The default font on terminal got reset soon after the update. I used "update". After noticing something wrong with fonts I updated the garuda-update package and updated again. Major problem being steam games (specifically Hitman 3) is stuck at "Preparing to launch". The terminal output for launching the game (includes logs for when at the end I used killall steam)--
$steam steam://run/1659040
steam.sh[112934]: Running Steam on garuda Soaring 64-bit
steam.sh[112934]: STEAM_RUNTIME is enabled automatically
setup.sh[113008]: Steam runtime environment up-to-date!
steam.sh[112934]: Steam client's requirements are satisfied
[2022-02-13 22:58:36] Startup - updater built Feb 10 2022 00:01:58
[2022-02-13 22:58:36] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1644454953)
[2022-02-13 22:58:37] Loading cached metrics from disk (/home/maxsash/.local/share/Steam/package/steam_client_metrics.bin)
[2022-02-13 22:58:37] Using the following download hosts for Public, Realm steamglobal
[2022-02-13 22:58:37] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-02-13 22:58:37] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-02-13 22:58:37] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-02-13 22:58:37] Verifying installation...
[2022-02-13 22:58:37] Verification complete
Loaded SDL version 2.0.21-7056715
Gtk-Message: Failed to load module "gail"
Gtk-Message: Failed to load module "atk-bridge"
(steam:113071): Gtk-WARNING **: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Sweet-Dark/gtk-2.0/main.rc:727: error: unexpected identifier `direction', expected character `}'
/usr/share/themes/Sweet-Dark/gtk-2.0/apps/chrome.rc:50: error: invalid string constant "button", expected valid string constant
/usr/share/themes/Sweet-Dark/gtk-2.0/apps/xfce.rc:79: error: invalid string constant "entry", expected valid string constant
Fontconfig warning: line 5: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-hinting-slight.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 4: unknown element "description"
steamwebhelper.sh[113116]: Runtime for steamwebhelper: defaulting to /home/maxsash/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 72: non-double matrix element
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 80: saw unknown, expected number
Fontconfig warning: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/30-metric-aliases.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/40-nonlatin.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/45-generic.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/45-latin.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/48-spacing.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/49-sansserif.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/60-generic.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/60-latin.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/65-nonlatin.conf", line 4: unknown element "description"
CAppInfoCacheReadFromDiskThread took 82 milliseconds to initialize
(steam:113071): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
Connectivity test: result=Connected, in progress=0
roaming config store loaded successfully - 899 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 24ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/maxsash/.local/share/Steam/ubuntu12_32/steam' 'steam://run/1659040'"
ExecuteSteamURL: "steam://run/1659040"
System startup time: 6.92 seconds
GameAction [AppID 1659040, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
BuildCompleteAppOverviewChange: 170
RegisterForAppOverview 1: 33ms
RegisterForAppOverview 2: 33ms
fsync: up and running.
wine: Using setpriority to control niceness in the [-11,11] range
[2022-02-13 23:05:50] Background update loop checking for update. . .
[2022-02-13 23:05:50] Checking for available updates...
[2022-02-13 23:05:50] Downloading manifest: https://cdn.cloudflare.steamstatic.com/client/steam_client_publicbeta_ubuntu12
[2022-02-13 23:05:51] Download skipped by HTTP 304 Not Modified
[2022-02-13 23:05:51] Nothing to do
GameAction [AppID 1659040, ActionID 2] : LaunchApp changed task to ProcessingInstallScript with ""
src/common/pipes.cpp (885) : stalled cross-thread pipe.
assert_20220213231903_31.dmp[117985]: Uploading dump (out-of-process)
/tmp/dumps/assert_20220213231903_31.dmp
src/clientdll/steamclient.cpp (854) : bufRet.TellPut() == sizeof(uint8)
assert_20220213231903_31.dmp[117985]: Finished uploading minidump (out-of-process): success = yes
assert_20220213231903_31.dmp[117985]: response: CrashID=bp-32629103-e77d-4f05-a5f7-1b67f2220213
assert_20220213231903_31.dmp[117985]: file ''/tmp/dumps/assert_20220213231903_31.dmp'', upload yes: ''CrashID=bp-32629103-e77d-4f05-a5f7-1b67f2220213''
(steam:113071): GLib-GObject-CRITICAL **: g_object_unref: assertion `G_IS_OBJECT (object)' failed
(steam:113071): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(steam:113071): GLib-GObject-CRITICAL **: g_signal_handlers_disconnect_matched: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
[2022-02-13 23:19:11] Shutdown
And the required output
$garuda-inxi
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=14b5ba85-da2d-4b2f-aec3-377828fbf8f2 rw [email protected]
resume=UUID=c89d66a2-1b16-4335-8b70-12db95fa2e27 loglevel=3
Desktop: N/A wm: xmonad 0.15 vt: 1 dm: SDDM Distro: Garuda Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IV_FA566IV
Mobo: ASUSTeK model: FA506IV v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FA506IV.316 date: 03/12/2021
ID-1: BAT1 charge: 23.9 Wh (31.8%) condition: 75.1/90.2 Wh (83.2%)
volts: 14.4 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: Discharging
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1449 high: 1780 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1629 2: 1395
3: 1421 4: 1356 5: 1336 6: 1391 7: 1572 8: 1346 9: 1392 10: 1343 11: 1659
12: 1396 13: 1397 14: 1780 15: 1381 16: 1397 bogomips: 92623
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: picom v: git-c4107
driver: loaded: modesetting display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.8-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:1637
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000
bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
Device-3: Lite-On Dell Wireless Mouse WM118 type: USB
driver: hid-generic,usbhid bus-ID: 3-3:2 chip-ID: 04ca:00a8 class-ID: 0301
Device-1: Lite-On Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 5-1:2 chip-ID: 04ca:4005 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 953.87 GiB used: 199.47 GiB (20.9%)
model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21106000 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 423.83 GiB size: 423.83 GiB (100.00%)
used: 199.45 GiB (47.1%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 25.8 MiB (10.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 423.83 GiB size: 423.83 GiB (100.00%)
ID-4: /var/log raw-size: 423.83 GiB size: 423.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 423.83 GiB size: 423.83 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.63 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: swap-2 type: zram size: 15.11 GiB used: 3.2 MiB (0.0%)
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): cpu: 2200
Processes: 795 Uptime: 3h 15m wakeups: 1 Memory: 15.11 GiB
used: 6.73 GiB (44.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1657 lib: 364 Shell: fish
v: 3.3.1 running-in: kitty inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2021-09-04
Last full system update: 2022-02-13
Snapshots: Timeshift
