Hello Garuda Forum
Please go easy on me
System: Kernel: 5.12.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-07-02_00-18-49/@/boot/vmlinuz-linux-zen
root=UUID=3da14aaf-cef6-4bda-9bc1-b175d6ed4910 quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
resume=UUID=4019ab13-02ed-4dc3-892e-81ce8c46b230 loglevel=3
rootflags=defaults,noatime,space_cache,autodefrag,compress=zstd,subvol=timeshift-btrfs/snapshots/2021-07-02_00-18-49/@
Desktop: KDE Plasma 5.22.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: <filter>
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <filter> UEFI: American Megatrends LLC.
v: F33c date: 02/17/2021
CPU: Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: 0 microcode: 8701021 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 182055
Speed: 3592 MHz min/max: 2200/3800 MHz boost: disabled Core speeds (MHz): 1: 3592 2: 3596
3: 3587 4: 3587 5: 3584 6: 3596 7: 3591 8: 3588 9: 3201 10: 3572 11: 3657 12: 3590 13: 3592
14: 3372 15: 3586 16: 3581 17: 3620 18: 3597 19: 3594 20: 3588 21: 3667 22: 3040 23: 3033
24: 3584
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI driver: nvidia v: 465.31
alternate: nouveau,nvidia_drm bus-ID: 08:00.0 chip-ID: 10de:1b82 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.6x11.5") s-diag: 600mm (23.6")
Monitor-1: DVI-D-0 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 08:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech [G533 Wireless Headset Dongle] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:3 chip-ID: 046d:0a66 class-ID: 0300
Sound Server-1: ALSA v: k5.12.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Network: Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel port: f000
bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
Drives: Local Storage: total: 931.51 GiB used: 651.49 GiB (69.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-ASM2NE6100TTTD size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: EGFM13.0 scheme: GPT
Partition: ID-1: / raw-size: 914.06 GiB size: 914.06 GiB (100.00%) used: 651.49 GiB (71.3%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 914.06 GiB size: 914.06 GiB (100.00%) used: 651.49 GiB (71.3%) fs: btrfs
ID-4: /var/log raw-size: 914.06 GiB size: 914.06 GiB (100.00%) used: 651.49 GiB (71.3%)
ID-5: /var/tmp raw-size: 914.06 GiB size: 914.06 GiB (100.00%) used: 651.49 GiB (71.3%)
ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 666.9 MiB used: 21.2 MiB (3.2%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 666.9 MiB used: 19.3 MiB (2.9%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 666.9 MiB used: 19.2 MiB (2.9%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 666.9 MiB used: 17.6 MiB (2.6%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 666.9 MiB used: 17.7 MiB (2.7%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 666.9 MiB used: 21 MiB (3.2%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 666.9 MiB used: 17.4 MiB (2.6%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 666.9 MiB used: 17.5 MiB (2.6%) priority: 32767 dev: /dev/zram7
ID-10: swap-10 type: zram size: 666.9 MiB used: 17.6 MiB (2.6%) priority: 32767 dev: /dev/zram8
ID-11: swap-11 type: zram size: 666.9 MiB used: 18.9 MiB (2.8%) priority: 32767 dev: /dev/zram9
ID-12: swap-12 type: zram size: 666.9 MiB used: 17.5 MiB (2.6%) priority: 32767
dev: /dev/zram10
ID-13: swap-13 type: zram size: 666.9 MiB used: 19.5 MiB (2.9%) priority: 32767
dev: /dev/zram11
ID-14: swap-14 type: zram size: 666.9 MiB used: 17.9 MiB (2.7%) priority: 32767
dev: /dev/zram12
ID-15: swap-15 type: zram size: 666.9 MiB used: 17.1 MiB (2.6%) priority: 32767
dev: /dev/zram13
ID-16: swap-16 type: zram size: 666.9 MiB used: 18.7 MiB (2.8%) priority: 32767
dev: /dev/zram14
ID-17: swap-17 type: zram size: 666.9 MiB used: 18.4 MiB (2.8%) priority: 32767
dev: /dev/zram15
ID-18: swap-18 type: zram size: 666.9 MiB used: 16.3 MiB (2.4%) priority: 32767
dev: /dev/zram16
ID-19: swap-19 type: zram size: 666.9 MiB used: 17.7 MiB (2.7%) priority: 32767
dev: /dev/zram17
ID-20: swap-20 type: zram size: 666.9 MiB used: 19.7 MiB (3.0%) priority: 32767
dev: /dev/zram18
ID-21: swap-21 type: zram size: 666.9 MiB used: 17.8 MiB (2.7%) priority: 32767
dev: /dev/zram19
ID-22: swap-22 type: zram size: 666.9 MiB used: 20.8 MiB (3.1%) priority: 32767
dev: /dev/zram20
ID-23: swap-23 type: zram size: 666.9 MiB used: 18.3 MiB (2.7%) priority: 32767
dev: /dev/zram21
ID-24: swap-24 type: zram size: 666.9 MiB used: 20.3 MiB (3.0%) priority: 32767
dev: /dev/zram22
ID-25: swap-25 type: zram size: 666.9 MiB used: 20.2 MiB (3.0%) priority: 32767
dev: /dev/zram23
Sensors: System Temperatures: cpu: 36.2 C mobo: 16.8 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 44%
Info: Processes: 466 Uptime: 5m wakeups: 0 Memory: 15.63 GiB used: 3.39 GiB (21.7%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: apt: 0 pacman: 1645 lib: 488
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
I am a newbie to Linux (windows for 20 years) and Garuda is my first distro, I am running 2 machines that I built and I have been doing ok over the last 12 months learning as I go, and usually I am able to resolve any issues I encounter.
For the last month or so my second PC , would not load after the latest updates, so I used a snapshot to restore then I would update again and the same issue would return - stuck at loading. I have been putting off fixing this, but I couldn't leave it...
So today after loading the latest snapshot I used the commands
sudo mkinitcpio -P
sudo grub-mkconfig -o /boot/grub/grub.cfg
And rebooted.
I think I have made the problem worse and now the recent snapshots will not load at all - only the oldest one, which is over 5 months old and now there is no network ....
I'm not sure where to start any assistance would be appreciated.
EDIT: To be clear - I have been trying to fix this for weeks, and I am ok with that - I was able to load any snapshot before today but now I think I have made it worse, and so decided to ask for help.
