Hey All,
Issue just started today 4/18/24 - I was trying to watch some videos online and my system locked up, rebooted, locked up again. I checked journalctrl and found the following that happens before every crash:
Apr 18 21:33:05 s0ul-GCL plasmashell[15412]: aurorae: Couldn't find QML Decoration ""
Apr 18 21:33:05 s0ul-GCL bluetoothd[8187]: Failed to set mode: Failed (0x03)
Apr 18 21:33:07 s0ul-GCL bluetoothd[8187]: Failed to add UUID: Failed (0x03)
Apr 18 21:33:07 s0ul-GCL bluetoothd[8187]: src/gatt-database.c:database_add_chrc() Failed to create character>
Apr 18 21:33:07 s0ul-GCL bluetoothd[8187]: src/gatt-database.c:database_add_service() Failed to add character>
Apr 18 21:33:07 s0ul-GCL bluetoothd[8187]: src/gatt-database.c:database_add_app() Failed to add service
Apr 18 21:33:07 s0ul-GCL bluetoothd[8187]: src/gatt-database.c:client_ready_cb() Failed to create GATT servic>
Apr 18 21:33:07 s0ul-GCL pipewire[15238]: spa.v4l2: '/dev/video0' VIDIOC_QUERYCTRL: Input/output error
I used snapper to restore to before my System Update last night, same issue, can’t go further back now thanks to creating more snapshots while troubleshooting. I’ve powerflushed the system, reinstalled ALL my pipewire packages, but am now lost as to what to try next since I am pretty new to Linux overall. I was watching video and gaming fine yesterday, the build date on pipewire is from the 15th, but I am not sure how I would downgrade every single package to try that. Per the title, the issue only seems to happen with videos in fullscreen, Spotify and other audio doesn’t crash as far as I can tell. I will be testing my games through Steam next. Any help would be appreciated!
Garuda-inxi results:
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=d3b11231-5e33-47dc-a2a9-e096174e35e7 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MAG B650 TOMAHAWK WIFI (MS-7D75)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.E0 date: 02/20/2024
Info: model: AMD Ryzen 9 7900X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 2740 high: 4796 min/max: 400/5660 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4789 2: 4161 3: 4787
4: 4773 5: 400 6: 4783 7: 400 8: 3190 9: 4796 10: 400 11: 3195 12: 4795
13: 4775 14: 400 15: 400 16: 400 17: 400 18: 4773 19: 400 20: 3389
21: 4791 22: 400 23: 4768 24: 400 bogomips: 211188
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: XFX
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2,DP-3 empty: HDMI-A-1,Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:744c class-ID: 0300
Device-2: Generalplus 808 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:8 chip-ID: 1b3f:2002
class-ID: 0102
gpu: amdgpu d-rect: 5560x4440 display-ID: 0
Monitor-1: DP-1 pos: middle-c res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-2 pos: top-right res: 1080x1920 size: N/A modes: N/A
Monitor-3: DP-3 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 17.0.6 DRM 3.57 6.8.7-zen1-1-zen) device-ID: 1002:744c
memory: 19.53 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Corsair VIRTUOSO SE USB Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-5.1:4 chip-ID: 1b1c:0a3d class-ID: 0300
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 0db0:422d class-ID: 0300
Device-5: Generalplus 808 Camera driver: snd-usb-audio,uvcvideo type: USB
class-ID: 0102
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:7 chip-ID: 0e8d:0616
Local Storage: total: 2.73 TiB used: 550.86 GiB (19.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 39.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 550.84 GiB (29.6%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:2
used: 27.2 MiB (28.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 550.84 GiB (29.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.8 C mobo: 40.0 C gpu: amdgpu temp: 55.0 C
mem: 64.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 489
Memory: total: 32 GiB note: est. available: 31.03 GiB used: 5.58 GiB (18.0%)
Processes: 434 Power: uptime: 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1978 libs: 576 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2023-11-19
Last full system update: 2024-04-18
