System consumes so much battery!
After a fresh install of the system, I noticed it consumes so much battery compared to windows 11 which i was using prior to this system. I was using the machine mainly for basic tasks like web browsing and noticed that the drain is so high and the battery barely lasts 2 hours of usage while in windows this usage scenario will take over 4 hours for the battery to run out. I tried to put the performance profile on battery saver but this did not help out a lot. here is the output of garuda-inxi:
Kernel: 6.6.33-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=1c11ac10-7b61-4305-a54b-4b4fd8bc9e81 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: Razer product: Blade Pro 17 (Early 2021) - RZ09-0368
v: 6.04 serial: <filter> Chassis: type: 10 serial: N/A
Mobo: Razer model: DA760 v: 4 serial: N/A part-nu: RZ09-0368AEA2
uuid: 65633565-6561-6466-3339-353434383236 UEFI: Razer v: 1.01
date: 01/05/2021
ID-1: BAT0 charge: 59.6 Wh (91.4%) condition: 65.2/70.6 Wh (92.5%)
volts: 16.4 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
Info: model: Intel Core i7-10875H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xFA
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5100 base/boost: 2178/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800 bogomips: 73625
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Razer USA
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Razer USA driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm
non-free: 550.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
active: none empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:2 chip-ID: 13d3:56d5
Display: server: X.Org v: 24.1 with: Xwayland v: 24.1.0
display-ID: :1 screens: 1
s-diag: 777mm (30.58")
Monitor-1: eDP-1 model: BOE Display 0x09d9 built: 2020 res: 2560x1440
hz: 60 dpi: 171 gamma: 1.2 size: 380x210mm (14.96x8.27") diag: 437mm (17.2")
ratio: 16:9 modes: 2560x1440
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1
device-ID: 8086:9bc4 memory: 7.56 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.90.07
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
Device-2: NVIDIA GA106 High Definition Audio vendor: Razer USA
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
API: ALSA v: k6.6.33-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.7 status: n/a (root, process) with:
Device-1: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 3d:00.0
IF: enp61s0 state: down mac: <filter>
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3f:00.0
IF: wlp63s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0032
Local Storage: total: 1.38 TiB used: 813.04 GiB (57.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVMe CA5-8D512 size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: CQ20904 temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 110d 1h cycles: 3,106
read-units: 46,686,969 [23.9 TB] written-units: 43,677,450 [22.3 TB]
ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 41.9 C
SMART: yes health: PASSED on: 14d 0h cycles: 2,830
read-units: 12,757,244 [6.53 TB] written-units: 10,380,741 [5.31 TB]
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 16.14 GiB (32.3%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:7
used: 96 MiB (100.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 50 GiB size: 50 GiB (100.00%)
used: 16.14 GiB (32.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
maj-min: 259:7
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%)
maj-min: 259:7
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C pch: 52.0 C mobo: N/A
Memory: total: 16 GiB available: 15.48 GiB used: 4.59 GiB (29.6%)
igpu: 32 MiB
Processes: 351 Power: uptime: 1h 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1403 libs: 415 tools: octopi,pamac,paru
Compilers: gcc: 14.1.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date:     2024-06-16
Last full system update: 2024-06-17
Windows dual boot:       Yes
Check
you mean I should check or uncheck the highlighted options?
Do not use performance settings on battery, so use energy save settings.
You are the admin, try the settings by yourself, please.
Maybe you find more about in the WWW :slight_smile:
Here’s a useful video about using Intel Undervolt:
Note: this video suggests undervolting by 100mv. I found this too much and it caused errors. An 80mv undervolt worked for me.
  Kernel: 6.6.33-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
    root=UUID=f60f6675-0606-42d7-9815-e0fbe7be0409 rw rootflags=subvol=@ quiet
    resume=UUID=d807950b-e01b-4ea5-b73f-d50f5ae401e3 loglevel=3 ibt=off
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0 with: xfce4-panel
    tools: xfce4-screensaver avail: xautolock vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA v: 1.0
  Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends LLC. v: X513UA.312 date: 04/26/2022
  ID-1: BAT0 charge: 20.5 Wh (59.4%) condition: 34.5/42.1 Wh (82.0%) power: 10.5 W volts: 11.8
    min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 799
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
    desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 815 high: 1398 min/max: 400/4056 scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 1398 2: 1397 3: 1397 4: 400 5: 1397 6: 400 7: 400 8: 400 9: 400
    10: 400 11: 1397 12: 400 bogomips: 50325
  Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
    class-ID: 0300 temp: 39.0 C
  Device-2: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4161 built: 2020 res: 1920x1080 hz: 60 dpi: 142
    gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080
    min: 640x480
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: AMD Radeon Graphics
    (RADV RENOIR) driver: mesa radv v: 24.1.1-arch1.1 device-ID: 1002:164c surfaces: xcb,xlib
    device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
    v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
  Server-1: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725 class-ID: 0280
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0032 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
    hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12 status: discoverable: yes
    pairing: yes
  Local Storage: total: 710.19 GiB used: 33.28 GiB (4.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB
    fw-rev: FXV7101Q temp: 26.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1 size: 233.25 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
    serial: <filter> fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 156.25 GiB size: 156.25 GiB (100.00%) used: 20.19 GiB (12.9%) fs: btrfs
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 584 KiB (0.1%) fs: vfat
  ID-3: /home raw-size: 312.18 GiB size: 312.18 GiB (100.00%) used: 13.08 GiB (4.2%) fs: btrfs
  ID-4: /var/log raw-size: 156.25 GiB size: 156.25 GiB (100.00%) used: 20.19 GiB (12.9%)
  ID-5: /var/tmp raw-size: 156.25 GiB size: 156.25 GiB (100.00%) used: 20.19 GiB (12.9%)
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
    maj-min: 259:3
  ID-2: swap-2 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
  System Temperatures: cpu: 41.1 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (rpm): cpu: 0
  Memory: total: 8 GiB note: est. available: 7.15 GiB used: 4.12 GiB (57.5%)
  Processes: 368 Power: uptime: 8h 11m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 4 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 2.85 GiB
    services: power-profiles-daemon, upowerd, xfce4-power-manager Init: systemd v: 255
  Packages: pm: pacman pkgs: 1375 libs: 435 tools: paru Compilers: gcc: 14.1.1
    Client: shell wrapper v: 5.2.26-release inxi: 3.3.34
  System install date:     2024-01-29
  Last full system update: 2024-06-17 ↻
I tried to activate it in the garuda settings. Still, all I can manage to get from battery is around 2 hours while I get around 5-6 hours from other arch based distros with KDE as well. I tried using other kernels but still no significant change. This really disappoint me and can be the reason I stop using the OS although I really like the look and the fell.
Undervolting has to be done as specified in the video.
I’ve had a look at your CPU specs and I see it is 45W TDP.
The Intel CPU in my XFCE laptop is 15W TDP. It is undervolted as stated above and uses a lightweight version of Garuda, but I have not been able to get close to 6 hours use on a single battery charge.
You mention that you have got 5 - 6 hours on other arch based distros with KDE. What versions of Linux did you previously use?
  Kernel: 6.6.35-2-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
    avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
    root=UUID=8c7f54ca-199b-422c-8c18-84494c3fff8f rw rootflags=subvol=@ quiet
    resume=UUID=4b9834d1-7245-4d66-9099-911c44f1565f loglevel=3 ibt=off
  Type: Laptop System: LENOVO product: 20L50000UK v: ThinkPad T480 serial: <superuser required>
    Chassis: type: 10 serial: <superuser required>
  Mobo: LENOVO model: 20L50000UK v: SDK0J40697 WIN serial: <superuser required>
    part-nu: LENOVO_MT_20L5_BU_Think_FM_ThinkPad T480 uuid: <superuser required> UEFI: LENOVO
    v: N24ET75W (1.50 ) date: 10/30/2023
  ID-1: BAT0 charge: 12.9 Wh (77.2%) condition: 16.7/24.0 Wh (69.6%) volts: 11.7 min: 11.5
    model: LGC 01AV421 type: Li-poly serial: <filter> status: not charging cycles: 6
  ID-2: BAT1 charge: 5.8 Wh (28.2%) condition: 20.6/23.9 Wh (86.0%) power: 5.0 W volts: 10.8
    min: 11.4 model: LGC 01AV490 type: Li-poly serial: <filter> status: discharging cycles: 231
  Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake gen: core 8 level: v3
    note: check built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
    microcode: 0xF4
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 836 high: 1101 min/max: 400/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1100 2: 1101 3: 1100 4: 400 5: 1100 6: 400 7: 400 8: 1089
    bogomips: 28808
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: Bison SunplusIT Integrated Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 5986:2113 class-ID: 0e02
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Monitor-1: eDP-1 model: BOE Display 0x0791 built: 2017 res: 1920x1080 hz: 60 dpi: 158
    gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: Intel UHD Graphics 620
    (KBL GT2) driver: mesa intel v: 24.1.2-arch1.1 device-ID: 8086:5917 surfaces: xcb,xlib
    v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480 driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.6.35-2-lts status: kernel-api tools: N/A
  Device-1: Intel Ethernet I219-V vendor: Lenovo ThinkPad T480 driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
  Info: ser
vices: NetworkManager, systemd-timesyncd, wpa_supplicant
  Local Storage: total: 238.47 GiB used: 10.79 GiB (4.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L size: 238.47 GiB
    fw-rev: L15P temp: 25.9 C scheme: GPT
  ID-1: / raw-size: 221.11 GiB size: 221.11 GiB (100.00%) used: 10.79 GiB (4.9%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 221.11 GiB size: 221.11 GiB (100.00%) used: 10.79 GiB (4.9%) fs: btrfs
  ID-4: /var/log raw-size: 221.11 GiB size: 221.11 GiB (100.00%) used: 10.79 GiB (4.9%) fs: btrfs
  ID-5: /var/tmp raw-size: 221.11 GiB size: 221.11 GiB (100.00%) used: 10.79 GiB (4.9%) fs: btrfs
  ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2
  ID-2: swap-2 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
  System Temperatures: cpu: 39.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.52 GiB used: 2.65 GiB (17.1%)
  Processes: 255 Power: uptime: 2h 24m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 6.19 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1328 libs: 412 tools: paru Compilers: gcc: 14.1.1
    Client: shell wrapper v: 5.2.26-release inxi: 3.3.35
  System install date:     2024-03-15
  Last full system update: 2024-06-23
  Relevant software:       snapper tlp NetworkManager dracut
