System broken on wifi drivers rtw88-dkms-git
Hello, recently only working drivers for my laptop stop upgrading. Now when I install rtw88-dkms-git my system is broken. On lts kernel I got freeze after few minutes working and on zen kenrel wifi stop working and apps stop to launch. It’s possible to install some old version of rtw88-fixed-dkms-git drivers?
That are full diagnostics from Rani:
Regards
Last logs when system freeze when I start Pika backup:
╰─λ journalctl --since=“10 minutes ago” | grep -i error
sie 06 15:26:29 emilka-matebook gnome-session-binary\[2228\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2501: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:26:29 emilka-matebook gnome-session\[2228\]: gnome-session-binary\[2228\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2501: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:26:29 emilka-matebook gnome-session\[2228\]: gnome-session-binary\[2228\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2511: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:26:29 emilka-matebook gnome-session-binary\[2228\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2511: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:26:29 emilka-matebook gsd-usb-protect\[2420\]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
sie 06 15:26:29 emilka-matebook gnome-shell\[2249\]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
sie 06 15:26:32 emilka-matebook gnome-shell\[2970\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:26:33 emilka-matebook xdg-document-po\[1997\]: Error releasing name org.freedesktop.portal.Documents: Połączenie jest zamknięte
sie 06 15:26:33 emilka-matebook gnome-shell\[3043\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:26:33 emilka-matebook gsd-xsettings\[3041\]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
sie 06 15:26:34 emilka-matebook pika-backup-mon\[2520\]: src/daemon/init.rs:63:0: Error setting background status: Portal(NotAllowed(“Only sandboxed applications can set background status”))
sie 06 15:27:02 emilka-matebook syncthing.desktop\[2485\]: \[UUABL\] 2025/08/06 15:27:02 INFO: Lost primary connection to YOYM47H at 192.168.0.109:22000-192.168.0.208:22000/quic-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P20-62P61OJN7GSEUBMQEMQHGSSLG8: reading length: Application error 0x0 (remote): closing (1 remain)
sie 06 15:28:06 emilka-matebook pipewire\[2780\]: mod.x11-bell: X11 I/O error handler called on display :0
sie 06 15:28:06 emilka-matebook pipewire\[2780\]: mod.x11-bell: X11 display (:0) has encountered a fatal I/O error
sie 06 15:28:06 emilka-matebook dockerd\[797\]: time=“2025-08-06T15:28:06.849223726+02:00” level=info msg=“stopping event stream following graceful shutdown” error=“” module=libcontainerd namespace=moby
sie 06 15:28:08 emilka-matebook evolution-alarm\[2483\]: Error reading events from display: Przerwany potok
sie 06 15:28:08 emilka-matebook garuda-system-m\[2514\]: Error reading events from display: Przerwany potok
sie 06 15:28:39 emilka-matebook kernel: ACPI BIOS Error (bug): Could not resolve symbol \[\_SB.PCI0.GPP4.WLAN\], AE_NOT_FOUND (20240827/dswload2-162)
sie 06 15:28:39 emilka-matebook kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
sie 06 15:28:39 emilka-matebook kernel: RAS: Correctable Errors collector initialized.
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.360104704+02:00” level=info msg=“skip loading plugin” error=“no scratch file generator: skip plugin” id=io.containerd.snapshotter.v1.blockfile type=io.containerd.snapshotter.v1
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.360604698+02:00” level=info msg=“skip loading plugin” error=“devmapper not configured: skip plugin” id=io.containerd.snapshotter.v1.devmapper type=io.containerd.snapshotter.v1
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.361543784+02:00” level=info msg=“skip loading plugin” error=“EROFS unsupported, please `modprobe erofs`: skip plugin” id=io.containerd.snapshotter.v1.erofs type=io.containerd.snapshotter.v1
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.361926444+02:00” level=info msg=“skip loading plugin” error=“lstat /var/lib/containerd/io.containerd.snapshotter.v1.zfs: no such file or directory: skip plugin” id=io.containerd.snapshotter.v1.zfs type=io.containerd.snapshotter.v1
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.364397009+02:00” level=info msg=“skip loading plugin” error=“could not find mkfs.erofs: exec: "mkfs.erofs": executable file not found in $PATH: skip plugin” id=io.containerd.differ.v1.erofs type=io.containerd.differ.v1
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.365582286+02:00” level=info msg=“starting cri plugin” config=“{"containerd":{"defaultRuntimeName":"runc","runtimes":{"runc":{"runtimeType":"io.containerd.runc.v2","runtimePath":"","PodAnnotations":null,"ContainerAnnotations":null,"options":{"BinaryName":"","CriuImagePath":"","CriuWorkPath":"","IoGid":0,"IoUid":0,"NoNewKeyring":false,"Root":"","ShimCgroup":""},"privileged_without_host_devices":false,"privileged_without_host_devices_all_devices_allowed":false,"cgroupWritable":false,"baseRuntimeSpec":"","cniConfDir":"","cniMaxConfNum":0,"snapshotter":"","sandboxer":"podsandbox","io_type":""}},"ignoreBlockIONotEnabledErrors":false,"ignoreRdtNotEnabledErrors":false},"cni":{"binDir":"","binDirs":\["/opt/cni/bin"\],"confDir":"/etc/cni/net.d","maxConfNum":1,"setupSerially":false,"confTemplate":"","ipPref":"","useInternalLoopback":false},"enableSelinux":false,"selinuxCategoryRange":1024,"maxContainerLogLineSize":16384,"disableApparmor":false,"restrictOOMScoreAdj":false,"disableProcMount":false,"unsetSeccompProfile":"","tolerateMissingHugetlbController":true,"disableHugetlbController":true,"device_ownership_from_security_context":false,"ignoreImageDefinedVolumes":false,"netnsMountsUnderStateDir":false,"enableUnprivilegedPorts":true,"enableUnprivilegedICMP":true,"enableCDI":true,"cdiSpecDirs":\["/etc/cdi","/var/run/cdi"\],"drainExecSyncIOTimeout":"0s","ignoreDeprecationWarnings":null,"containerdRootDir":"/var/lib/containerd","containerdEndpoint":"/run/containerd/containerd.sock","rootDir":"/var/lib/containerd/io.containerd.grpc.v1.cri","stateDir":"/run/containerd/io.containerd.grpc.v1.cri"}”
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.366213721+02:00” level=info msg=“skip loading plugin” error=“skip plugin: tracing endpoint not configured” id=io.containerd.tracing.processor.v1.otlp type=io.containerd.tracing.processor.v1
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.366257162+02:00” level=info msg=“skip loading plugin” error=“skip plugin: tracing endpoint not configured” id=io.containerd.internal.v1.tracing type=io.containerd.internal.v1
sie 06 15:28:47 emilka-matebook containerd\[765\]: time=“2025-08-06T15:28:47.367273981+02:00” level=error msg=“failed to load cni during init, please check CRI plugin status before setting up network for pods” error=“cni config load failed: no network config found in /etc/cni/net.d: cni plugin not initialized: failed to load cni config”
sie 06 15:28:47 emilka-matebook polkitd\[806\]: Error opening rules directory: Error opening directory “/run/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
sie 06 15:28:47 emilka-matebook polkitd\[806\]: Error opening rules directory: Error opening directory “/usr/local/share/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
sie 06 15:28:49 emilka-matebook dockerd\[805\]: time=“2025-08-06T15:28:49.288768472+02:00” level=warning msg=“Error (Unable to complete atomic operation, key modified) deleting object \[endpoint_count 9bf1cc7690d4c9c79e1dc0c3f1f08ad0b31cc60e5fa6896bd380c22fc4ad732d\], retrying…”
sie 06 15:28:50 emilka-matebook gnome-shell\[943\]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
sie 06 15:28:50 emilka-matebook gsd-sharing\[1678\]: Failed to handle service change: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
sie 06 15:28:51 emilka-matebook org.gnome.Shell.desktop\[1887\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:28:51 emilka-matebook org.gnome.Shell.desktop\[1943\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:28:51 emilka-matebook gsd-sharing\[1678\]: Failed to handle service change: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
sie 06 15:29:01 emilka-matebook gnome-session\[2204\]: gnome-session-binary\[2204\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2476: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:29:01 emilka-matebook gnome-session-binary\[2204\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2476: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:29:01 emilka-matebook gnome-session\[2204\]: gnome-session-binary\[2204\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2481: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:29:01 emilka-matebook gnome-session-binary\[2204\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2481: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:29:01 emilka-matebook gnome-session\[2204\]: gnome-session-binary\[2204\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2499: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:29:01 emilka-matebook gnome-session-binary\[2204\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2499: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:29:01 emilka-matebook gnome-session-binary\[2204\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2520: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:29:01 emilka-matebook gnome-session\[2204\]: gnome-session-binary\[2204\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2520: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:29:01 emilka-matebook gsd-usb-protect\[2386\]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
sie 06 15:29:01 emilka-matebook gnome-shell\[2225\]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
sie 06 15:29:04 emilka-matebook gnome-shell\[2861\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:29:05 emilka-matebook gnome-shell\[2952\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:29:05 emilka-matebook xdg-document-po\[1992\]: Error releasing name org.freedesktop.portal.Documents: Połączenie jest zamknięte
sie 06 15:29:05 emilka-matebook gsd-xsettings\[2948\]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
sie 06 15:29:06 emilka-matebook pika-backup-mon\[2495\]: src/daemon/init.rs:63:0: Error setting background status: Portal(NotAllowed(“Only sandboxed applications can set background status”))
sie 06 15:32:24 emilka-matebook kernel: ACPI BIOS Error (bug): Could not resolve symbol \[\_SB.PCI0.GPP4.WLAN\], AE_NOT_FOUND (20240827/dswload2-162)
sie 06 15:32:24 emilka-matebook kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
sie 06 15:32:24 emilka-matebook kernel: RAS: Correctable Errors collector initialized.
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.224341537+02:00” level=info msg=“skip loading plugin” error=“no scratch file generator: skip plugin” id=io.containerd.snapshotter.v1.blockfile type=io.containerd.snapshotter.v1
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.224810870+02:00” level=info msg=“skip loading plugin” error=“devmapper not configured: skip plugin” id=io.containerd.snapshotter.v1.devmapper type=io.containerd.snapshotter.v1
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.225511867+02:00” level=info msg=“skip loading plugin” error=“EROFS unsupported, please `modprobe erofs`: skip plugin” id=io.containerd.snapshotter.v1.erofs type=io.containerd.snapshotter.v1
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.225909194+02:00” level=info msg=“skip loading plugin” error=“lstat /var/lib/containerd/io.containerd.snapshotter.v1.zfs: no such file or directory: skip plugin” id=io.containerd.snapshotter.v1.zfs type=io.containerd.snapshotter.v1
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.228434655+02:00” level=info msg=“skip loading plugin” error=“could not find mkfs.erofs: exec: "mkfs.erofs": executable file not found in $PATH: skip plugin” id=io.containerd.differ.v1.erofs type=io.containerd.differ.v1
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.229695709+02:00” level=info msg=“starting cri plugin” config=“{"containerd":{"defaultRuntimeName":"runc","runtimes":{"runc":{"runtimeType":"io.containerd.runc.v2","runtimePath":"","PodAnnotations":null,"ContainerAnnotations":null,"options":{"BinaryName":"","CriuImagePath":"","CriuWorkPath":"","IoGid":0,"IoUid":0,"NoNewKeyring":false,"Root":"","ShimCgroup":""},"privileged_without_host_devices":false,"privileged_without_host_devices_all_devices_allowed":false,"cgroupWritable":false,"baseRuntimeSpec":"","cniConfDir":"","cniMaxConfNum":0,"snapshotter":"","sandboxer":"podsandbox","io_type":""}},"ignoreBlockIONotEnabledErrors":false,"ignoreRdtNotEnabledErrors":false},"cni":{"binDir":"","binDirs":\["/opt/cni/bin"\],"confDir":"/etc/cni/net.d","maxConfNum":1,"setupSerially":false,"confTemplate":"","ipPref":"","useInternalLoopback":false},"enableSelinux":false,"selinuxCategoryRange":1024,"maxContainerLogLineSize":16384,"disableApparmor":false,"restrictOOMScoreAdj":false,"disableProcMount":false,"unsetSeccompProfile":"","tolerateMissingHugetlbController":true,"disableHugetlbController":true,"device_ownership_from_security_context":false,"ignoreImageDefinedVolumes":false,"netnsMountsUnderStateDir":false,"enableUnprivilegedPorts":true,"enableUnprivilegedICMP":true,"enableCDI":true,"cdiSpecDirs":\["/etc/cdi","/var/run/cdi"\],"drainExecSyncIOTimeout":"0s","ignoreDeprecationWarnings":null,"containerdRootDir":"/var/lib/containerd","containerdEndpoint":"/run/containerd/containerd.sock","rootDir":"/var/lib/containerd/io.containerd.grpc.v1.cri","stateDir":"/run/containerd/io.containerd.grpc.v1.cri"}”
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.230321487+02:00” level=info msg=“skip loading plugin” error=“skip plugin: tracing endpoint not configured” id=io.containerd.tracing.processor.v1.otlp type=io.containerd.tracing.processor.v1
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.230365207+02:00” level=info msg=“skip loading plugin” error=“skip plugin: tracing endpoint not configured” id=io.containerd.internal.v1.tracing type=io.containerd.internal.v1
sie 06 15:32:28 emilka-matebook containerd\[743\]: time=“2025-08-06T15:32:28.231383563+02:00” level=error msg=“failed to load cni during init, please check CRI plugin status before setting up network for pods” error=“cni config load failed: no network config found in /etc/cni/net.d: cni plugin not initialized: failed to load cni config”
sie 06 15:32:28 emilka-matebook polkitd\[785\]: Error opening rules directory: Error opening directory “/run/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
sie 06 15:32:28 emilka-matebook polkitd\[785\]: Error opening rules directory: Error opening directory “/usr/local/share/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
sie 06 15:32:29 emilka-matebook dockerd\[784\]: time=“2025-08-06T15:32:29.562807249+02:00” level=warning msg=“Error (Unable to complete atomic operation, key modified) deleting object \[endpoint_count bd4db290b3f8b951aff3603ad58be68e6d5b39e86ce3825e709ceb2ccd137d47\], retrying…”
sie 06 15:32:31 emilka-matebook gnome-shell\[1087\]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
sie 06 15:32:32 emilka-matebook gsd-sharing\[1720\]: Failed to handle service change: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
sie 06 15:32:32 emilka-matebook org.gnome.Shell.desktop\[1913\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:32:32 emilka-matebook org.gnome.Shell.desktop\[1942\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:32:43 emilka-matebook gnome-session\[2186\]: gnome-session-binary\[2186\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2455: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:32:43 emilka-matebook gnome-session\[2186\]: gnome-session-binary\[2186\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2458: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:32:43 emilka-matebook gnome-session-binary\[2186\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2455: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:32:43 emilka-matebook gnome-session-binary\[2186\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2458: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:32:43 emilka-matebook gnome-session\[2186\]: gnome-session-binary\[2186\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2472: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:32:43 emilka-matebook gnome-session-binary\[2186\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2472: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:32:43 emilka-matebook gnome-session\[2186\]: gnome-session-binary\[2186\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2478: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:32:43 emilka-matebook gnome-session-binary\[2186\]: GnomeDesktop-WARNING: Could not create transient scope for PID 2478: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
sie 06 15:32:43 emilka-matebook gsd-usb-protect\[2375\]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
sie 06 15:32:43 emilka-matebook gnome-shell\[2207\]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
sie 06 15:32:46 emilka-matebook gnome-shell\[2913\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:32:47 emilka-matebook gnome-shell\[1087\]: JS ERROR: Gio.IOErrorEnum: Xwayland exited unexpectedly
sie 06 15:32:47 emilka-matebook gnome-shell\[2982\]: Errors from xkbcomp are not fatal to the X server
sie 06 15:32:47 emilka-matebook gsd-xsettings\[2977\]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
sie 06 15:32:48 emilka-matebook pika-backup-mon\[2489\]: src/daemon/init.rs:63:0: Error setting background status: Portal(NotAllowed(“Only sandboxed applications can set background status”))
You should always post a link to any prior help request you’ve made, if your current help request is directly related to an old one.
Your old thread:
As before, I have moved this thread to the Networking sub-fora where it belongs. Please post any networking help requests in the “Networking” sub-forum in the future.
I have no idea why your system would freeze when doing a backup using Gnome/Pika. I have been a KDE user for 20+ years, I have next to no experience using Gnome. I would suggest you investigate this error:
As far as your wireless issue goes, I would have to fall back to what I stated on your last thread. When Realtek WiFi drivers break, the usual fix is to switch to using the lts kernel. At some point in the future the mainline or Linux kernels should resume working with your Realtek WiFi driver.
I gave you a lot of suggestions on my post that you marked as your fix on your last wifi thread. You did not really report on which suggestions of mine you implemented on that thread that contributed to your fix.
You would need to provide the terminal output of any/all changes you made to any grub or network configuration file(s) via the cat command so that we can view your current configuration.
You need to test your WiFi driver on the lts kernel (again), making sure you implemented the fixes correctly that I listed on your last WiFi help request. You also need to test the mainline kernel. For the best chance of getting your WiFi driver working correctly you should test numerous alternate kernels. If you insist on using the zen kernel or another kernel that is currently incompatible with your Realtek WiFi driver, then I would suggest that you probably should buy another WiFi adapter. Look to buy a WiFi adapter that has better in-kernel driver support. Unfortunately, the Realtek WiFi model you are currently using has been problematic in Linux for quite some time.
Don´t know if it would help, but there is maybe another driver in AUR.
aur/rtl88x2ce-dkms-git r50.eb2fff0-1
    Realtek RTL8822CE WLAN GNU/Linux Driver
That repository doesn’t look like it’s been updated in quite some time. Last AUR comment from Feb 25 says it broken on recent kernels.
Anything’s possible though, you never know.
Edit:
I do not own a Realtek RTL8822CE wifi adapter, so I have absolutely no way of testing to see if it’s possible to get that driver working with your WiFi adapter. Only someone who actually owns a Realtek RTL8822CE WiFi adapter can possibly perform the experiments required to answer that question.
Read the Archwiki entries on downgrading packages if you want to test older unofficial drivers. Be aware however, that Arch Linux does not support partial upgrades. Do your own research if this is the method you wish to attempt to follow.
@MarianKoniuszko, You linked your garuda-inxi via our PrivateBin, so there were some things I did not immediately notice. We prefer that the user’s garuda-inxi information is included directly in your opening post for this reason, so that it is easily visible for easier reference when rendering assistance.
Some things from your inxi that could use clarification:
wlp1s0 state: up
Is your wifi in actuality functioning correctly on any kernel?
If so, on which kernel is your WiFi driver functioning?
Your inxi output indicates state: up which indicates your WiFi is working.
On your prior help request thread I asked you to add a kernel boot parameter and a wifi driver parameter configuration file.
Your garuda-inxi output is clearly missing the kernel boot parameter I asked you to add on your last help request.
    root=UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 rw rootflags=subvol=@ quiet quiet
    resume=UUID=8f7c97f0-2758-4001-95b0-57f15fb14228 loglevel=3 ibt=off
This makes me wonder what other suggestions I made that were not implemented.
Please confirm with the following command output that you did in fact create the WiFi driver parameter configuration file correctly:
cat  /etc/modprobe.d/rtl8822ce.conf
Your inxi output indicates your system has an outdated bios version known by your manufacturer to cause crashes:
HUAWEI v: 1.06 date: 09/14/2020
I would highly recommend updating your system’s bios to your manufacturers most up to date version.
Your inxi network info contains the following lines:
IF-ID-1: docker0 state: down mac:
IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Are you attempting to operate your WiFi via a docker container or though a VPN?
The above inxi outputs are not normal. Could you please provide further information as to why these outputs are present.
Are you running a firewall?
If so, please provide details.
Please respond to all queries in full detail, simple yes or no replies are generally insufficient if you wish forum assistants to volunteer their time to help you correct your issue.
