Hello,
So I'm still trying to install Garuda Linux KDE Dragonized Gaming Edition, after a while of attempting with different versions of differents date from this url.
Though on every bootup it seems I encounter the same things, where booting with NVIDIA drivers displays nothing but keep the computer alive (can toggle numlock for exemple).
Attempting to boot open sourced drivers leads to the computer completely freezing (can't even toggle numlock for keyboard)
The only thing I seemingly manage to boot up is the xfce version, so here is my garuda-inxi
from there:
Kernel: 6.1.32-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=1eb3e87d-0348-4dbe-9033-c9d944c1ca50 rw rootflags=subvol=@
loglevel=3 ibt=off
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MPG Z490 GAMING EDGE WIFI (MS-7C79)
v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.70 date: 04/19/2021
Info: model: Intel Core i7-10700K socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 5
microcode: 0xF6
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3954 high: 5063 min/max: 800/5100 base/boost: 3762/8300
scaling: driver: intel_pstate governor: performance volts: 0.9 V
ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 5063 4: 3800 5: 5001 6: 3800
7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800 13: 3800 14: 3800
15: 3800 16: 3800 bogomips: 121639
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: none empty: DP-1, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:9bc5 class-ID: 0380
Device-2: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2484 class-ID: 0300
Device-3: HP HP Webcam HD 4310
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:4 chip-ID: 03f0:e807
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
dri: iris gpu: i915,nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DP-0 pos: right res: 1920x1080 hz: 60 dpi: 93
Monitor-2: DP-2 pos: primary,left res: 1920x1080 hz: 60 dpi: 93
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
API: ALSA v: k6.1.32-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.71 status: n/a (root, process) with:
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0026
Local Storage: total: 4.58 TiB used: 17.31 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 39.9 C
SMART: yes health: PASSED on: 81d 13h cycles: 1,603
read-units: 50,570,632 [25.8 TB] written-units: 28,956,904 [14.8 TB]
model: WD20EURS-63S48Y0 family: AV-GP (AF) size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: N/A
serial: <filter> fw-rev: AB51 temp: 37 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 5y 22d 22h cycles: 1635
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: 0001 temp: 44 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 7713h+43m+53.915s
cycles: 1983 read: 15.88 TiB written: 18.44 TiB Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-4: /dev/sdc maj-min: 8:32 model: USB Disk 2.0 size: 29 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
ID-1: / raw-size: 468.75 GiB size: 468.75 GiB (100.00%)
used: 17.28 GiB (3.7%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 30.8 MiB (32.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 468.75 GiB size: 468.75 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 468.75 GiB size: 468.75 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 468.75 GiB size: 468.75 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C pch: 45.0 C mobo: N/A gpu: nvidia
temp: 43 C
Processes: 403 Uptime: 6m wakeups: 0 Memory: available: 31.2 GiB
used: 2.77 GiB (8.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1925 libs: 420 tools: pamac,paru pm: flatpak pkgs: 0
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.27
System install date: 2023-06-06
Last full system update: 2023-06-06
Windows dual boot: Yes
I am however unhappy with this setup as I said, I am wishing to have KDE on my system, I am guessing the issue is from the Zen kernel (as KDE runs fine on Manjaro, which I previously tried but broke itself) and since xfce is the only one that runs fine, and the only difference being instead of Zen, it uses LTS.
I have seen a previous thread that linked a LTS version of Garuda Dragonized, however it seems it got removed.
I'm looking for support to either manage to make the Zen kernel work on KDE Dragonized Gaming Edition, or to update the xfce version to be the KDE Dragonized Gaming Edition but with LTS kernel (not asking to keep both, just want to keep the KDE DE).
Thanks for the upcoming support
