##: I have been facing a issue while using pytorch in amd gpu here is my system conf
╭─alex@SoulHunter in ~
╰─λ garuda-inxi
LANGUAGE = "en_US",
LC_ALL = (unset),
LC_ADDRESS = "en_IN",
LC_NAME = "en_IN",
LC_MONETARY = "en_IN",
LC_PAPER = "en_IN",
LC_IDENTIFICATION = "en_IN",
LC_TELEPHONE = "en_IN",
LC_MEASUREMENT = "en_IN",
LC_TIME = "en_IN",
LC_NUMERIC = "en_IN",
LANG = "en_US"
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.6.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b84458b7-4f8b-4429-a689-c2987ea435d5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: A320M-S2H v: N/A
Mobo: Gigabyte model: A320M-S2H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F53 date: 01/05/2021
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 3297 high: 3693 min/max: 1600/3525 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3684 2: 2854
3: 2960 4: 3693 bogomips: 28146
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 07:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 46.0 C
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: 24HC1QR serial: <filter>
built: 2020 res: 1920x1080 hz: 120 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 600mm (23.6") ratio: 16:9, 15:9
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 16.0.6 DRM 3.54 6.6.9-zen1-1-zen)
device-ID: 1002:15dd memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.274 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.3.2-arch1.2
device-ID: 1002:15dd surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: C-Media USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 0d8c:0012 class-ID: 0300
API: ALSA v: k6.6.9-zen1-1-zen status: kernel-api with: aoss
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 599.85 GiB used: 219.96 GiB (36.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT3500SC 6
CTB5029G21Y034 size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: A52B
ID-2: /dev/sdb maj-min: 8:16 model: SSD 128GB size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: XKR scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 model: MXT-USB Storage Device size: 14.84 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1109 scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 41.26 GiB (34.7%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.59 GiB used: 282.2 MiB (2.0%)
System Temperatures: cpu: 45.9 C mobo: 25.0 C gpu: amdgpu temp: 45.0 C
Processes: 302 Uptime: 36m wakeups: 0 Memory: total: 16 GiB note: est.
available: 13.59 GiB used: 4.7 GiB (34.6%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1685 libs: 503 tools: octopi,paru Shell: fish
v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-03
Last full system update: 2024-01-03
So here is the things which was i did to my system to face that provlem
step 1 : Follow this instruction to setup the voice changer
step 2 : i searched for ROCm driver and i came up with installing this from aur repo
step 3 : i also did this pip3 install --force-reinstall torch-2.0.1+rocm5.7-cp310-cp310-linux_x86_64.whl torchvision-0.15.2+rocm5.7-cp310-cp310-linux_x86_64.whl
to install amd supported onix model to get the gpu acceleration with voice changer but i came up with tis issue the sysem was just crashed so i unable to upload the logs
here is the video
if this not work use this
https://github.com/ALEX5402/minecraft-docker/releases/download/alex/video_2024-01-03_18-47-50.mp4
