Issue Description:
I’m using Garuda Linux (plain KDE) on a Dynabook laptop, and the system frequently freezes. When this happens:
- I can’t interact with anything on the screen.
- Audio and other inputs (e.g., keyboard or mic) seem to continue working in the background.
This issue has been ongoing for a long time, and I haven’t found a solution yet.
What I’ve Tried:
- Searched the web and forums for similar issues.
- Checked the Garuda Linux wiki and FAQ sections.
- Updated the system and checked logs for errors (couldn’t identify anything conclusive).
Additional Information:
I used Fedora on the same laptop for about 10 weeks, and this freezing issue did not occur there. Could this be related to differences in how Arch-based systems handle hardware, drivers, or kernel configurations?
garuda-inxi Output:
Kernel: 6.12.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f31b6098-c1a4-49c9-9149-91014bae2745 rw rootflags=subvol=@
Type: Laptop System: Dynabook product: dynabook TECRA A40-G
v: PMZ20E-05800WAR serial: <superuser required> Chassis: type: 10
v: Version 1.0 serial: <superuser required>
Mobo: Dynabook model: A0104/0002 v: Version A0
serial: <superuser required> part-nu: PMZ20E uuid: <superuser required>
UEFI: Dynabook v: Version 4.50 date: 02/13/2023
ID-1: BAT1 charge: 17.4 Wh (51.3%) condition: 33.9/42.0 Wh (80.7%)
power: 15.6 W volts: 0.1 min: 15.4 model: G71C000LY111 type: Li-ion
Info: model: Intel Core i7-10710U bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA6 (166) stepping: 0 microcode: 0xFE
Speed (MHz): avg: 400 min/max: 400/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 38399
Device-1: Intel Comet Lake UHD Graphics vendor: Dynabook driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bca
Device-2: Chicony TOSHIBA Web Camera - HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:7 chip-ID: 04f2:b689
class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d6 built: 2016 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: N/A device-ID: 8086:9bca
19.1.6 256 bits) driver: N/A device-ID: 10005:0000
Info: Tools: api: vulkaninfo de: kscreen-console,kscreen-doctor x11: xprop
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dynabook
API: ALSA v: k6.12.9-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-V vendor: Dynabook driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
IF: wlan0 state: up mac: <filter>
Info: services: iwd, NetworkManager, smbd, systemd-timesyncd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:8 chip-ID: 8087:0029
Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: <filter>
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept
Local Storage: total: 1.34 TiB used: 52.03 GiB (3.8%)
model: MZVLQ512HALU-00000 size: 476.94 GiB block-size: physical: 512 B
fw-rev: FXV7101Q temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37960G
size: 894.25 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1.02 scheme: GPT
ID-1: / raw-size: 238.16 GiB size: 238.16 GiB (100.00%) used: 52 GiB (21.8%)
used: 25.8 MiB (26.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
used: 52 GiB (21.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.38 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 50.0 C pch: 48.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Memory: total: 16 GiB available: 15.38 GiB used: 4.35 GiB (28.3%)
Processes: 331 Power: uptime: 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: 1184 pm: pacman pkgs: 1150 libs: 352 tools: yay pm: flatpak
pkgs: 34 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: kitty inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-12-29
Last full system update: 2025-01-16
Windows dual boot: Probably (Run as root to verify)```
