System freezes after booting
System freezes and becomes irresponsive after booting
Can’t provide garuda-inxi as am. Writing from my phone
Or should I fallback using snapshots?
Does the system work fine if you use a snapshot, or at least long enough for you to get and post your garuda-inxi?
It freezes before I can copy garuda inxi
Here is my garuda-inxi
 ╭─guru@guru in ~
 ╰─λ garuda-inxi
  Kernel: 6.7.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=5e8d113e-4a3d-4c75-b3df-3309f8d4aff8 rw rootflags=subvol=@
  Type: Laptop System: HP product: HP Laptop 15s-gy0xxx
  Mobo: HP model: 87D2 v: 38.28 serial: <superuser required> UEFI: Insyde
    v: F.37 date: 08/22/2023
  ID-1: BAT1 charge: 28.2 Wh (83.2%) condition: 33.9/41.0 Wh (82.5%)
    volts: 13.0 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
  Info: model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
    process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
    microcode: 0x8108109
    L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2448 high: 2600 min/max: 1400/2600 boost: disabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2524 2: 2077
    3: 2594 4: 2600 bogomips: 20760
    vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 69.0 C
  Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.1:3
    chip-ID: 30c9:0035 class-ID: fe01 serial: <filter>
    compositor: Hyprland driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 1
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1526 built: 2019 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 scale: 1 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: AMD
    Radeon Vega 3 Graphics (RADV RAVEN2) driver: mesa radv v: 23.3.3-arch1.1
    device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 23.3.3-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
    bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
    driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.5
  API: ALSA v: k6.7.1-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
    lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
    vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
  Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.3:4
    chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
  Local Storage: total: 238.47 GiB used: 17.75 GiB (7.4%)
    model: MZVLQ256HBJD-00BH1 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: HPS1NFAV temp: 39.9 C scheme: GPT
    used: 17.75 GiB (7.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 5.73 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 70.1 C mobo: N/A gpu: amdgpu temp: 70.0 C
  Processes: 233 Uptime: 0m wakeups: 0 Memory: total: 6 GiB
  available: 5.73 GiB used: 1.81 GiB (31.5%) Init: systemd v: 255
  pm: pacman pkgs: 1311 libs: 405 tools: pamac,paru,yay Shell: fish v: 3.7.0
  running-in: foot inxi: 3.3.31
Garuda (2.6.22-1):
  System install date:     2024-01-03
  Last full system update: 2024-01-24
I would recommend to rollback to previous version through snapshots from the boot menu .
I can advise it because of this :
And then you can check which package was updated , this would help you to detect the culprit .
I am not an expert but this is what I would have might did, if I would have gone into such situation .
Okey
I’m with Ankur. Believe it or not a lot of times when you have an update break something just rolling the system back and redoing the updates fixes the problem.
ya i rolled back and All Fine now
