Today I ran garuda-update for the first time in a while, and after rebooting I froze twice requiring hard shutdowns. Both times I was playing Factorio through Steam with Firefox open, and the freezes happened about two minutes after boot. After that, I was no longer able to launch Steam.
Here is what happens when I try to run Steam:
$ steam-native
steam.sh[120058]: Running Steam on garuda Soaring 64-bit
steam.sh[120058]: STEAM_RUNTIME is disabled by the user
steam.sh[120058]: Can't find 'steam-runtime-check-requirements', continuing anyway
My inxi:
Kernel: 6.8.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=84e8a7e6-87c1-4a5c-9ad7-b1fbd237c67b rw rootflags=subvol=@
quiet rd.luks.uuid=2fbb97f3-9ec7-4f64-947f-24d42ee13814
rd.luks.uuid=29eb5c9d-ec55-479c-b906-5f9bb2e901ad
resume=/dev/mapper/luks-29eb5c9d-ec55-479c-b906-5f9bb2e901ad loglevel=3
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F38b
date: 03/23/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3857 high: 4450 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3559 2: 4450
3: 3560 4: 4450 5: 3591 6: 3559 7: 3560 8: 3730 9: 3585 10: 4449 11: 3558
12: 4448 13: 4442 14: 3570 15: 3584 16: 3625 bogomips: 108792
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-2,DP-3 empty: HDMI-A-1,Writeback-1 bus-ID: 0b:00.0
chip-ID: 1002:744c class-ID: 0300
gpu: amdgpu d-rect: 7920x2520 display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-2 pos: top-center res: 3440x1440 size: N/A modes: N/A
Monitor-3: DP-3 pos: top-right res: 2560x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.8.6-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab30
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: b58e:9e84 class-ID: 0300
Device-4: Astro Gaming A50 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3
chip-ID: 9886:002c class-ID: 0300
Device-5: Cambridge Silicon Radio Audioengine 2+
lanes: 1 mode: 1.1 bus-ID: 5-4.1:5 chip-ID: 0a12:4007 class-ID: 0300
API: ALSA v: k6.8.6-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.1:6 chip-ID: 0b05:190e
Local Storage: total: 4.78 TiB used: 374.33 GiB (7.7%)
fw-rev: 2B2QEXM7 temp: 52.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 40.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 198.2 GiB size: 198.2 GiB (100.00%)
used: 149.35 GiB (75.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-2fbb97f3-9ec7-4f64-947f-24d42ee13814
used: 732 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 198.2 GiB size: 198.2 GiB (100.00%)
ID-4: /var/log raw-size: 198.2 GiB size: 198.2 GiB (100.00%)
ID-5: /var/tmp raw-size: 198.2 GiB size: 198.2 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%)
mapped: luks-29eb5c9d-ec55-479c-b906-5f9bb2e901ad
ID-2: swap-2 type: zram size: 31.26 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.8 C mobo: 34.0 C gpu: amdgpu temp: 59.0 C
mem: 73.0 C
Fan Speeds (rpm): fan-1: 845 gpu: amdgpu fan: 562
Memory: total: 32 GiB available: 31.26 GiB used: 7.52 GiB (24.1%)
Processes: 371 Power: uptime: 31m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1912 libs: 548 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-02-26
Last full system update: 2024-04-17 ↻
Some of the recommended troubleshooting commands:
$ journalctl -b -p3 --no-hostname --no-pager
Apr 17 17:13:18 kernel: usb 1-3.1: device descriptor read/64, error -32
Apr 17 17:13:22 systemd-udevd[798]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Apr 17 17:13:24 libvirtd[1160]: Unable to open /dev/kvm: No such file or directory
Apr 17 17:13:35 plasmashell[3953]: aurorae: Couldn't find QML Decoration ""
Apr 17 17:13:35 bluetoothd[1057]: src/gatt-database.c:database_add_chrc() Failed to create characteristic entry in database
Apr 17 17:13:35 bluetoothd[1057]: src/gatt-database.c:database_add_service() Failed to add characteristic
Apr 17 17:13:35 bluetoothd[1057]: src/gatt-database.c:database_add_app() Failed to add service
Apr 17 17:13:35 bluetoothd[1057]: src/gatt-database.c:client_ready_cb() Failed to create GATT service entry in local database
Apr 17 17:13:41 sudo[4740]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:15:31 (sd-pam)[9682]: pam_systemd(login:session): Failed to release session: Access denied
Apr 17 17:15:31 (sd-pam)[9701]: pam_systemd(login:session): Failed to release session: Access denied
Apr 17 17:16:14 sudo[11351]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:16:16 sudo[11462]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:18:38 sudo[16489]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:18:39 sudo[16597]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:22:28 sudo[26009]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:22:37 sudo[26058]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:26:02 sudo[33558]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:27:24 sudo[36352]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:28:56 sudo[39696]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:29:28 sudo[41107]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user} ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:33:24 sudo[48593]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:33:33 sudo[49380]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:34:42 sudo[51255]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:34:46 sudo[51827]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:34:54 sudo[52077]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:35:29 sudo[53548]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:40:13 sudo[63587]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:41:25 sudo[66003]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:42:26 sudo[68190]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
Apr 17 17:44:32 sudo[72317]: {user} : a password is required ; TTY=pts/0 ; PWD=/home/{user}/.local/share/Steam/ubuntu12_32 ; USER=root ; COMMAND=/usr/bin/true
$ free -h
total used free shared buff/cache available
Mem: 31Gi 8.5Gi 15Gi 973Mi 8.2Gi 22Gi
Swap: 65Gi 1.2Mi 65Gi
$ sensors
amdgpu-pci-0b00
Adapter: PCI adapter
vddgfx: 675.00 mV
fan1: 562 RPM (min = 0 RPM, max = 3300 RPM)
edge: +55.0°C (crit = +100.0°C, hyst = -273.1°C)
(emerg = +105.0°C)
junction: +62.0°C (crit = +110.0°C, hyst = -273.1°C)
(emerg = +115.0°C)
mem: +75.0°C (crit = +108.0°C, hyst = -273.1°C)
(emerg = +113.0°C)
PPT: 84.00 W (cap = 327.00 W)
gigabyte_wmi-virtual-0
Adapter: Virtual device
temp1: +36.0°C
temp2: +38.0°C
temp3: +48.0°C
temp4: +47.0°C
temp5: +45.0°C
temp6: +52.0°C
nvme-pci-0400
Composite: +40.9°C (low = -273.1°C, high = +84.8°C)
(crit = +84.8°C)
Sensor 1: +40.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +53.9°C (low = -273.1°C, high = +65261.8°C)
acpitz-acpi-0
Adapter: ACPI interface
temp1: +16.8°C
temp2: +16.8°C
temp3: +16.8°C
kraken2-hid-3-7
Adapter: HID adapter
Fan: 848 RPM
Pump: 2102 RPM
Coolant: +37.4°C
k10temp-pci-00c3
Tctl: +48.1°C
Tccd1: +48.5°C
nvme-pci-0100
Composite: +52.9°C (low = -273.1°C, high = +84.8°C)
(crit = +84.8°C)
Sensor 1: +52.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +56.9°C (low = -273.1°C, high = +65261.8°C)
I’ve looked up a few of the errors, but all I could find was problems with Nvidia, which I’m pretty sure would not apply to me.
