System freeze while gaming on X11
Hi, I switched to Garuda from Windows in the beginning of this year. My previous experience with Garuda, about a year ago, was great, despite some loss of performance in games. This time though, I’m having serious issues to the point I can’t play anything.
The problem:
After launching any game, through Lutris or Steam, the whole system becomes completely unresponsive and I have to hard reset. It’s random and sometimes happens when I’ve just loaded the game. So far, the only things I know is that my Nvidia GPU is being used, Prime Render Offload is On and Vulcan ICD loader is set to the Nvidia GPU.
Note:
It might or might not be related to another issue I’m having which is why I’m posting it separately. Sometimes, randomly, while playing any game, my CPU usage drops to single digits along with the framerate. Restarting the game does not help. Restarting the PC helps but only sometimes.
Steps I’ve taken to solve the problem:
  1. Using different wine and proton versions with Lutris and Steam respectively.
  2. Setting CPU scaling governor to performance.
  3. Using Feral Gamemode.
  4. Trying with low and high swappiness values.
  5. Setting max map count to 10485776 every time I start the system.
  6. Using DXVK_ASYNC=1 and _GL_SHADER_DISK_CACHE_SKIP_CLEANUP=1 in Lutris environment variables.
  7. Searching for solutions on google and in Lutris and Arch forums. Following the How to improve gaming performace article on the Arch forum.
  8. Adding the following kernel parameter:
    nvidia-drm.modeset=1
  9. I can’t use Wayland because I have massive screen tearing issues on top of everything else.
  10. Tried Manjaro to see if its distro sepecific. Had the same problems.
  11. Completely reinstalled Garuda a week or so ago.
Garuda-inxi output is attached below:
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f4ee0572-7dbd-48a6-abcd-94ddf5660d3f rw rootflags=subvol=@
mitigations=off quiet resume=UUID=1e153a42-e993-464f-add2-e23dff8ab41b
loglevel=3 nvidia-drm.modeset=1 udev.log_priority=3 ibt=off
v: 5.115.0 wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: LENOVO product: 81Y4 v: IdeaPad Gaming 3 15IMH05
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IMH05
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724 WIN
serial: <superuser required> part-nu: LENOVO_MT_81Y4_BU_idea_FM_IdeaPad
Gaming 3 15IMH05 uuid: <superuser required> UEFI: LENOVO v: EGCN41WW
date: 06/09/2023
ID-1: BAT0 charge: 22.8 Wh (54.5%) condition: 41.8/45.5 Wh (91.8%)
volts: 11.6 min: 11.4 model: Sunwoda L19D3PF4 type: Li-poly serial: <filter>
status: not charging cycles: 125
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1249 high: 4398 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 4398 5: 800 6: 800 7: 800 8: 800 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 04f2:b6c2
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2020 res: 1920x1080
ratio: 16:9 modes: 1920x1080
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.1-arch1.1
device-ID: 8086:9bc4 memory: 15 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 24.0.1-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 545.29.06
device-ID: 10de:1f99 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api with: aoss
vendor: Lenovo RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 2.29 TiB used: 622.8 GiB (26.6%)
ID-1: /dev/nvme0n1 maj-min: 259:2 model: PCIe SSD size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: EDFM00.7 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 37.9 C
ID-1: / raw-size: 459.6 GiB size: 459.6 GiB (100.00%)
used: 66.63 GiB (14.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 459.6 GiB size: 459.6 GiB (100.00%)
ID-4: /var/log raw-size: 459.6 GiB size: 459.6 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.6 GiB size: 459.6 GiB (100.00%)
Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 15.36 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.04 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 61.0 C pch: 57.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 4.56 GiB (29.7%)
Processes: 334 Power: uptime: 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.08 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1919 libs: 549 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-02-13
Last full system update: 2024-02-21 ↻
Any and all help is appreciated. Thanks.
Are you running the games with prime-run? This wasn’t very clear by the “what I’ve tried” section. Steam should not be started with it so I’ve read, but you should add this to your launch options per game as:
prime-run %command%
https://wiki.archlinux.org/title/PRIME#PRIME_render_offload
I launch all my games through Lutris and Nvidia Prime Render Offload is enabled. So, I guess when I launch a steam game, Lutris applies the command on those games too?
I’m not a gamer. Just did a quick search out of curiosity:
Do you have this Vulkan ICD loader flag? And can you try to set it to Nvidia or auto?
This seems also consistent with this comment:
https://www.reddit.com/r/linux_gaming/comments/s4lung/comment/icmcpbo/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
Try changing the kernel with this command:
sudo pacman  -S --needed linux linux-headers
Had somewhat same issues as yours , this fixed it.
Also choose advanced options for garuda at your grub boot menu and select one that says garuda linux arch(something like this) different from the zen one.
Yes, Vulcan ICD loader is set to Nvidia Proprietary. Doesn’t help.
