Hello everyone.
As the tittle says, I have been experiencing crashes when the monitors turn off for power saving. I think it has been so for the last month. After a while with the monitors off, the HDD led starts blinking regularly and when I use the mouse or keyboard to bring the system back, I am greeted by a frozen desktop screen.
Any help will be appreciated.
Note: I have Kscreen disabled as workaround for a previous problem. It had work for months without problems, but I thought that it would be worth mentioning
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=810cddd0-3d54-45f7-88fa-84f8b12b1038 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-I GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4901
date: 07/25/2022
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3884 high: 4125 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4125 2: 3600
3: 3600 4: 3600 5: 4093 6: 4100 7: 4091 8: 4099 9: 3600 10: 4107 11: 4109
12: 4122 13: 3600 14: 3600 15: 3600 16: 4099 bogomips: 115196
protection
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 09:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1:2 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-right
model: MSI MAG274QRF-QD serial: <filter> built: 2021 res: 2560x1440 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 640x480
Monitor-2: DP-3 mapped: DisplayPort-2 pos: bottom-l model: AOC 2590G4
serial: <filter> built: 2019 res: 1920x1080 dpi: 90 gamma: 1.2
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 5700 (navi10 LLVM
14.0.6 DRM 3.48 6.0.8-zen1-1-zen) direct render: Yes
bus-ID: 1-1:2 chip-ID: 046d:0825 gen: 4 class-ID: 0102 speed: 16 GT/s
serial: <filter> lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab38
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: Logitech G432 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 046d:0a9c
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-8:5 chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Local Storage: total: 1.84 TiB used: 1.49 TiB (80.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 type: SSD serial: <filter> rev: S0118C temp: 32.9 C scheme: GPT
model: WD10SPZX-00Z10T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
used: 699.5 GiB (73.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 39.0 C mobo: 52.0 C gpu: amdgpu temp: 56.0 C
mem: 60.0 C
Fan Speeds (RPM): cpu: 656 case-1: 705 gpu: amdgpu fan: 0
Power: 12v: 9.97 5v: N/A 3.3v: N/A vbat: 3.23 gpu: amdgpu watts: 32.00
Processes: 394 Uptime: 11m wakeups: 0 Memory: 15.54 GiB
used: 4.09 GiB (26.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2004
pm: pacman pkgs: 1996 libs: 572 tools: octopi,paru pm: flatpak pkgs: 8
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-06-25
Last full system update: 2022-11-18 ↻
Failed units: mnt-sr0.mount fancontrol.service NetworkManager-wait-online.service
