I have Garuda gamer edition, and for the most part things work, but lately has been freezing at seemingly random times. When watching a video, when just trying to close a window, when waking it from a monitor going to sleep.
At first I thought it was my nvme overheating, but the temperature seems fine. Then I thought nvidia was not working correctly, since some games said I was in software render mode. Booting into the normal linux kernel made that go away, so I had removed the zen and tried other nvidia drivers, but then borked the system with a bad nvidia. So restored a snapshot, and everything booted again with zen and normal kernel, and now things do not say software mode.
But for a further test I had booted into the linux normal kernel and it still froze this morning when I was checking things. Lately though it has been freezing when I have been copying stuff to my NAS, using rsync and cryptomator with it. At least thats what I have been doing lately when I notice the freezing. However it has frozen even when I am not doing that.
I am at a loss as to what to check next. I just would like it to not freeze and hang the system because it requires me to force power off the machine. When it freezes I can still hear audio for a bit, but the screen is still and I cannot move the mouse.
It could still be something with the nvme, but I am not sure. might even be nvidia, or file indexing. I really dont know. I am also dual booted with windows, but windows is on its own ssd and linux is on the nvme. So they should not be affecting each other. I doubt it is running out of RAM, since I have 64GB and I barely use 8GB. CPU seems to always be low as well. So any help would be appreciated. Thanks!
Here are the outputs from the assistant tool:
System Spec:
System: Kernel: 5.13.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6b01d9a0-f1d5-4fcc-a164-83a5dd0cab3b rw [email protected] quiet
cryptdevice=UUID=2aed9b51-5839-4dc7-b7fd-626b0a957268:luks-2aed9b51-5839-4dc7-b7fd-626b0a957268
root=/dev/mapper/luks-2aed9b51-5839-4dc7-b7fd-626b0a957268 splash
resume=/dev/mapper/luks-4f21562b-460c-422e-838e-008dcae4276e loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASRock model: Z590 Steel Legend WiFi 6E serial: <filter>
UEFI: American Megatrends LLC. v: P1.60 date: 06/16/2021
CPU: Info: 8-Core model: 11th Gen Intel Core i9-11900K bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: A7 (167) stepping: 1 microcode: 40 cache:
L2: 16 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 112128
Speed: 5102 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 5102 2: 5113 3: 5075
4: 5127 5: 5153 6: 5133 7: 5104 8: 5059 9: 5100 10: 5113 11: 5210 12: 4966 13: 5112
14: 5112 15: 5108 16: 5105
Graphics: Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-6.4:8 chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
Screen-1: 0 s-res: 1921x2160 s-dpi: 101 s-size: 483x544mm (19.0x21.4")
s-diag: 727mm (28.6")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 30 size: 1600x900mm (63.0x35.4")
diag: 1836mm (72.3")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Audio: Device-1: Intel Tiger Lake-H HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.13.12-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 8086:2725 class-ID: 0280
Bluetooth: Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:12
chip-ID: 8087:0032 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Drives: Local Storage: total: 1.82 TiB used: 112.49 GiB (6.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS100T2B0C-00PXH0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: 211210WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS100T2B0A-00SM50
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 20WD scheme: GPT
Partition: ID-1: / raw-size: 862.32 GiB size: 862.32 GiB (100.00%) used: 112.49 GiB (13.0%)
mapped: luks-2aed9b51-5839-4dc7-b7fd-626b0a957268
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 707 KiB (0.3%) fs: vfat
ID-3: /home raw-size: 862.32 GiB size: 862.32 GiB (100.00%) used: 112.49 GiB (13.0%)
ID-4: /var/log raw-size: 862.32 GiB size: 862.32 GiB (100.00%) used: 112.49 GiB (13.0%)
ID-5: /var/tmp raw-size: 862.32 GiB size: 862.32 GiB (100.00%) used: 112.49 GiB (13.0%)
ID-1: swap-1 type: zram size: 62.66 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 68.93 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1 mapped: luks-4f21562b-460c-422e-838e-008dcae4276e
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 100%
Info: Processes: 387 Uptime: 21m wakeups: 0 Memory: 62.66 GiB used: 5.16 GiB (8.2%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 2008 lib: 559 flatpak: 0 Client: Unknown Client: garuda-assistant inxi: 3.3.06
Journal Errors:
-- Journal begins at Tue 2021-08-10 12:36:07 MDT, ends at Sun 2021-08-22 07:26:59 MDT. --
Aug 22 06:53:21 kalachakra kernel:
Aug 22 06:53:21 kalachakra systemd-modules-load[468]: Failed to find module 'ashmem_linux'
Aug 22 06:53:21 kalachakra systemd-modules-load[468]: Failed to find module 'binder_linux'
Aug 22 06:53:21 kalachakra systemd-modules-load[468]: Failed to find module 'vboxpci'
Aug 22 06:53:21 kalachakra systemd-udevd[512]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Aug 22 06:53:21 kalachakra systemd-udevd[534]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Aug 22 06:53:21 kalachakra systemd-udevd[529]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
Aug 22 06:53:22 kalachakra systemd-udevd[515]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Aug 22 06:53:22 kalachakra systemd-udevd[515]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Aug 22 06:53:26 kalachakra systemd-tmpfiles[861]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Aug 22 06:53:34 kalachakra systemd[3532]: Failed to start Profile-sync-daemon.
Aug 22 06:55:22 kalachakra systemd-networkd-wait-online[560]: Timeout occurred while waiting for network connectivity.
Aug 22 06:55:22 kalachakra systemd[1]: Failed to start Wait for Network to be Configured.
Aug 22 06:55:22 kalachakra nmbd[11163]: [2021/08/22 06:55:22.044770, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
Aug 22 06:55:22 kalachakra nmbd[11163]: daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Aug 22 06:55:22 kalachakra smbd[11164]: [2021/08/22 06:55:22.074875, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
Aug 22 06:55:22 kalachakra smbd[11164]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Aug 22 06:55:45 kalachakra nmbd[11163]: [2021/08/22 06:55:45.099407, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Aug 22 06:55:45 kalachakra nmbd[11163]: *****
Aug 22 06:55:45 kalachakra nmbd[11163]: Samba name server KALACHAKRA is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.124
Aug 22 06:55:45 kalachakra nmbd[11163]: [2021/08/22 06:55:45.099470, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Aug 22 06:55:45 kalachakra nmbd[11163]: Samba name server KALACHAKRA is now a local master browser for workgroup WORKGROUP on subnet 10.42.0.1
Aug 22 07:08:09 kalachakra systemd-coredump[55397]: Process 55393 (bt-adapter) of user 1000 dumped core.
Found module linux-vdso.so.1 with build-id: 8940648a0253889ba6d49dfc4df381b90a9b0ca9
Found module librt.so.1 with build-id: 75484da2d6f1515189eefa076e0a40328834cd16
Found module libblkid.so.1 with build-id: f03a24e92c9852272bd0049b5bcb7ed6cf0e664f
Found module libdl.so.2 with build-id: 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Found module ld-linux-x86-64.so.2 with build-id: 040cc3dd10461562f177df39e3be2f3704258c3c
Found module libffi.so.7 with build-id: de60e99f39569d11d09160bbdcd486cedc87d2b6
Found module libresolv.so.2 with build-id: c915c72668282861a813f7ea3c0780f37b681dc0
Found module libmount.so.1 with build-id: ff9a1d99d35cf640d0bfdaba294854372672c29b
Found module libz.so.1 with build-id: 81bf6e728a6d6f5b105b0f8b25f6c614ce10452a
Found module libgmodule-2.0.so.0 with build-id: 1c305e1a08706be35604a78f8d99a567274a0217
Found module libpthread.so.0 with build-id: 07c8f95b4f3251d08550217ad8a1f31066229996
Found module libpcre.so.1 with build-id: 845483dd0acba86de9f0313102bebbaf3ce52767
Found module libc.so.6 with build-id: 4b406737057708c0e4c642345a703c47a61c73dc
Found module libgobject-2.0.so.0 with build-id: a6d338dd0fd6bb335a4010b838f5173c6cbf953a
Found module libgio-2.0.so.0 with build-id: 6fb2e9431ef3524f75b1eb28b4ee37aad2405fac
Found module libglib-2.0.so.0 with build-id: 059b1bf3efd0a9ccb2beba9fced88e7f7bc4f6ca
Found module bt-adapter with build-id: 8fbd0701fe633e765f66129d0a4afbf561440ab8
Stack trace of thread 55393:
#0 0x00007f0f87b23d22 raise (libc.so.6 + 0x3cd22)
#1 0x00007f0f87b0d862 abort (libc.so.6 + 0x26862)
#2 0x00007f0f87ee7084 n/a (libglib-2.0.so.0 + 0x1d084)
#3 0x00007f0f87f42c4d g_assertion_message_expr (libglib-2.0.so.0 + 0x78c4d)
#4 0x00005587c7935412 n/a (bt-adapter + 0x9412)
#5 0x00005587c79306ad n/a (bt-adapter + 0x46ad)
#6 0x00007f0f87b0eb25 __libc_start_main (libc.so.6 + 0x27b25)
#7 0x00005587c7930c3e n/a (bt-adapter + 0x4c3e)
Stack trace of thread 55395:
#0 0x00007f0f87bdab2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f0f87f71b39 n/a (libglib-2.0.so.0 + 0xa7b39)
#2 0x00007f0f87f1d693 g_main_loop_run (libglib-2.0.so.0 + 0x53693)
#3 0x00007f0f87e0e8c8 n/a (libgio-2.0.so.0 + 0x1018c8)
#4 0x00007f0f87f4c2d1 n/a (libglib-2.0.so.0 + 0x822d1)
#5 0x00007f0f87a58259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f0f87be55e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 55394:
#2 0x00007f0f87f1b871 g_main_context_iteration (libglib-2.0.so.0 + 0x51871)
#3 0x00007f0f87f1b8c2 n/a (libglib-2.0.so.0 + 0x518c2)
Aug 22 07:14:03 kalachakra systemd-coredump[74177]: Process 74173 (bt-adapter) of user 1000 dumped core.
Stack trace of thread 74173:
#0 0x00007fc54a996d22 raise (libc.so.6 + 0x3cd22)
#1 0x00007fc54a980862 abort (libc.so.6 + 0x26862)
#2 0x00007fc54ad5a084 n/a (libglib-2.0.so.0 + 0x1d084)
#3 0x00007fc54adb5c4d g_assertion_message_expr (libglib-2.0.so.0 + 0x78c4d)
#4 0x0000555751fde412 n/a (bt-adapter + 0x9412)
#5 0x0000555751fd96ad n/a (bt-adapter + 0x46ad)
#6 0x00007fc54a981b25 __libc_start_main (libc.so.6 + 0x27b25)
#7 0x0000555751fd9c3e n/a (bt-adapter + 0x4c3e)
Stack trace of thread 74174:
#0 0x00007fc54aa4db2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007fc54ade4b39 n/a (libglib-2.0.so.0 + 0xa7b39)
#2 0x00007fc54ad8e871 g_main_context_iteration (libglib-2.0.so.0 + 0x51871)
#3 0x00007fc54ad8e8c2 n/a (libglib-2.0.so.0 + 0x518c2)
#4 0x00007fc54adbf2d1 n/a (libglib-2.0.so.0 + 0x822d1)
#5 0x00007fc54a8cb259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007fc54aa585e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 74175:
#2 0x00007fc54ad90693 g_main_loop_run (libglib-2.0.so.0 + 0x53693)
#3 0x00007fc54ac818c8 n/a (libgio-2.0.so.0 + 0x1018c8)
Aug 22 07:26:39 kalachakra systemd-coredump[116388]: Process 116384 (bt-adapter) of user 1000 dumped core.
Stack trace of thread 116384:
#0 0x00007f68b9ae6d22 raise (libc.so.6 + 0x3cd22)
#1 0x00007f68b9ad0862 abort (libc.so.6 + 0x26862)
#2 0x00007f68b9eaa084 n/a (libglib-2.0.so.0 + 0x1d084)
#3 0x00007f68b9f05c4d g_assertion_message_expr (libglib-2.0.so.0 + 0x78c4d)
#4 0x000055c4d40b9412 n/a (bt-adapter + 0x9412)
#5 0x000055c4d40b46ad n/a (bt-adapter + 0x46ad)
#6 0x00007f68b9ad1b25 __libc_start_main (libc.so.6 + 0x27b25)
#7 0x000055c4d40b4c3e n/a (bt-adapter + 0x4c3e)
Stack trace of thread 116386:
#0 0x00007f68b9b9db2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f68b9f34b39 n/a (libglib-2.0.so.0 + 0xa7b39)
#2 0x00007f68b9ee0693 g_main_loop_run (libglib-2.0.so.0 + 0x53693)
#3 0x00007f68b9dd18c8 n/a (libgio-2.0.so.0 + 0x1018c8)
#4 0x00007f68b9f0f2d1 n/a (libglib-2.0.so.0 + 0x822d1)
#5 0x00007f68b9a1b259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f68b9ba85e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 116385:
#2 0x00007f68b9ede871 g_main_context_iteration (libglib-2.0.so.0 + 0x51871)
#3 0x00007f68b9ede8c2 n/a (libglib-2.0.so.0 + 0x518c2)
Systemd Analyze
2min 239ms systemd-networkd-wait-online.service
4.486s NetworkManager-wait-online.service
4.169s [email protected]\x2d4f21562b\x2d460c\x2d422e\x2d838e\x2d008dcae4276e.service
635ms linux-modules-cleanup.service
507ms dev-mapper-luks\x2d2aed9b51\x2d5839\x2d4dc7\x2db7fd\x2d626b0a957268.device
488ms systemd-tmpfiles-clean.service
177ms ldconfig.service
161ms systemd-remount-fs.service
105ms systemd-sysctl.service
71ms [email protected]
52ms lvm2-monitor.service
52ms systemd-modules-load.service
48ms systemd-udev-trigger.service
45ms polkit.service
40ms systemd-journal-flush.service
40ms udisks2.service
39ms systemd-logind.service
37ms systemd-networkd.service
37ms upower.service
35ms ModemManager.service
35ms plymouth-quit-wait.service
34ms plymouth-quit.service
34ms plymouth-deactivate.service
31ms [email protected]
29ms smb.service
26ms systemd-timesyncd.service
25ms avahi-daemon.service
25ms systemd-udevd.service
25ms NetworkManager.service
24ms bluetooth.service
24ms plymouth-start.service
22ms systemd-binfmt.service
18ms systemd-journald.service
17ms [email protected]\x2duuid-20A0\x2d9079.service
17ms nmb.service
17ms systemd-machined.service
15ms systemd-vconsole-setup.service
14ms sys-kernel-config.mount
14ms dev-mapper-luks\x2d4f21562b\x2d460c\x2d422e\x2d838e\x2d008dcae4276e.swap
14ms systemd-sysusers.service
14ms dev-zram0.swap
13ms sys-fs-fuse-connections.mount
13ms systemd-guest-user.service
13ms lm_sensors.service
11ms home.mount
11ms systemd-tmpfiles-setup.service
10ms plymouth-read-write.service
10ms systemd-guest-config.service
8ms boot-efi.mount
8ms cups.service
8ms [email protected]
7ms colord.service
6ms systemd-journal-catalog-update.service
5ms systemd-rfkill.service
5ms dev-binderfs.mount
5ms [email protected]
5ms dev-hugepages.mount
5ms [email protected]\x2d2aed9b51\x2d5839\x2d4dc7\x2db7fd\x2d626b0a957268.service
4ms dev-mqueue.mount
4ms sys-kernel-debug.mount
4ms [email protected]
4ms systemd-tmpfiles-setup-dev.service
4ms sys-kernel-tracing.mount
4ms kmod-static-nodes.service
4ms var-cache.mount
4ms rtkit-daemon.service
3ms dev-loop0.device
3ms srv.mount
3ms [email protected]
3ms var-log.mount
3ms systemd-update-utmp.service
3ms systemd-random-seed.service
3ms root.mount
3ms systemd-user-sessions.service
3ms var-tmp.mount
2ms systemd-update-done.service
1ms wpa_supplicant.service
1ms home-guest.mount
1ms tmp.mount
1ms proc-sys-fs-binfmt_misc.mount
367us snapd.socket
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @2min 2.092s
└─multi-user.target @2min 2.092s
└─smb.service @2min 2.063s +29ms
└─nmb.service @2min 2.044s +17ms
└─network-online.target @2min 2.043s
└─NetworkManager-wait-online.service @6.336s +4.486s
└─NetworkManager.service @6.310s +25ms
└─dbus.service @6.309s
└─basic.target @6.306s
└─sockets.target @6.306s
└─snapd.socket @6.306s +367us
└─sysinit.target @6.303s
└─systemd-update-done.service @6.301s +2ms
└─ldconfig.service @6.122s +177ms
└─local-fs.target @6.122s
└─run-user-1000-doc.mount @45.569s
└─run-user-1000.mount @14.591s
└─swap.target @6.119s
└─dev-mapper-luks\x2d4f21562b\x2d460c\x2d422e\x2d838e\x2d008dcae4276e.swap @6.105s +14ms
└─[email protected]\x2d4f21562b\x2d460c\x2d422e\x2d838e\x2d008dcae4276e.target @6.104s
└─[email protected]\x2d4f21562b\x2d460c\x2d422e\x2d838e\x2d008dcae4276e.service @1.934s +4.169s
└─dev-disk-by\x2duuid-4f21562b\x2d460c\x2d422e\x2d838e\x2d008dcae4276e.device @1.933s
