My system is experiencing micro-freezes
Here’s my INXI:
Kernel: 6.15.1-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
root=UUID=41d13ceb-bd92-4022-a095-731ad881c554 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0 wm: kwin_wayland vt: 1
Type: Laptop System: OriginPC product: EON17-X v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Notebook model: X370SNx serial: <superuser required> part-nu: EON17-X
uuid: <superuser required> UEFI: INSYDE v: 1.07.12TCOM date: 01/15/2024
ID-1: BAT0 charge: 74.8 Wh (78.0%) condition: 95.9/103.1 Wh (93.1%) volts: 16.2 min: 15.2
model: Notebook BAT type: Li-ion serial: <filter> status: not charging
Info: model: 13th Gen Intel Core i9-13900HX bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 13 level: v3 note: check built: 2022+ process: Intel 7 (10nm) family: 6
model-id: 0xB7 (183) stepping: 1 microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2 st: 16 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB L2: 32 MiB
desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 892 min/max: 800/5200:5400:3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 892 2: 892 3: 892 4: 892 5: 892 6: 892 7: 892 8: 892 9: 892 10: 892
11: 892 12: 892 13: 892 14: 892 15: 892 16: 892 17: 892 18: 892 19: 892 20: 892 21: 892 22: 892
23: 892 24: 892 25: 892 26: 892 27: 892 28: 892 29: 892 30: 892 31: 892 32: 892
bogomips: 154828
Device-1: Intel Raptor Lake-S UHD Graphics vendor: CLEVO/KAPOK driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA AD104M [GeForce RTX 4080 Max-Q / Mobile] vendor: CLEVO/KAPOK driver: nvidia
v: 575.57.08 alternate: nouveau,nova_core,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none empty: DP-1,
DP-2, DP-3, HDMI-A-1, eDP-2 bus-ID: 02:00.0 chip-ID: 10de:27e0 class-ID: 0300
Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-6:3 chip-ID: 04f2:b7c3 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
driver: X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x09f9 built: 2021 res: mode: 1600x900 hz: 60
scale: 114% (1.15) to: 1391x783 dpi: 171 gamma: 1.2 size: 381x214mm (15x8.43")
diag: 437mm (17.2") ratio: 16:9 modes: 2560x1440
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: iris device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia wayland: drv: iris x11:
drv: iris inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.3-arch1.3 glx-v: 1.4
direct-render: yes renderer: Mesa Intel Graphics (RPL-S) device-ID: 8086:a788 memory: 61.03 GiB
unified: yes display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 16 device: 0 type: integrated-gpu name: Intel Graphics (RPL-S)
driver: mesa intel v: 25.1.3-arch1.3 device-ID: 8086:a788 surfaces: N/A device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 4080 Laptop GPU driver: nvidia v: 575.57.08
device-ID: 10de:27e0 surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 20.1.6 256 bits)
driver: mesa llvmpipe v: 25.1.3-arch1.3 (LLVM 20.1.6) device-ID: 10005:0000 surfaces: N/A
gpu: corectrl, nvidia-settings, nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Intel Raptor Lake High Definition Audio vendor: CLEVO/KAPOK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: NVIDIA AD104 High Definition Audio driver: snd_hda_intel v: kernel
alternate: nova_core pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 02:00.1
chip-ID: 10de:22bc class-ID: 0403
API: ALSA v: k6.15.1-zen1-2-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
Device-2: Intel vendor: CLEVO/KAPOK driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 04:00.0 chip-ID: 8086:3102 class-ID: 0200
IF-ID-1: virbr1 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 4.55 TiB used: 1.86 TiB (40.8%)
ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Corsair model: MP600 GS size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: ELFMH0.1 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: MP600 CORE XT size: 3.64 TiB
fw-rev: ELFMC1.0 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 161.85 GiB (17.4%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:9
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 616 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:8
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 161.85 GiB (17.4%) fs: btrfs
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 161.85 GiB (17.4%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:9
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 161.85 GiB (17.4%)
ID-1: swap-1 type: zram size: 62.49 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
System Temperatures: cpu: 40.8 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.49 GiB used: 10.82 GiB (17.3%)
Processes: 640 Power: uptime: 22m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 24.89 GiB
Packages: 2544 pm: nix-default pkgs: 64 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0 pm: pacman
pkgs: 2455 libs: 598 tools: cylon, gnome-software, octopi, pacaur, pakku, paru, pikaur, yay
pm: rpm pkgs: 0 pm: flatpak pkgs: 18 pm: snap pkgs: 7 Compilers: clang: 20.1.6 gcc: 15.1.1
Client: Unknown Client: garuda-rani inxi: 3.3.38
System install date: 2025-06-03
Last full system update: 2025-06-11
Relevant software: snapper(custom) NetworkManager dracut nvidia-dkms
