System constantly freezes for some seconds
Hello! My system constantly freezes at intervals, irrespective of the application I’m in - browser, KWrite, VLC - while the hard drive seems to be actively working.
Strangely, while I type in KWrite, and the system freezes, if i keep typing, when the “spell” is over, the text appears in its entirety, so I guess the system works in the background as it is obvious that it records the input.
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=3b12eb2c-8483-407c-8d5e-e3753bb0f932 rw rootflags=subvol=@
quiet rd.luks.uuid=9ef8855a-d41e-4e3b-860a-eca23739126c quiet
rd.luks.uuid=fd6ddec5-eac7-4ca8-8815-d373d6d7aa1e
resume=/dev/mapper/luks-fd6ddec5-eac7-4ca8-8815-d373d6d7aa1e loglevel=3
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: SAMSUNG product: 300V3Z/300V4Z/300V5Z v: 0.1
serial: <superuser required> Chassis: type: 9 v: 0.1
Mobo: SAMSUNG model: 300V3Z/300V4Z/300V5Z v: FAB1
serial: <superuser required> uuid: <superuser required> UEFI: Phoenix
v: 00FU date: 07/05/2011
Info: model: Intel Core i3-2310M bits: 64 type: MT MCP arch: Sandy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1149 high: 2100 min/max: 800/2100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 898 2: 2100 3: 800
4: 798 bogomips: 16762
vendor: Samsung Co driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: VGA-1 off: LVDS-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: Silicon Motion WebCam SCB-1100N driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:3
chip-ID: 2232:1008 class-ID: 0e02
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: 0
Monitor-1: VGA-1 res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
drv: crocus x11: drv: crocus
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) device-ID: 8086:0116 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM 18.1.8)
vendor: Samsung Co driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
Device-1: Intel Centrino Wireless-N 130 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:0896
vendor: Samsung Co driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.3:3
chip-ID: 8086:0189 class-ID: e001
rfk-block: hardware: no software: yes address: <filter> bt-v: 3.0 lmp-v: 5
Local Storage: total: 465.76 GiB used: 349.5 GiB (75.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HN-M500MBB
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 457.23 GiB size: 457.23 GiB (100.00%)
used: 349.5 GiB (76.4%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-9ef8855a-d41e-4e3b-860a-eca23739126c
used: 728 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 457.23 GiB size: 457.23 GiB (100.00%)
ID-4: /var/log raw-size: 457.23 GiB size: 457.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 457.23 GiB size: 457.23 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.0 C mobo: N/A
Memory: total: 8 GiB available: 7.67 GiB used: 2.46 GiB (32.1%)
Processes: 218 Power: uptime: 1h 36m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 3.05 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1398 libs: 384 tools: octopi,paru,trizen
Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.32
System install date:     2024-08-25
Last full system update: 2024-08-26
Have you tried using the LTS kernel and seeing if the issue persists?
I’m a simple, GUI Linux user. Don’t know how to do that. Can’t it be seen, as output to some command, which process might cause the glitches?
In terminal
sudo pacman -Suy linux-lts linux-lts-headers
Reboot, use advanced in grub menu and use the lts kernel.
Thank you! I did as instructed.
Apparently, it solved the issue. Will have to test it for a few more days.
Can you, please, instruct me on how to make it default, so as not to have to select it every time I boot?
sudo garuda-boot-options
Summary
:wink:
Done!
Thank you!
From the FAQ
Rather than posting “Thank you”, “+1” or “Agreed”, use the like button :heart: . :slight_smile:
