System hangs before loging after update
Hi all. The issue is that after each successful update, I am not able to reach the logging screen after reboot: the system will get stuck on either a black screen, the last log message from before shut down or a random-pixel screen. I’m on Garuda Mokka.
I’ve been trying to update for the past three weeks, and is only until now that I come for aid; work has not allowed me to look into this until now, so everytime I would just go back to the last working snapshot (from which I’m writing now).
After the last update today, the system was working fine; I worked a bit just to observe if any weird behavior was noticeable (it was not). I rebooted to get stuck again before the login screen (with a black screen displayin the reboot log message).
Things I’ve tried:
  1. Computer doesn’t boot, boots to a black screen, or stops at a message
  2. Made sure that Secure Boot and Fast Boot are disabled in BIOS settings (did a recent firmware update).
  3. Booted using LTS kernel (with fallback initramfs)
garuda-inxi before update
  Kernel: 6.17.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=543c6354-5d39-4703-bb64-407600dc772d rw rootflags=subvol=@
    quiet rd.udev.log_priority=3 vt.global_cursor_default=0
    resume=UUID=65b1555e-e8e7-41cb-84a2-63265cdbd7db loglevel=3 threadirqs
    sysrq_always_enabled=1
    wm: kwin_wayland with: krunner vt: 2 dm: SDDM Distro: Garuda
  Mobo: ASUSTeK model: TUF GAMING B550M-PLUS (WI-FI) v: Rev X.0x
    UEFI: American Megatrends v: 3621 date: 01/13/2025
  Device-1: hidpp_battery_2 model: Logitech Wireless Mouse M325
  Device-2: hidpp_battery_3 model: Logitech MX Keys Wireless Keyboard
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201030
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 4205 min/max: 636/5282 boost: disabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 4205 2: 4205 3: 4205
    4: 4205 5: 4205 6: 4205 7: 4205 8: 4205 9: 4205 10: 4205 11: 4205 12: 4205
    bogomips: 100806
  Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia
    v: 580.95.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-08; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
    ports: active: HDMI-A-1 empty: DVI-D-1 bus-ID: 08:00.0 chip-ID: 10de:1d01
  Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
    chip-ID: 046d:08e5 class-ID: 0102
  Monitor-1: HDMI-A-1 model: BenQ GW2780 serial: <filter> built: 2021 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
    max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
    memory: 1.95 GiB display-ID: :0.0
  API: Vulkan v: 1.4.328 layers: 7 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GT 1030 driver: nvidia v: 580.95.05
    device-ID: 10de:1d01 surfaces: N/A device: 1 type: cpu name: llvmpipe
    (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.4-arch1.1 (LLVM
  Device-1: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
    bus-ID: 08:00.1 chip-ID: 10de:0fb8 class-ID: 0403
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Yamaha Steinberg UR22 driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:8 chip-ID: 0499:1509
    class-ID: ff00
  Device-4: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.17.1-zen1-1-zen status: kernel-api with: aoss
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0029
  Local Storage: total: 2.05 TiB used: 1000.26 GiB (47.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
    Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QJXD7
    temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Seagate
    model: WDS250G3X0C-00SJG0 size: 232.89 GiB block-size: physical: 512 B
    fw-rev: 111110WD temp: 39.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 1053 scheme: MBR
  ID-1: / raw-size: 922.51 GiB size: 922.51 GiB (100.00%)
    used: 186.91 GiB (20.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:4
    used: 336 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 922.51 GiB size: 922.51 GiB (100.00%)
  ID-4: /var/log raw-size: 922.51 GiB size: 922.51 GiB (100.00%)
  ID-5: /var/tmp raw-size: 922.51 GiB size: 922.51 GiB (100.00%)
  Kernel: swappiness: 180 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 31.25 GiB used: 4.7 MiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
  System Temperatures: cpu: 37.0 C mobo: 37.0 C
  Fan Speeds (rpm): fan-1: 1028 fan-2: 1339 fan-3: 1061 fan-7: 0
  Memory: total: 32 GiB available: 31.25 GiB used: 5.97 GiB (19.1%)
  Processes: 450 Power: uptime: 18m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 258 default: graphical tool: systemctl
  Packages: 2569 pm: guix-sys pkgs: 0 pm: guix-usr pkgs: 5 pm: nix-default
    pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 261 libs: 24 pm: pacman
    pkgs: 2303 libs: 457 tools: aura,paru Compilers: clang: 20.1.8 gcc: 15.2.1
    Shell: Bash v: 5.3.3 default: fish v: 4.1.2 running-in: yakuake
    inxi: 3.3.39
Garuda (2.11.1-1):
  System install date:     2023-02-14
  Last full system update: 2025-10-14
  Is partially upgraded:   Yes
  Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-dkms garuda-hardware-profile-nvidia-closed garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
23/24 checks run in 5.67 seconds ⌛
Powered by garuda-health 🦅
--- CRITICAL ---
 - System is partially upgraded (fix available)
--- HIGH ---
 - System is outdated (last update more than 2 weeks ago) (fix available)
--- LOW ---
jctl output before update
nov 08 08:25:18 Xolotl kernel:
nov 08 08:25:20 Xolotl systemd[1]: NetworkManager-initrd.service: Two services allocated for the same bus name org.freedesktop.NetworkManager, refusing operation.
nov 08 08:25:20 Xolotl (udev-worker)[938]: host7: /usr/lib/udev/rules.d/50-sata.rules:2 ATTR{link_power_management_policy}="max_performance": Could not chase sysfs attribute "/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-7/1-7.1/1-7.1:1.0/host7/scsi_host/host7/link_power_management_policy", ignoring: No such file or directory
nov 08 08:25:20 Xolotl (udev-worker)[936]: host6: /usr/lib/udev/rules.d/50-sata.rules:2 ATTR{link_power_management_policy}="max_performance": Could not chase sysfs attribute "/sys/devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb4/4-2/4-2:1.0/host6/scsi_host/host6/link_power_management_policy", ignoring: No such file or directory
nov 08 08:25:21 Xolotl (udev-worker)[934]: host7: /usr/lib/udev/rules.d/50-sata.rules:2 ATTR{link_power_management_policy}="max_performance": Could not chase sysfs attribute "/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-7/1-7.1/1-7.1:1.0/host7/scsi_host/host7/link_power_management_policy", ignoring: No such file or directory
nov 08 08:25:22 Xolotl bluetoothd[1172]: Failed to set mode: Failed (0x03)
nov 08 08:25:32 Xolotl sddm-helper[8217]: gkr-pam: unable to locate daemon control file
nov 08 08:25:34 Xolotl plasmashell[8427]: Couldn't find QML Decoration  ""
nov 08 08:25:34 Xolotl org_kde_powerdevil[8456]: [  8456] busno=1, All features that should not exist detected. Monitor does not indicate unsupported
nov 08 08:30:33 Xolotl sudo[71128]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 08:30:36 Xolotl sudo[71191]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 08:38:58 Xolotl sudo[165355]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 08:43:23 Xolotl sudo[211670]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 08:53:29 Xolotl sudo[324297]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 08:54:32 Xolotl sudo[332787]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 08:54:39 Xolotl sudo[337034]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
Post-transaction hooks
( 1/46) Restoring Linux kernel modules...
++ uname -r
+ KVER=6.17.1-zen1-1-zen
+ test -e /usr/lib/modules/backup/6.17.1-zen1-1-zen
+ rsync -AHXal --ignore-existing /usr/lib/modules/backup/6.17.1-zen1-1-zen /usr/lib/modules/
+ rm -rf /usr/lib/modules/backup
( 2/46) Adding Garuda specific configurations...
( 3/46) Creating system user accounts...
Creating group 'pcscd' with GID 928.
Creating user 'pcscd' (PC/SC Smart Card Daemon) with UID 928 and GID 928.
( 4/46) Registering binary formats...
( 5/46) Updating journal message catalog...
( 6/46) Reloading system manager configuration...
( 7/46) Reloading user manager configuration...
( 8/46) Updating udev hardware database...
( 9/46) Restarting marked services...
(10/46) Applying kernel sysctl settings...
(11/46) Creating temporary files...
(12/46) Reloading device manager configuration...
(13/46) Arming ConditionNeedsUpdate...
(14/46) Updating the MIME type database...
(15/46) Updating module dependencies...
(16/46) Install DKMS modules
==> dkms install --no-depmod nvidia/580.95.05 -k 6.12.57-1-lts
==> dkms install --no-depmod nvidia/580.95.05 -k 6.17.7-zen1-1-zen
==> depmod 6.12.57-1-lts
==> depmod 6.17.7-zen1-1-zen
(17/46) Updating TeXLive filename database...
(18/46) Restart a running sshd.service
(19/46) Checking for package with missing dependencies...
(20/46) Updating ConTeXt database...
(21/46) Updating initramfs with dracut
:: Rebuilding all initramfs due to changes in dracut files.
:: Building initramfs for linux-lts (6.12.57-1-lts)
:: Building fallback initramfs for linux-lts (6.12.57-1-lts)
:: Building initramfs for linux-zen (6.17.7-zen1-1-zen)
:: Building fallback initramfs for linux-zen (6.17.7-zen1-1-zen)
(22/46) Updating linux initcpios...
(23/46) Foreign/AUR package notification
abcm2ps 8.14.15-1
agordejo 0.4.2-2
appimagelauncher 3.0.0_beta_1-1
aura-bin 4.0.8-1
briss 0.9-6
coursier 2.1.24-1
dict-freedict-eng-spa-bin 2024.10.10-1
dict-freedict-spa-eng-bin 0.3.1-2
emacs-lsp-booster 0.2.1-1
enpass-bin 6.11.12.1953-1
exodus 25.40.6-1
extempore-bin 0.8.9-1
garuda-hotfixes 1.1.2-1
gtk2 2.24.33-5
gtkmm 1:2.24.5-5
hexchat 2.16.2-5
js-beautify 1.15.4-2
kdoctools5 5.116.0-2
lockdown-ms 20130326-4
mit-scheme 12.1-9
nodejs-http-server 14.1.1-1
ormolu-bin 0.8.0.0-1
otf-hasklig 1.2-1
pdfsam 5.4.0-1
python-deadlib 3.13.0-2
python-grip-git 4.6.2.r586.a3f0ab5-1
python-path-and-address-git 2.0.1.r46.f8193a0-1
realtime-suggestions 0.1.0-1
reiserfsprogs 3.6.27-5
renoise-demo 3.5.2-1
rmtrash 1.15-2
rtapp 1.1-1
rtcqs 0.6.7-1
scalafmt 3.9.9-1
ttf-hasklig 1.2-1
vim-markdown-toc 1.4.0-1
(24/46) Updating grub binary in EFI
Found theme: /usr/share/grub/themes/catppuccin-mocha/theme.txt
Found initrd image: /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  initramfs-linux-zen-fallback.img
Found linux image: /boot/vmlinuz-linux-lts
Found initrd image: /boot/initramfs-linux-lts.img
Found fallback initrd image(s) in /boot:  initramfs-linux-lts-fallback.img
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2025-11-08 09:14:37 | @/.snapshots/18/snapshot   | pre    | pacman -Su                                                               |
Found snapshot: 2025-11-03 10:24:55 | @/.snapshots/17/snapshot   | post   | alacritty alsa-card-profiles alsa-lib amd-ucode ananicy-cpp appmenu-gtk- |
Found snapshot: 2025-11-03 10:19:27 | @/.snapshots/16/snapshot   | pre    | pacman -Su                                                               |
Found snapshot: 2025-10-28 17:37:11 | @_backup_20250311113814826 | N/A    | N/A        |
Found snapshot: 2025-10-28 17:29:45 | @/.snapshots/15/snapshot   | post   | appimagelauncher patchelf                                                |
Found snapshot: 2025-10-28 17:29:36 | @/.snapshots/14/snapshot   | pre    | pacman -Rns appimagelauncher                                             |
Found snapshot: 2025-10-28 17:20:26 | @/.snapshots/13/snapshot   | post   | alacritty alsa-card-profiles alsa-lib amd-ucode ananicy-cpp appmenu-gtk- |
Found snapshot: 2025-10-28 17:15:24 | @/.snapshots/12/snapshot   | pre    | pacman -Su                                                               |
Found snapshot: 2025-10-27 19:41:57 | @/.snapshots/11/snapshot   | post   | emacs-lsp-booster                                                        |
Found snapshot: 2025-10-27 19:41:54 | @/.snapshots/10/snapshot   | pre    | pacman -U /home/xavigo/.cache/aura/cache/emacs-lsp-booster-0.2.1-1-x86_6 |
Found snapshot: 2025-10-18 16:05:08 | @_backup_20252810173710881 | N/A    | N/A        |
Found snapshot: 2025-10-18 15:20:16 | @/.snapshots/9/snapshot    | post   | alacritty alsa-card-profiles amd-ucode at-spi2-core attica aws-c-io aws- |
Found snapshot: 2025-10-18 15:16:08 | @/.snapshots/8/snapshot    | pre    | pacman -Su                                                               |
Found snapshot: 2025-10-10 10:01:53 | @/.snapshots/1/snapshot    | single | After mess                                                               |
Found snapshot: 2025-02-13 19:24:24 | @_backup_20251810160508489 | N/A    | N/A        |
Found 15 snapshot(s)
Unmount /tmp/grub-btrfs.VoUaTgEoxG .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
The GRUB bootloader at EFI/Garuda is being updated!
Installing for x86_64-efi platform.
Installation finished. No error reported.
(25/46) Orphaned package notification...
find-the-command-git 2.0.1.r0.gfecba1a-1.1
gtkmm 1:2.24.5-5
qca-qt5 2.3.10-4
qt6-wayland 6.10.0-1
(26/46) Checking for .pacnew and .pacsave files...
.pac* files found:
Please check and merge
(27/46) 99-pkg-backup.hook
(28/46) GRUB update after transactions...
Unmount /tmp/grub-btrfs.8LvNtwQmww .. Success
done
(29/46) Reloading system bus configuration...
(30/46) Checking for old perl modules...
(31/46) Updating fontconfig cache...
(32/46) Updating 32-bit fontconfig cache...
(33/46) Updating Garuda specific hooks...
(34/46) Probing GDK-Pixbuf loader modules...
(35/46) Probing 32-bit GDK-Pixbuf loader modules...
(36/46) Compiling GSettings XML schema files...
(37/46) Fix 'grub' and 'os-prober' after upgrading either of them....
(38/46) Updating icon theme caches...
(39/46) Checking which packages need to be rebuilt
(40/46) Updating the info directory file...
(41/46) Copy Thunderbird Distribution Settings
(42/46) Updating the desktop file MIME type cache...
(43/46) Updating the vlc plugin cache...
(44/46) Updating Vim help tags...
(45/46) Performing snapper post snapshots for the following configurations...
==> root: 19
(46/46) Syncing all file systems...
checking dependencies...
Package (1)      Old Version  Net Change
garuda-hotfixes  1.1.2-1        0.00 MiB
:: Do you want to remove these packages? [Y/n]
snapper snapshots skipped
removing garuda-hotfixes...
(1/6) Foreign/AUR package notification
abcm2ps 8.14.15-1
agordejo 0.4.2-2
aura-bin 4.0.8-1
briss 0.9-6
coursier 2.1.24-1
exodus 25.40.6-1
gtk2 2.24.33-5
gtkmm 1:2.24.5-5
hexchat 2.16.2-5
mit-scheme 12.1-9
otf-hasklig 1.2-1
pdfsam 5.4.0-1
rmtrash 1.15-2
rtapp 1.1-1
rtcqs 0.6.7-1
scalafmt 3.9.9-1
ttf-hasklig 1.2-1
(2/6) Orphaned package notification...
gtkmm 1:2.24.5-5
qca-qt5 2.3.10-4
(3/6) Checking for .pacnew and .pacsave files...
.pac* files found:
(4/6) 99-pkg-backup.hook
(5/6) Performing snapper post snapshots for the following configurations...
(6/6) Syncing all file systems...
System updated! 🐧
Update notices:
The GRUB bootloader at /EFI/Garuda has been updated/reinstalled using 'grub-install'. If this looks correct, no further action has to be taken.
25/25 checks run in 1.13 seconds ⌛
--- LOW ---
--- INFO ---
Do not forget to read the update notices above the garuda-health output!
jctl after upgrade
nov 08 08:55:59 Xolotl sudo[349731]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:07:13 Xolotl sudo[472813]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:07:33 Xolotl sudo[473924]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:08:23 Xolotl sudo[485581]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:08:33 Xolotl sudo[485698]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:08:36 Xolotl sudo[485755]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:08:53 Xolotl sudo[489677]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:13:04 Xolotl sudo[529825]:   xavigo : a password is required ; TTY=pts/3 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:19:20 Xolotl systemd[1316]: Failed to start Rebuilds bat cache.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 794 and the job result is failed.
nov 08 09:19:21 Xolotl sudo[583422]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:21:33 Xolotl sudo[583658]:   xavigo : a password is required ; TTY=pts/0 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:21:47 Xolotl sudo[583782]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
nov 08 09:22:48 Xolotl sudo[583899]:   xavigo : a password is required ; TTY=pts/1 ; PWD=/home/xavigo ; USER=root ; COMMAND=/usr/bin/true
Packages to update (a tsunami of them)
alacritty 0.15.1-1 -> 0.16.1-1
alsa-card-profiles 1:1.4.8-2 -> 1:1.4.9-1
alsa-lib 1.2.14-1 -> 1.2.14-2
amd-ucode 20250917-1 -> 20251021-1
ananicy-cpp 1.1.1-8 -> 1.1.1-9
android-tools 35.0.2-21 -> 35.0.2-22
appmenu-gtk-module 25.04-1 -> 25.04-2
arch-wiki-docs 20250801-1 -> 20251102-1
ark 25.08.2-1 -> 25.08.3-1
at-spi2-core 2.58.0-1 -> 2.58.1-1
attica 6.18.0-1 -> 6.19.0-1
audit 4.0.5-1 -> 4.1.2-1
aurorae 6.4.5-1 -> 6.5.2-1
aws-c-cal 0.9.3-1 -> 0.9.8-1
aws-c-http 0.10.4-1 -> 0.10.7-1
aws-c-io 0.22.1-1 -> 0.23.2-1
aws-c-s3 0.9.1-1 -> 0.9.2-1
aws-crt-cpp 0.34.5-1 -> 0.35.2-1
aws-sdk-cpp-core 1.11.662-1 -> 1.11.681-1
aws-sdk-cpp-iam 1.11.662-1 -> 1.11.681-1
aws-sdk-cpp-s3 1.11.662-1 -> 1.11.681-1
baloo 6.18.0-1 -> 6.19.0-1
baloo-widgets 25.08.2-1 -> 25.08.3-1
bash-completion 2.16.0-1 -> 2.17.0-1
bat 0.25.0-4 -> 0.26.0-1
beautyline 1:20250720-1 -> 2:3.0.3-1
bind 9.20.13-1 -> 9.20.15-1
bluedevil 1:6.4.5-1 -> 1:6.5.2-1
bluez-qt 6.18.0-1 -> 6.19.0-1
boost-libs 1.88.0-3 -> 1.89.0-2
botan 3.9.0-1 -> 3.10.0-1
brave-bin 1:1.83.112-1 -> 1:1.84.135-1
breeze 6.4.5-1 -> 6.5.2-1
breeze-icons 6.18.0-1 -> 6.19.0-1
breeze5 6.4.5-1 -> 6.5.2-1
breezy 3.3.13-1 -> 3.3.15-1
btrfs-assistant 2.2-3 -> 2.2-4
cachyos-ananicy-rules-git 20250909.r575.g0f5d788-1 -> 20251106.r621.gb20501f-1
calf 0.90.8-4 -> 0.90.8-5
candy-icons-git r1332.278998c-1 -> r1346.1be42f2-1
chaotic-mirrorlist 20240724-3 -> 20251025-1
clang 20.1.8-2 -> 21.1.5-1
clazy 1.16-1 -> 1.16-2
compiler-rt 20.1.8-1 -> 21.1.5-1
curl 8.16.0-1 -> 8.17.0-1
dav1d 1.5.1-1 -> 1.5.2-1
db 6.2.32-1 -> 6.2.32-3
device-mapper 2.03.35-1 -> 2.03.36-2
dkms 3.2.2-1 -> 3.3.0-1
dolphin 25.08.2-1 -> 25.08.3-1
dolphin-plugins 25.08.2-1 -> 25.08.3-1
dracut 108-1 -> 109-1
eclib 20250627-1 -> 20250627-3
electron38 38.1.2-1 -> 38.6.0-1
element-desktop 1.12.0-1 -> 1.12.3-1
element-web 1.12.0-1 -> 1.12.3-1
elfutils 0.193-5 -> 0.194-1
eq10q 2.2-7 -> 2.2-8
exfatprogs 1.2.9-1 -> 1.3.0-1
faust 2.81.10-1 -> 2.81.10-3
ffmpegthumbs 25.08.2-1 -> 25.08.3-1
filelight 25.08.2-1 -> 25.08.3-1
filesystem 2025.05.03-1 -> 2025.10.12-1
fio 3.39-1 -> 3.41-1
firedragon-catppuccin 1:12.5.0.1-1 -> 1:12.5.1-1
fluidsynth 2.5.0-2 -> 2.5.0-3
fmt 12.0.0-1 -> 12.1.0-1
frameworkintegration 6.18.0-2 -> 6.19.0-1
frei0r-plugins 2.4.0-1 -> 2.5.0-1
fuse-common 3.17.1-1 -> 3.17.4-1
fuse3 3.17.1-1 -> 3.17.4-1
fwupd 2.0.16-1 -> 2.0.17-1
fzf 0.65.2-1 -> 0.66.1-1
gap 4.15.0-3 -> 4.15.1-1
garuda-bash-config 1.0.7-1 -> 1.0.8-1
garuda-boot-options 1.1.0-2 -> 1.1.2-2
garuda-dracut-support 1.6.0-1 -> 1.6.0-2
garuda-fish-config 1.5.24-2 -> 1.5.25-1
garuda-hardware-tool 1.0.4-1 -> 1.1.0-1
garuda-health 1.8.1-1 -> 1.9.0-1
garuda-hooks 2.15.1-1 -> 2.15.2-1
garuda-libs 1.7.1-1 -> 1.9.0-1
garuda-mokka 1.2.3-5 -> 1.2.4-5
garuda-network-assistant 1.2.1-2 -> 1.2.2-2
garuda-rani 3.3.1-1 -> 3.5.1-1
garuda-setup-assistant 4.3.0-1 -> 4.4.1-1
garuda-system-maintenance 3.0.2-1.1 -> 3.1.0-2
gc 8.2.8-2 -> 8.2.10-2
gdk-pixbuf2 2.44.3-1 -> 2.44.4-1
git 2.51.0-1 -> 2.51.2-2
github-cli 2.81.0-1 -> 2.83.0-1
glib2 2.86.0-2 -> 2.86.1-1
glycin 2.0.3-1 -> 2.0.5-1
gnome-firmware 47.0-2 -> 49.0-1
gnupg 2.4.8-1 -> 2.4.8-3
grub 2:2.12.r359.g19c698d12-1.1 -> 2:2.14rc1-2
gsettings-desktop-schemas 49.0-1 -> 49.1-1
gsettings-system-schemas 49.0-1 -> 49.1-1
gst-libav 1.26.6-3 -> 1.26.7-1
gst-plugin-pipewire 1:1.4.8-2 -> 1:1.4.9-1
gst-plugin-qml6 1.26.6-3 -> 1.26.7-1
gst-plugins-bad 1.26.6-3 -> 1.26.7-1
gst-plugins-bad-libs 1.26.6-3 -> 1.26.7-1
gst-plugins-base 1.26.6-3 -> 1.26.7-1
gst-plugins-base-libs 1.26.6-3 -> 1.26.7-1
gst-plugins-good 1.26.6-3 -> 1.26.7-1
gst-plugins-ugly 1.26.6-3 -> 1.26.7-1
gstreamer 1.26.6-3 -> 1.26.7-1
gstreamer-vaapi 1.26.6-3 -> 1.26.7-1
guitarix 0.47.0-1 -> 0.47.0-2
harfbuzz 12.1.0-1 -> 12.2.0-1
harfbuzz-icu 12.1.0-1 -> 12.2.0-1
hwdata 0.400-1 -> 0.401-1
iana-etc 20250612-1 -> 20251030-1
imagemagick 7.1.2.5-1 -> 7.1.2.8-1
imath 3.2.2-1 -> 3.2.2-2
inkscape 1.4.2-8 -> 1.4.2-10
intel-gmmlib 22.8.1-1 -> 22.8.2-1
ipython 9.5.0-1 -> 9.7.0-1
jdk21-openjdk 21.0.8.u9-1 -> 21.0.9.u10-1
jre-openjdk 25.u36-1 -> 25.0.1.u8-1
jre8-openjdk 8.462.u08-1 -> 8.472.u08-1
jre8-openjdk-headless 8.462.u08-1 -> 8.472.u08-1
jupyterlab 4.4.9-1 -> 4.4.10-1
kaccounts-integration 25.08.2-1 -> 25.08.3-1
kactivitymanagerd 6.4.5-1 -> 6.5.2-1
kamoso 25.08.2-1 -> 25.08.3-1
karchive 6.18.0-1 -> 6.19.0-1
karchive5 5.116.0-1 -> 5.116.0-2
kasts 25.08.2-1 -> 25.08.3-1
kate 25.08.2-1 -> 25.08.3-1
kauth 6.18.0-1 -> 6.19.0-1
kauth5 5.116.0-1 -> 5.116.0-2
kbookmarks 6.18.0-1 -> 6.19.0-1
kbookmarks5 5.116.0-1 -> 5.116.0-2
kcmutils 6.18.0-1 -> 6.19.0-1
kcodecs 6.18.0-1 -> 6.19.0-1
kcodecs5 5.116.0-1 -> 5.116.0-2
kcolorscheme 6.18.0-1 -> 6.19.0-1
kcompletion 6.18.0-1 -> 6.19.0-1
kcompletion5 5.116.0-1 -> 5.116.0-2
kconfig 6.18.0-1 -> 6.19.0-1
kconfig5 5.116.0-1 -> 5.116.0-2
kconfigwidgets 6.18.0-1 -> 6.19.0-1
kconfigwidgets5 5.116.0-1 -> 5.116.0-3
kcontacts 1:6.18.0-1 -> 1:6.19.0-1
kcoreaddons 6.18.0-2 -> 6.19.0-1
kcoreaddons5 5.116.0-1 -> 5.116.0-2
kcrash 6.18.0-1 -> 6.19.0-1
kcrash5 5.116.0-1 -> 5.116.0-2
kdbusaddons 6.18.0-1 -> 6.19.0-1
kdbusaddons5 5.116.0-1 -> 5.116.0-2
kde-cli-tools 6.4.5-1 -> 6.5.2-1
kde-gtk-config 6.4.5-2 -> 6.5.2-1
kdeclarative 6.18.0-1 -> 6.19.0-1
kdeconnect 25.08.2-2 -> 25.08.3-1
kdecoration 6.4.5-1 -> 6.5.2-1
kded 6.18.0-1 -> 6.19.0-1
kded5 5.116.0-1 -> 5.116.0-2
kdegraphics-mobipocket 25.08.2-1 -> 25.08.3-1
kdegraphics-thumbnailers 25.08.2-1 -> 25.08.3-1
kdenlive 25.08.2-1 -> 25.08.3-2
kdeplasma-addons 6.4.5-1 -> 6.5.2-1
kdesu 6.18.0-1 -> 6.19.0-1
kdf 25.08.2-1 -> 25.08.3-1
kdialog 25.08.2-1 -> 25.08.3-1
kdnssd 6.18.0-1 -> 6.19.0-1
kdsoap-ws-discovery-client 0.4.0-1 -> 0.4.0-2
kfilemetadata 6.18.0-2 -> 6.19.0-1
kglobalaccel 6.18.0-1 -> 6.19.0-1
kglobalaccel5 5.116.0-1 -> 5.116.0-2
kglobalacceld 6.4.5-1 -> 6.5.2-1
kguiaddons 6.18.0-3 -> 6.19.0-1
kguiaddons5 5.116.0-1 -> 5.116.0-2
kholidays 1:6.18.0-1 -> 1:6.19.0-1
ki18n 6.18.0-1 -> 6.19.0-1
ki18n5 5.116.0-1 -> 5.116.0-2
kiconthemes 6.18.0-1 -> 6.19.0-1
kiconthemes5 5.116.0-1 -> 5.116.0-2
kidletime 6.18.0-2 -> 6.19.0-1
kinfocenter 6.4.5-1 -> 6.5.2-1
kio 6.18.0-1 -> 6.19.0-2
kio-extras 25.08.2-1 -> 25.08.3-1
kio-fuse 5.1.0-5 -> 5.1.1-1
kio5 5.116.0-2 -> 5.116.0-5
kirigami 6.18.0-1 -> 6.19.0-1
kirigami2 5.116.0-1 -> 5.116.0-2
kitemmodels 6.18.0-1 -> 6.19.0-1
kitemviews 6.18.0-1 -> 6.19.0-1
kitemviews5 5.116.0-1 -> 5.116.0-2
kitty 0.43.1-1 -> 0.44.0-1
kitty-shell-integration 0.43.1-1 -> 0.44.0-1
kitty-terminfo 0.43.1-1 -> 0.44.0-1
kjobwidgets 6.18.0-2 -> 6.19.0-1
kjobwidgets5 5.116.0-1 -> 5.116.0-2
kmenuedit 6.4.5-1 -> 6.5.2-1
knewstuff 6.18.0-1 -> 6.19.0-1
knotifications 6.18.0-2 -> 6.19.0-1
knotifications5 5.116.0-2 -> 5.116.0-3
knotifyconfig 6.18.0-1 -> 6.19.0-1
kompare 25.08.2-1 -> 25.08.3-1
konsole 25.08.2-1 -> 25.08.3-1
kpackage 6.18.0-1 -> 6.19.0-1
kparts 6.18.0-1 -> 6.19.0-1
kpeople 6.18.0-1 -> 6.19.0-1
kpipewire 6.4.5-2 -> 6.5.2-1
kpty 6.18.0-1 -> 6.19.0-1
kquickcharts 6.18.0-1 -> 6.19.0-1
krunner 6.18.0-1 -> 6.19.0-1
kscreen 6.4.5-2 -> 6.5.2-1
kscreenlocker 6.4.5-1 -> 6.5.2-1
kservice 6.18.0-1 -> 6.19.0-1
kservice5 5.116.0-1 -> 5.116.0-3
kstatusnotifieritem 6.18.0-2 -> 6.19.0-1
ksvg 6.18.0-1 -> 6.19.0-1
ksystemstats 6.4.5-1 -> 6.5.2-1
ktexteditor 6.18.0-1 -> 6.19.0-1
ktextwidgets 6.18.0-1 -> 6.19.0-1
ktextwidgets5 5.116.0-1 -> 5.116.0-2
kunitconversion 6.18.0-2 -> 6.19.0-1
kuserfeedback 6.18.0-1 -> 6.19.0-1
kwallet 6.18.0-1 -> 6.19.0-1
kwallet-pam 6.4.5-1 -> 6.5.2-1
kwallet5 5.116.0-3 -> 5.116.0-5
kwayland 6.4.5-2 -> 6.5.2-1
kwayland-integration 6.4.5-1 -> 6.5.2-1
kwayland5 5.116.0-1 -> 5.116.0-2
kwidgetsaddons 6.18.0-2 -> 6.19.0-1
kwidgetsaddons5 5.116.0-1 -> 5.116.0-2
kwin 6.4.5-4 -> 6.5.2-1
kwin-effect-rounded-corners-git 0.8.5.r2.gc394ec9-1 -> 0.8.5.r9.g4c5dce7-1.1
kwin-effects-forceblur 1.5.0-1.2 -> 1.5.0-1.6
kwin-scripts-krohnkite-git 0.9.9.2.r24.g4aa9372-1 -> 0.9.9.2.r47.g985c9bd-1
kwin-x11 6.4.5-5 -> 6.5.2-1
kwindowsystem 6.18.0-2 -> 6.19.0-1
kwindowsystem5 5.116.0-1 -> 5.116.0-2
kxmlgui 6.18.0-2 -> 6.19.0-1
kxmlgui5 5.116.0-1 -> 5.116.0-2
layer-shell-qt 6.4.5-4 -> 6.5.2-1
lazygit 0.55.1-1 -> 0.56.0-1
ldb 2:4.23.1-1 -> 2:4.23.3-1
leancrypto 1.5.1-1 -> 1.6.0-1
less 1:679-1 -> 1:685-1
lib32-alsa-lib 1.2.14-1 -> 1.2.14-2
lib32-at-spi2-core 2.58.0-1 -> 2.58.1-1
lib32-audit 4.0.5-1 -> 4.1.2-1
lib32-curl 8.16.0-1 -> 8.17.0-1
lib32-gdk-pixbuf2 2.44.3-1 -> 2.44.4-1
lib32-glib2 2.86.0-2 -> 2.86.1-1
lib32-gst-plugins-base-libs 1.26.6-2 -> 1.26.7-1
lib32-gstreamer 1.26.6-2 -> 1.26.7-1
lib32-harfbuzz 12.1.0-1 -> 12.2.0-1
lib32-libcap 2.76-1 -> 2.77-1
lib32-libdrm 2.4.125-1 -> 2.4.128-1
lib32-libelf 0.193-4 -> 0.194-1
lib32-libgpg-error 1.55-1 -> 1.56-1
lib32-libnghttp2 1.67.1-1 -> 1.68.0-1
lib32-libpipewire 1:1.4.8-2 -> 1:1.4.9-1
lib32-libpulse 17.0+r43+g3e2bb8a1e-1 -> 17.0+r88+geee0e8f22-1
lib32-librsvg 2:2.61.1-1 -> 2:2.61.3-1
lib32-libxcrypt 4.4.38-1 -> 4.5.0-1
lib32-libxkbcommon 1.11.0-1 -> 1.12.3-1
lib32-libxml2 2.15.0-1 -> 2.15.1-1
lib32-llvm-libs 1:20.1.8-1 -> 1:21.1.5-1
lib32-mesa 1:25.2.4-1 -> 1:25.2.6-1
lib32-mpg123 1.33.2-1 -> 1.33.3-1
lib32-pcre2 10.46-1 -> 10.47-1
lib32-pipewire 1:1.4.8-2 -> 1:1.4.9-1
lib32-pipewire-jack 1:1.4.8-2 -> 1:1.4.9-1
lib32-sdl2-compat 2.32.56-1 -> 2.32.58-1
lib32-sdl3 3.2.24-1 -> 3.2.26-1
lib32-spirv-tools 1:1.4.321.0-1 -> 1:1.4.328.1-1
lib32-systemd 258-1 -> 258.1-1
lib32-vulkan-icd-loader 1.4.321.0-1 -> 1.4.328.1-1
lib32-vulkan-intel 1:25.2.4-1 -> 1:25.2.6-1
lib32-vulkan-mesa-device-select 1:25.2.4-1 -> 1:25.2.6-1
lib32-vulkan-mesa-layers 1:25.2.4-1 -> 1:25.2.6-1
lib32-vulkan-radeon 1:25.2.4-1 -> 1:25.2.6-1
libappimage 1.0.4.5-10 -> 1.0.4.5-11
libarchive 3.8.1-1 -> 3.8.2-1
libavif 1.3.0-2 -> 1.3.0-3
libblockdev 3.3.1-1 -> 3.4.0-1
libblockdev-crypto 3.3.1-1 -> 3.4.0-1
libblockdev-fs 3.3.1-1 -> 3.4.0-1
libblockdev-loop 3.3.1-1 -> 3.4.0-1
libblockdev-mdraid 3.3.1-1 -> 3.4.0-1
libblockdev-nvme 3.3.1-1 -> 3.4.0-1
libblockdev-part 3.3.1-1 -> 3.4.0-1
libblockdev-swap 3.3.1-1 -> 3.4.0-1
libcanberra 1:0.30+r2+gc0620e4-4 -> 1:0.30+r2+gc0620e4-6
libcerf 1:3.2-1 -> 1:3.3-1
libcmis 0.6.2-5 -> 0.6.2-6
libdbusmenu-glib 16.04.0.r498-2 -> 18.10.20180917-1
libdbusmenu-gtk3 16.04.0.r498-2 -> 18.10.20180917-1
libdecor 0.2.3-1 -> 0.2.4-1
libdrm 2.4.126-1 -> 2.4.128-1
libdvdnav 6.1.1-2 -> 7.0.0-1
libdvdread 6.1.3-2 -> 7.0.0-1
libelf 0.193-5 -> 0.194-1
libevdev 1.13.4-1 -> 1.13.5-1
libfabric 2.2.0-1 -> 2.3.1-1
libgphoto2 2.5.32-4 -> 2.5.33-1
libheif 1.20.2-2 -> 1.20.2-3
libimobiledevice 1.3.0-17 -> 1.4.0-1
libinput 1.29.1-1 -> 1.29.2-1
libinput-gestures 2.80-1.1 -> 2.80-1.2
libinput-gestures-qt 0.4-1.2 -> 0.4-2
libixion 0.20.0-2 -> 0.20.0-3
libjcat 0.2.3-2 -> 0.2.5-1
libjxl 0.11.1-4 -> 0.11.1-5
libkdcraw 25.08.2-1 -> 25.08.3-1
libkexiv2 25.08.2-1 -> 25.08.3-1
libkomparediff2 25.08.2-1 -> 25.08.3-1
libkscreen 6.4.5-2 -> 6.5.2-1
libksysguard 6.4.5-1 -> 6.5.2-1
liblo 1:0.33-1 -> 1:0.34-1
libluv 1.48.0_2-1 -> 1.51.0-1
libnvme 1.15-1 -> 1.16-2
liborcus 0.21.0-1 -> 0.21.0-2
libplasma 6.4.5-2 -> 6.5.2-1
libqalculate 5.7.0-1 -> 5.8.1-1
libreoffice-fresh 25.8.2-1 -> 25.8.2-4
libsidplayfp 2.15.1-1 -> 2.15.2-1
libsndfile 1.2.2-3 -> 1.2.2-4
libtorrent-rasterbar 1:2.0.11-4 -> 1:2.0.11-5
libunrar 1:7.1.10-1 -> 1:7.2.1-1
libvlc 3.0.21-30 -> 3.0.21-31
libwbclient 2:4.23.1-1 -> 2:4.23.3-1
libwireplumber 0.5.11-1 -> 0.5.12-1
libxkbcommon-x11 1.11.0-1 -> 1.12.3-1
linux-firmware 20250917-1 -> 20251021-1
linux-firmware-amdgpu 20250917-1 -> 20251021-1
linux-firmware-atheros 20250917-1 -> 20251021-1
linux-firmware-broadcom 20250917-1 -> 20251021-1
linux-firmware-cirrus 20250917-1 -> 20251021-1
linux-firmware-intel 20250917-1 -> 20251021-1
linux-firmware-mediatek 20250917-1 -> 20251021-1
linux-firmware-nvidia 20250917-1 -> 20251021-1
linux-firmware-other 20250917-1 -> 20251021-1
linux-firmware-radeon 20250917-1 -> 20251021-1
linux-firmware-realtek 20250917-1 -> 20251021-1
linux-firmware-whence 20250917-1 -> 20251021-1
linux-lts 6.12.51-1 -> 6.12.57-1
linux-lts-headers 6.12.51-1 -> 6.12.57-1
linux-zen 6.17.1.zen1-1 -> 6.17.7.zen1-1
linux-zen-headers 6.17.1.zen1-1 -> 6.17.7.zen1-1
llvm 20.1.8-1 -> 21.1.5-1
llvm-libs 20.1.8-1 -> 21.1.5-1
lowdown 1.4.0-1 -> 2.0.2-1
luajit 2.1.1753364724-1 -> 2.1.1762386122-1
lv2 1.18.10-1 -> 1.18.10-2
lvm2 2.03.35-1 -> 2.03.36-2
lynis 3.1.5-1 -> 3.1.6-1
man-pages 6.15-1 -> 6.16-1
maxima 5.48.1-6 -> 5.48.1-7
maxima-ecl 5.48.1-6 -> 5.48.1-7
maxima-fas 5.48.1-6 -> 5.48.1-7
milou 6.4.5-1 -> 6.5.2-1
mlt 7.32.0-4 -> 7.34.1-1
modemmanager-qt 6.18.0-1 -> 6.19.0-1
neovim 0.11.4-1 -> 0.11.5-1
networkmanager-qt 6.18.0-1 -> 6.19.0-1
nilfs-utils 2.2.11-1 -> 2.2.12-1
nix 2.32.0-1 -> 2.32.3-1
node-gyp 11.4.2-1 -> 11.5.0-1
nodejs-lts-jod 22.19.0-1 -> 22.21.1-1
nomacs 1:3.21.0-2 -> 1:3.21.1-1
noto-fonts 1:2025.10.01-1 -> 1:2025.11.01-1
ntl 11.5.1-2 -> 11.6.0-1
ntp 4.2.8.p18-5 -> 4.2.8.p18-6
nvme-cli 2.15-1 -> 2.16-1
ocean-sound-theme 6.4.5-1 -> 6.5.2-1
octave 10.2.0-2 -> 10.3.0-1
okular 25.08.2-2 -> 25.08.3-1
onetbb 2022.2.0-1 -> 2022.3.0-1
openbsd-netcat 1.229_1-2 -> 1.234_1-1
opencv 4.12.0-10 -> 4.12.0-13
openexr 3.4.1-1 -> 3.4.3-1
openmpi 5.0.8-5 -> 5.0.9-1
openssh 10.0p1-6 -> 10.2p1-2
opentimelineio 0.17.0-3 -> 0.18.0-1
openucx 1.19.0-2 -> 1.19.0-3
openxr 1.1.50-1 -> 1.1.53-1
pacman-mirrorlist 20251003-1 -> 20251021-1
pandoc-bin 3.8.2-1 -> 3.8.2.1-1
parallel 20250922-1 -> 20251022-1
pcsclite 2.3.3-1 -> 2.4.0-3
perl-business-isbn-data 20251003.001-1 -> 20251101.001-1
perl-http-message 7.00-2 -> 7.01-1
perl-libwww 6.80-1 -> 6.81-1
perl-specio 0.52-1 -> 0.53-1
perl-test-fatal 0.017-5 -> 0.018-1
perl-uri 5.32-2 -> 5.34-1
pipewire-alsa 1:1.4.8-2 -> 1:1.4.9-1
pipewire-audio 1:1.4.8-2 -> 1:1.4.9-1
pipewire-docs 1:1.4.8-2 -> 1:1.4.9-1
pipewire-pulse 1:1.4.8-2 -> 1:1.4.9-1
pipewire-v4l2 1:1.4.8-2 -> 1:1.4.9-1
pipewire-x11-bell 1:1.4.8-2 -> 1:1.4.9-1
pipewire-zeroconf 1:1.4.8-2 -> 1:1.4.9-1
planarity 4.0.0.0-1 -> 4.0.1.0-1
plasma-activities 6.4.5-1 -> 6.5.2-1
plasma-activities-stats 6.4.5-1 -> 6.5.2-1
plasma-browser-integration 6.4.5-1 -> 6.5.2-1
plasma-desktop 6.4.5-4 -> 6.5.2-1
plasma-firewall 6.4.5-1 -> 6.5.2-1
plasma-integration 6.4.5-4 -> 6.5.2-1
plasma-nm 6.4.5-1 -> 6.5.2-1
plasma-pa 6.4.5-1 -> 6.5.2-1
plasma-systemmonitor 6.4.5-1 -> 6.5.2-1
plasma-thunderbolt 6.4.5-1 -> 6.5.2-1
plasma-workspace 6.4.5-3 -> 6.5.2-1
plasma-x11-session 6.4.5-3 -> 6.5.2-1
plasma5-integration 6.4.5-4 -> 6.5.2-1
plasma5support 6.4.5-1 -> 6.5.2-1
plasma6-applets-panel-colorizer 5.0.1-1 -> 5.2.1-1
polkit-kde-agent 6.4.5-1 -> 6.5.2-1
poppler 25.09.1-1 -> 25.10.0-1
poppler-glib 25.09.1-1 -> 25.10.0-1
poppler-qt6 25.09.1-1 -> 25.10.0-1
portmidi 1:2.0.6-1 -> 1:2.0.7-1
powerdevil 6.4.5-2 -> 6.5.2-1
primecount 7.19-1 -> 7.20-1
primesieve 12.9-1 -> 12.10-1
prison 6.18.0-1 -> 6.19.0-1
protobuf 32.1-1 -> 33.0-2
protobuf-c 1.5.2-6 -> 1.5.2-7
pulseaudio-qt 1.7.0-1 -> 1.7.0-2
purpose 6.18.0-1 -> 6.19.0-1
python-anyio 4.10.0-1 -> 4.11.0-1
python-apsw 3.49.2.0-1 -> 3.50.4.0-1
python-bleach 6.2.0-2 -> 6.3.0-1
python-cffi 1.17.1-2 -> 2.0.0-1
python-charset-normalizer 3.4.3-1 -> 3.4.4-1
python-cryptography 46.0.2-1 -> 46.0.3-1
python-cssselect 1.2.0-8 -> 1.3.0-1
python-cypari2 2.2.2-1 -> 2.2.4-1
python-cysignals 1.12.5-1 -> 1.12.6-1
python-docutils 1:0.21.2-3 -> 1:0.22.3-1
python-dulwich 0.24.1-1 -> 0.24.8-1
python-filelock 3.19.1-1 -> 3.20.0-1
python-gobject 3.54.3-1 -> 3.54.5-1
python-idna 3.10-2 -> 3.11-1
python-ipykernel 6.30.1-1 -> 7.1.0-1
python-ipywidgets 8.1.7-1 -> 8.1.8-1
python-isort 6.1.0-1 -> 7.0.0-1
python-jupyter-client 8.6.3-3 -> 8.6.3-4
python-jupyter-core 5.8.1-1 -> 5.9.1-1
python-jupyterlab-server 2.27.3-3 -> 2.28.0-1
python-linux-procfs 0.7.3-4 -> 0.7.4-1
python-markdown 3.9.0-1 -> 3.10.0-1
python-matplotlib-inline 0.1.7-2 -> 0.2.1-1
python-numpy 2.3.3-1 -> 2.3.4-1
python-pikepdf 9.11.0-1 -> 10.0.0-1
python-pillow 11.3.0-4 -> 12.0.0-1
python-psutil 7.1.0-1 -> 7.1.3-1
python-pypdf 6.1.1-1 -> 6.1.3-1
python-pyqt6 6.9.1-3 -> 6.10.0-1
python-pyqt6-webengine 6.9.0-1 -> 6.10.0-1
python-pytokens 0.1.10-1 -> 0.3.0-1
python-referencing 0.36.2-1 -> 0.37.0-1
python-regex 2025.9.18-1 -> 2025.11.3-1
python-rich 14.1.0-1 -> 14.2.0-1
python-rpds-py 0.27.1-1 -> 0.28.0-1
python-scipy 1.16.2-1 -> 1.16.3-1
python-tornado 6.4.2-1 -> 6.5.2-1
python-urllib3 2.5.0-1 -> 2.5.0-2
python-virtualenv 20.34.0-1 -> 20.35.4-1
python-websocket-client 1.8.0-2 -> 1.9.0-1
qalculate-gtk 5.7.0-1 -> 5.8.1-1
qbittorrent 5.1.2-1 -> 5.1.2-2
qca-qt5 2.3.10-3 -> 2.3.10-4
qca-qt6 2.3.10-3 -> 2.3.10-4
qpwgraph 0.9.5-1 -> 0.9.6-1
qqc2-breeze-style 6.4.5-1 -> 6.5.2-1
qqc2-desktop-style 6.18.0-1 -> 6.19.0-1
qt5-base 5.15.17+kde+r123-2 -> 5.15.18+kde+r109-1
qt5-declarative 5.15.17+kde+r21-1 -> 5.15.18+kde+r22-1
qt5-graphicaleffects 5.15.17-1 -> 5.15.18-1
qt5-imageformats 5.15.17+kde+r2-1 -> 5.15.18+kde+r2-1
qt5-location 5.15.17+kde+r7-1 -> 5.15.18+kde+r7-1
qt5-multimedia 5.15.17+kde+r2-1 -> 5.15.18+kde+r2-1
qt5-quick3d 5.15.17+kde+r1-2 -> 5.15.18+kde+r1-1
qt5-quickcontrols 5.15.17-1 -> 5.15.18-1
qt5-quickcontrols2 5.15.17+kde+r5-1 -> 5.15.18+kde+r5-1
qt5-remoteobjects 5.15.17-1 -> 5.15.18-1
qt5-sensors 5.15.17-1 -> 5.15.18-1
qt5-serialport 5.15.17-1 -> 5.15.18-1
qt5-speech 5.15.17+kde+r1-1 -> 5.15.18+kde+r1-1
qt5-svg 5.15.17+kde+r5-1 -> 5.15.18+kde+r5-1
qt5-tools 5.15.17+kde+r3-2 -> 5.15.18+kde+r3-1
qt5-translations 5.15.17-1 -> 5.15.18-1
qt5-wayland 5.15.17+kde+r57-1 -> 5.15.18+kde+r55-1
qt5-webchannel 5.15.17+kde+r3-1 -> 5.15.18+kde+r3-1
qt5-webengine 5.15.19-3 -> 5.15.19-4
qt5-websockets 5.15.17+kde+r2-1 -> 5.15.18+kde+r2-1
qt5-x11extras 5.15.17-1 -> 5.15.18-1
qt6-base 6.10.0-1 -> 6.10.0-2
qt6-declarative 6.10.0-1 -> 6.10.0-2
qt6-multimedia 6.10.0-1 -> 6.10.0-2
qt6-multimedia-ffmpeg 6.10.0-1 -> 6.10.0-2
qt6-svg 6.10.0-1 -> 6.10.0-2
qt6-tools 6.10.0-1 -> 6.10.0-2
qtcreator 17.0.2-2 -> 18.0.0-1
qtractor 1.5.8-1 -> 1.5.8-2
r 4.5.1-1 -> 4.5.2-1
rclone 1.71.1-1 -> 1.71.2-1
reaper 7.47-1 -> 7.52-1
reuse 5.1.1-1 -> 6.2.0-1
rhash 1.4.4-1 -> 1.4.6-1
ripgrep 14.1.1-1 -> 15.1.0-1
ruby 3.4.5-1 -> 3.4.7-2
ruby-base64 0.2.0-1 -> 0.3.0-1
ruby-bigdecimal 3.1.9-1 -> 3.3.1-1
ruby-bundled-gems 3.4.5-1 -> 3.4.7-2
ruby-csv 3.3.2-1 -> 3.3.5-1
ruby-default-gems 3.4.5-1 -> 3.4.7-2
ruby-drb 2.2.1-1 -> 2.2.3-1
ruby-matrix 0.4.2-4 -> 0.4.3-1
ruby-minitest 5.25.5-2 -> 5.26.0-1
ruby-net-imap 0.5.8-1 -> 0.5.12-1
ruby-net-smtp 0.5.0-5 -> 0.5.1-1
ruby-power_assert 2.0.5-3 -> 2.0.5-4
ruby-prime 0.1.3-1 -> 0.1.4-1
ruby-rake 13.2.1-5 -> 13.3.0-1
ruby-rexml 3.4.1-3 -> 3.4.4-1
ruby-stdlib 3.4.5-1 -> 3.4.7-2
ruby-test-unit 3.6.8-1 -> 3.7.0-1
s2n-tls 1.5.27-1 -> 1.6.0-1
sagemath 10.7-3 -> 10.7-5
sbt 1:1.11.6-1 -> 1:1.11.7-1
scribus 1.6.4-7 -> 1.6.4-8
sddm-kcm 6.4.5-1 -> 6.5.2-1
sdl2-compat 2.32.56-2 -> 2.32.58-1
signon-kwallet-extension 25.08.2-1 -> 25.08.3-1
singular 4.4.1-3 -> 4.4.1-4
smbclient 2:4.23.1-1 -> 2:4.23.3-1
snapper 0.13.0-1 -> 0.13.0-2
solaar 1.1.14-2 -> 1.1.16-1
solid 6.18.0-1 -> 6.19.0-1
solid5 5.116.0-1 -> 5.116.0-2
sonnet 6.18.0-1 -> 6.19.0-1
sonnet5 5.116.0-1 -> 5.116.0-2
spdlog 1.15.3-3 -> 1.16.0-1
spectacle 1:6.4.5-2 -> 1:6.5.2-1
sqlite 3.50.4-2 -> 3.51.0-1
squashfs-tools 4.7.2-1 -> 4.7.3-1
starship 1.23.0-1 -> 1.24.0-1
strongswan 6.0.2-1 -> 6.0.3-1
sudo 1.9.17.p1-1 -> 1.9.17.p2-1
suil 0.10.20-1 -> 0.10.22-1
suitesparse 7.11.0-1 -> 7.12.1-1
sundials 7.5.0-1 -> 7.5.0-2
supercollider 3.14.0-2 -> 3.14.0-3
syndication 6.18.0-1 -> 6.19.0-1
syntax-highlighting 6.18.0-1 -> 6.19.0-1
sysstat 12.7.7-1 -> 12.7.8-1
systemd 258-4 -> 258.1-1
systemd-libs 258-4 -> 258.1-1
systemd-sysvcompat 258-4 -> 258.1-1
systemsettings 6.4.5-1 -> 6.5.2-1
thin-provisioning-tools 1.2.2-1 -> 1.3.0-1
threadweaver 6.18.0-1 -> 6.19.0-1
thunderbird 143.0.1-2 -> 144.0.1-2
thunderbird-i18n-en-us 143.0.1-2 -> 144.0.1-2
tinysparql 3.10.0-1 -> 3.10.1-1
tslib 1.23-1 -> 1.24-1
tuna 1:0.19-5 -> 1:0.20-1
usbutils 018-1 -> 019-1
v4l-utils 1.30.1-1 -> 1.32.0-1
vkd3d 1.17-1 -> 1.17-2
vlc-cli 3.0.21-30 -> 3.0.21-31
vlc-gui-qt 3.0.21-30 -> 3.0.21-31
vlc-plugin-a52dec 3.0.21-30 -> 3.0.21-31
vlc-plugin-alsa 3.0.21-30 -> 3.0.21-31
vlc-plugin-archive 3.0.21-30 -> 3.0.21-31
vlc-plugin-dav1d 3.0.21-30 -> 3.0.21-31
vlc-plugin-dbus 3.0.21-30 -> 3.0.21-31
vlc-plugin-dbus-screensaver 3.0.21-30 -> 3.0.21-31
vlc-plugin-faad2 3.0.21-30 -> 3.0.21-31
vlc-plugin-flac 3.0.21-30 -> 3.0.21-31
vlc-plugin-gnutls 3.0.21-30 -> 3.0.21-31
vlc-plugin-inflate 3.0.21-30 -> 3.0.21-31
vlc-plugin-journal 3.0.21-30 -> 3.0.21-31
vlc-plugin-jpeg 3.0.21-30 -> 3.0.21-31
vlc-plugin-lua 3.0.21-30 -> 3.0.21-31
vlc-plugin-mpg123 3.0.21-30 -> 3.0.21-31
vlc-plugin-ogg 3.0.21-30 -> 3.0.21-31
vlc-plugin-opus 3.0.21-30 -> 3.0.21-31
vlc-plugin-png 3.0.21-30 -> 3.0.21-31
vlc-plugin-pulse 3.0.21-30 -> 3.0.21-31
vlc-plugin-shout 3.0.21-30 -> 3.0.21-31
vlc-plugin-speex 3.0.21-30 -> 3.0.21-31
vlc-plugin-tag 3.0.21-30 -> 3.0.21-31
vlc-plugin-theora 3.0.21-30 -> 3.0.21-31
vlc-plugin-twolame 3.0.21-30 -> 3.0.21-31
vlc-plugin-vorbis 3.0.21-30 -> 3.0.21-31
vlc-plugin-vpx 3.0.21-30 -> 3.0.21-31
vlc-plugin-xml 3.0.21-30 -> 3.0.21-31
vlc-plugins-base 3.0.21-30 -> 3.0.21-31
vlc-plugins-video-output 3.0.21-30 -> 3.0.21-31
vulkan-swrast 1:25.2.4-1 -> 1:25.2.6-1
wasmtime 37.0.2-1 -> 38.0.3-1
webkit2gtk-4.1 2.50.0-2 -> 2.50.1-1
webkitgtk-6.0 2.50.0-2 -> 2.50.1-1
whois 5.6.4-1 -> 5.6.5-1
wine 10.16-1 -> 10.18-1
wine-mono 10.2.0-1 -> 10.3.0-1
wireless-regdb 2025.07.10-1 -> 2025.10.07-1
xdg-desktop-portal-kde 6.4.5-2 -> 6.5.2-1
xfsprogs 6.16.0-3 -> 6.17.0-1
xmlsec 1.3.7-2 -> 1.3.8-1
xorg-server 21.1.18-2 -> 21.1.20-1
xorg-server-common 21.1.18-2 -> 21.1.20-1
xorg-xwayland 24.1.8-1 -> 24.1.9-1
yabridge 5.1.1-4 -> 5.1.1-5
yabridgectl 5.1.1-4 -> 5.1.1-5
yakuake 25.08.2-1 -> 25.08.3-1
zed 0.207.4-1 -> 0.211.6-1
zoom 6.6.0-1 -> 6.6.6-1
zotero-bin 7.0.24-1 -> 7.0.27-1
Please do not post here as if it were a chat room. If you want to add new information, please edit your last post if no one has replied yet.
Keep it tidy. Thanks. :slightly_smiling_face:
Character limit prevented me from just updating my top-level post, so I figured appending in next comments was the way to go. Sorry about that.
  1. Update the system
  2. Reboot, wait for black screen or random pixels
  3. Reboot again, this time into recovery mode (advanced boot options)
  4. Run garuda-diag in recovery mode
  5. Post the generated link here.
This will get us the needed debug information.
Thanks @TNE , here’s the link:
Heya, sorry I have to ask for this, but may you please repeat the steps?
There was a bug in garuda-diag that prevented the logs from being useful. Sorry.
Don’t be sorry @TNE , I’m thankful you’re looking into this at all.
Booted again until hang, rebooted and here’s the garuda-diag output:
Based on the logs, the issue seems to be related to systemd-homed. Are you aware you are using systemd-homed?
Relevant logs that might help in troubleshooting:
nov 08 11:07:24 Xolotl (systemd)[1042]: user@1000.service: PAM failed: Authentication failure
nov 08 11:07:24 Xolotl (systemd)[1042]: user@1000.service: Failed to set up PAM session: Operation not permitted
nov 08 11:07:24 Xolotl (systemd)[1042]: user@1000.service: Failed at step PAM spawning /usr/lib/systemd/systemd: Operation not permitted
nov 08 11:07:24 Xolotl systemd[1]: user@1000.service: Main process exited, code=exited, status=224/PAM
nov 08 11:07:24 Xolotl systemd[1]: user@1000.service: Failed with result 'exit-code'.
nov 08 11:07:24 Xolotl systemd[1]: Failed to start User Manager for UID 1000.
I was not aware and have never heard about it before; pretty sure I did not manually enabled it. Still looking through documentation, but apparently I have it disabled. What I have discovered so far is that is has todo with some process that recovery mode omits: when I exit from the recovery mode I’m sent straight into login and the system runs fine.
I went and removed some stale symlinks on my .config/systemd/user, and after that my system was able to reach login without going into recovery mode first.
Nevertheless I got into a very laggy state (which I’m not getting currently after another reboot), and got a plasma message at some point regarding a dbus-org.freedesktop service missing. Apparently this might be indeed related to systemd-homed:
xavigo@Xolotl in ~
❯ systemctl status dbus.socket
● dbus-broker.service - D-Bus System Message Bus
     Loaded: loaded (/usr/lib/systemd/system/dbus-broker.service; disabled; preset: disabled)
     Active: active (running) since Mon 2025-11-17 07:28:34 CST; 28min ago
 Invocation: 1783891dc064422997b964f3b140e4af
TriggeredBy: ● dbus.socket
       Docs: man:dbus-broker-launch(1)
   Main PID: 876 (dbus-broker-lau)
      Tasks: 2 (limit: 38079)
     Memory: 5.9M (peak: 7.7M)
        CPU: 254ms
     CGroup: /system.slice/dbus-broker.service
             ├─876 /usr/bin/dbus-broker-launch --scope system --audit
             └─880 dbus-broker --log 10 --controller 9 --machine-id 3743a97089e340fb9bdcddde30fd4eec --max-bytes 536870912 --max-fds 4096 --max-matches 131072 --audit
nov 17 07:28:34 Xolotl systemd[1]: Starting D-Bus System Message Bus...
nov 17 07:28:34 Xolotl systemd[1]: Started D-Bus System Message Bus.
nov 17 07:28:34 Xolotl dbus-broker-launch[876]: Ready
nov 17 07:28:35 Xolotl dbus-broker-launch[876]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
nov 17 07:28:38 Xolotl dbus-broker-launch[876]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
xavigo@Xolotl in ~
❯ systemctl status dbus-org.freedesktop.home1.service
Unit dbus-org.freedesktop.home1.service could not be found.
xavigo@Xolotl ~
[✖]  systemctl status dbus-org.freedesktop.resolve1.service
Unit dbus-org.freedesktop.resolve1.service could not be found.
My take would be (re)install those services, even though I never migrated to systemd-homed (have been on the same Garuda install from 2021, but moved from Dragonized to Mokka this year). But seems like I need to reinstall all systemd, is this safe?
This is the log I get of system services from Rani:
as info: (special post 8 edit 2):
My mind, before you reinstall all the stuff make the manual intervention for this in /etc/pam.d/system-auth and pls don’t forget to backup this file if you run in trouble with the login or you must use a working snapshot.
