System Error when installing steam (native and runtime) with Garuda Gamer
I am trying to install steam using Garuda Gamer but getting error (image below, Please note that, the choices are made by the installer )
I cannot uninstall pipewire-jack as it is a requirement for other applications (see below)
checking dependencies...
:: removing pipewire-jack breaks dependency 'jack' required by blender
:: removing pipewire-jack breaks dependency 'jack' required by ffmpeg
:: removing pipewire-jack breaks dependency 'jack' required by ffmpeg4.4
:: removing pipewire-jack breaks dependency 'libjack.so=0-64' required by fluidsynth
:: removing pipewire-jack breaks dependency 'libjack.so=0-64' required by gst-plugins-good
:: removing pipewire-jack breaks dependency 'libjack.so=0-64' required by jconvolver
:: removing pipewire-jack breaks dependency 'jack' required by mpv
:: removing pipewire-jack breaks dependency 'libjack.so=0-64' required by mpv
:: removing pipewire-jack breaks dependency 'pipewire-jack' required by pipewire-support
:: removing pipewire-jack breaks dependency 'libjack.so=0-64' required by portaudio
Please suggest.
System Details
λ garuda-inxi
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=72e23d88-8130-4ae8-a6b4-adfbeeda5cce rw rootflags=subvol=@
resume=UUID=049e793a-538f-4728-a9bc-f42fcdf169c7 loglevel=3
Type: Desktop System: LENOVO product: 90RC00M1IN v: Legion T5 26AMR5
Mobo: LENOVO model: 3716 v: SDK0T76485 WIN 3424259781840
serial: <superuser required> UEFI: LENOVO v: O4MKT23A date: 09/03/2021
Info: model: AMD Ryzen 7 5800 bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3629 high: 3846 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3807 2: 3621
3: 3846 4: 3586 5: 3590 6: 3595 7: 3605 8: 3590 9: 3615 10: 3593 11: 3590
12: 3590 13: 3588 14: 3689 15: 3589 16: 3584 bogomips: 108588
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: Lenovo
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Ampere pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 06:00.0 chip-ID: 10de:2488 class-ID: 0300
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.40x13.46")
s-diag: 1252mm (49.28")
Monitor-1: DP-0 pos: primary,right res: 2560x1440 hz: 144 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1440 hz: 60 dpi: 109
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: NVIDIA GA104 High Definition Audio vendor: Lenovo
bus-ID: 06:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Lenovo
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
bus-ID: 1-10:5 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Local Storage: total: 3.88 TiB used: 89.51 GiB (2.3%)
model: PC SN730 SDBQNTY-512G-1001 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11170101 temp: 49.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0002 scheme: GPT
model: WD7500BPKT-75PK4T0 size: 698.64 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-1: / raw-size: 681.24 GiB size: 681.24 GiB (100.00%)
used: 89.51 GiB (13.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 580 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 681.24 GiB size: 681.24 GiB (100.00%)
ID-4: /var/log raw-size: 681.24 GiB size: 681.24 GiB (100.00%)
ID-5: /var/tmp raw-size: 681.24 GiB size: 681.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 254.8 MiB (1.6%)
ID-2: swap-2 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 377 Uptime: 1h 37m wakeups: 0 Memory: 15.55 GiB
used: 4.63 GiB (29.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1558 lib: 381 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date:     2022-01-22
Last full system update: 2022-05-21 ↻
Failed units:~~~
Can you install lib32-pipewire-jack before running the installer?
sudo pacman -S lib32-pipewire-jack
This means a reboot is required after upgrade
Also, please do not include pictures of terminal outputs as it is simply a waste of forum bandwidth and is highly discouraged on help requests.
