.00")
s-diag: 1554mm (61.17")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,bottom-l
model: Samsung C49RG9x serial: <filter> built: 2018 res: 5120x1440 hz: 120
dpi: 109 gamma: 1.2 size: 1190x340mm (46.85x13.39") diag: 1239mm (48.8")
modes: max: 5120x1440 min: 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: top-right
model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2015 res: 3440x1440
hz: 60 dpi: 109 gamma: 1.2 size: 800x335mm (31.5x13.19")
diag: 867mm (34.1") modes: max: 3440x1440 min: 640x480
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 13.0.1 DRM 3.44
5.17.5-zen1-2-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:ab38
bus-ID: 10:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Afatech NarviCapture U3 HD60 4K Device type: USB
Sound Server-1: ALSA v: k5.17.5-zen1-2-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 06:00.0 chip-ID: 1d6a:11b1
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
bus-ID: 1-6:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 4.55 TiB used: 1.7 TiB (37.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 97.17 GiB size: 97.17 GiB (100.00%)
used: 69.36 GiB (71.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 500.7 MiB size: 499.7 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 97.17 GiB size: 97.17 GiB (100.00%)
ID-4: /var/log raw-size: 97.17 GiB size: 97.17 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.17 GiB size: 97.17 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.78 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 56.0 C mobo: 39.0 C gpu: amdgpu temp: 64.0 C
mem: 66.0 C
Fan Speeds (RPM): cpu: 990 gpu: amdgpu fan: 0
Processes: 640 Uptime: 23m wakeups: 0 Memory: 62.78 GiB
used: 7.23 GiB (11.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1641 lib: 405 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.3-2):
System install date: 2022-03-17
Last full system update: 2022-05-19 ↻
If booting an old snapshot does not clear this issue, it is not likely a software problem IMHO.
I suggest you investigate and confirm your hardware state. It’s a desktop, so open the box and reseat what can be loose (RAM, disk cables, other cables…). Let CPU sink for last.
If you are lucky, it could be BIOS got stuck and could be reset IAW vendor’s user manual.
I think you need to update your BIOS!
Since you are running Windows, you may as well just run the software they designed for taking care of it for you: https://www.ami.com/resources/support-other/
I've never used it but I'm guessing it's a simple wizard.
I updated the bios and it didn't solve the problem, but then i logged in to a snapshot from beginning of April and i was able to recover from the sleep no problem.
So it seems something between 04/05 state and today got changed that is causing this....
i tired to make sure to retain the working snapshot through btrf assistant, but couldn't find the way of doing that... Also tried to review diff of the snapshot using snapshot browser and pressing the view diff button doesn't do anything...
╰─λ garuda-inxi
parameters: BOOT_IMAGE=/@/.snapshots/82/snapshot/boot/vmlinuz-linux-zen
root=UUID=cfa490e8-fc51-4b99-b39e-9e21021d7ed1 quiet quiet splash
rootflags=defaults,noatime,autodefrag,compress=zstd,discard=async,ssd,subvol=@/.snapshots/82/snapshot
serial: <superuser required> UEFI: American Megatrends v: 4201
date: 04/26/2022
Speed (MHz): avg: 3582 high: 3860 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3585 2: 3598
3: 3590 4: 3585 5: 3589 6: 3583 7: 3593 8: 3593 9: 3591 10: 3595 11: 3587
12: 3591 13: 3600 14: 3549 15: 3587 16: 3601 17: 3591 18: 3586 19: 3595
20: 3591 21: 3593 22: 3589 23: 3592 24: 3151 25: 3860 26: 3582 27: 3595
28: 3590 29: 3555 30: 3584 31: 3589 32: 3594 bogomips: 223573
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
5.17.1-zen1-1-zen)
v: 4.6 Mesa 22.0.1 direct render: Yes
bus-ID: 1-6:8 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 4.55 TiB used: 1.7 TiB (37.4%)
temp: 40.9 C scheme: GPT
ID-1: /boot/efi raw-size: 500.7 MiB size: 499.7 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /home raw-size: 97.17 GiB size: 97.17 GiB (100.00%)
used: 70.77 GiB (72.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /var/log raw-size: 97.17 GiB size: 97.17 GiB (100.00%)
ID-4: /var/tmp raw-size: 97.17 GiB size: 97.17 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.77 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C mobo: 35.0 C gpu: amdgpu temp: 51.0 C
mem: 54.0 C
Fan Speeds (RPM): cpu: 1133 gpu: amdgpu fan: 0
Processes: 794 Uptime: 3m wakeups: 7 Memory: 62.77 GiB
used: 7.05 GiB (11.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1576 lib: 399 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.8-1):
Last full system update: 2022-04-05
You have not restored the snapshot yet. You should restore it properly, as Garuda wiki suggests.
Your system is in a peculliar state now, like sailing up in the air (no root )
On topic, it might be a good idea to create and use a swap partition, or swapfile.
I would wait for some advice from a Garuda dev on this and if or how to do it properly.
This by itself can be or become a problem. You need ALSA backend, but I would use either PulseAudio or Pipewire as the frontend, but not both. I’m somewhat surprised not to recall a problem post regarding this, from this user.
regards
Hello!
I have been travelling for few days - couldn’t respond here…
So i applied the solution from thread here to disable pipewire
Garuda Linux comes with Garuda Assistant. You can restore the use of PulseAudio and Jack and disable Pipewire there.
There is no need to deal with the command line, as the devs provides a much better GUI frontend.
I’m not sure how to prevent it from starting on startup though.
Tested the sleep problem - didn’t help.
windows 11 upgrade blew away grub to a point i couldn't restore it. So i went to reinstall the system from scratch - i will monitor the monitor power off an d sleep behavior and provide update.
Which alternate kernels have you tested?
I would recommend testing the linux-mainline kernel and perhaps a few others.
Hi @tbg ,
I didn't test alternative kernels as all this was happening with one default kernel version. As of right now i have tested a couple scenarios and i can't reproduce the problem anymore.
That is: the solution was to reinstall the system from scratch and then update it, and this seems to have resolved the issue for now. That means that the problem itself is not really resolved as i couldn't get to the root cause of it... I'm not sure if "reinstall from scratch" should be considered the answer to this;)
Currently it was able to recover after long sleep overnight, and also i was able to recover from forced sleep.
SGS
Closed
1 June 2022 17:59
11
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
