System will freeze or close windows (still happens but started happening before kde plasma 6 update); seems to be an exploit issue not a resource issue; only happens on hardened kernel (6.8 on zen seems to be helping but it is not the only issue and was not happening on zen for a few weeks now).
Not effecting ESO anymore was originally though; Cyberpunk 2077 will also freeze and close as well as Firedragon & Librewolf (even after latest update); Firestorm Second Life Viewer & also VLC playing a DVD has frozen the system multiple times now and happens every single time after about 10 minutes in Firestorm.
Issues with freezing do not happen using the Zen Kernel; windows closings happens on both; windows closing seems to be more of an exploit yet freezing probably is too might be due to manipulation of system files. Thinking about trying something like Flat Seal if there are any recommendations. Remember seeing an alternative for arch. (not using flat packs or anything just direct packages from projects or repos)
Much appreciated.
Kernel: 6.7.9-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=ee9d8e46-88f6-40bb-a345-3b374ebb4edb rw rootflags=subvol=@
quiet rd.luks.uuid=5d766ada-bbea-4479-b984-c5950293753b quiet
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASUSTeK model: A88XM-PLUS v: Rev X.0x
UEFI-[Legacy]: American Megatrends v: 3004 date: 04/14/2017
Device-1: ps-controller-battery-1c:96:5a:c3:bb:50 model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD A10-7850K Radeon R7 12 Compute Cores 4C+8G bits: 64
type: MT MCP arch: Steamroller level: v2 built: 2014 process: GF 28nm
family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003106
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3746 high: 3988 min/max: 1700/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3988 2: 3700
3: 3700 4: 3599 bogomips: 29536
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: XFX Pine
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:687f
Monitor-1: DP-3 res: 1360x768 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX Vega (radeonsi vega10
LLVM 17.0.6 DRM 3.57 6.7.9-hardened1-1-hardened) device-ID: 1002:687f
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX Vega (RADV VEGA10) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:687f surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD FCH Azalia vendor: ASUSTeK AM1I-A driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-2: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:aaf8 class-ID: 0403
API: ALSA v: k6.7.9-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.14 TiB used: 29.73 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
tech: SSD serial: <filter> fw-rev: 3B0Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
used: 29.73 GiB (12.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5d766ada-bbea-4479-b984-c5950293753b
ID-2: /home raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-3: /var/log raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 24.2 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 26.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 398
Memory: total: 32 GiB available: 31.3 GiB used: 3.3 GiB (10.5%)
Processes: 227 Power: uptime: 49m states: freeze,mem suspend: deep
avail: s2idle wakeups: 0 services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1492 libs: 477 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-03-11
Last full system update: 2024-03-18
