System becomes unresponsive after display has been off
After a recent update I’ve issues with my system completely freezing after waking up a display. I have no screen locking in place, it’s really just the “Turn off screen” option from the power management section.
What’s weird about that issue is that the display seems to come back on, at least sometimes. I can seen the screen appearing but following that the system is completely unresponsive for at least a minute. Sometimes it then finds its way back…
I’m sorry I know that’s not a lot to go on, but I really have no clue where to start looking.
Can you provide your
As per the forum template
Sure.
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=08444cbe-8e6a-4ca6-be59-025001d9562e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop Mobo: ASUSTeK model: WS C422 PRO_SE v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_KBLX
uuid: <superuser required> UEFI: American Megatrends v: 3302
date: 11/04/2020
Info: model: Intel Xeon W-2125 bits: 64 type: MT MCP arch: Skylake level: v4
note: check process: Intel 14nm family: 6 model-id: 0x55 (85) stepping: 4
microcode: 0x2007006
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 4 MiB desc: 4x1024 KiB
L3: 8.2 MiB desc: 1x8.2 MiB
Speed (MHz): avg: 2013 high: 4500 min/max: 1200/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 4500 3: 1200
4: 1200 5: 1200 6: 4404 7: 1200 8: 1200 bogomips: 63999
Device-1: AMD Baffin [Radeon RX 550 640SP / 560/560X] vendor: XFX Pine
active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 65:00.0 chip-ID: 1002:67ff
class-ID: 0300 temp: 52.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 4520x1920
display-ID: 0
Monitor-1: DP-1 pos: right res: 1080x1920 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 3440x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 550 Series (radeonsi
polaris11 LLVM 18.1.8 DRM 3.57 6.10.10-zen1-1-zen) device-ID: 1002:67ff
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 550 Series (RADV POLARIS11) driver: mesa radv v: 24.2.2-arch1.1
device-ID: 1002:67ff surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.2-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 bus-ID: 65:00.1 chip-ID: 1002:aae0 class-ID: 0403
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: Intel I210 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 04:00.0
chip-ID: 8086:1533 class-ID: 0200
Device-2: Intel I210 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
Local Storage: total: 698.65 GiB used: 251.65 GiB (36.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 47.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
used: 251.65 GiB (54.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.49 GiB used: 141.2 MiB (0.2%)
System Temperatures: cpu: 68.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 955
Memory: total: 64 GiB note: est. available: 62.49 GiB
used: 13.99 GiB (22.4%)
Processes: 320 Power: uptime: 2h 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.97 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1801 libs: 455 tools: pamac,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2023-07-04
Last full system update: 2024-09-20 ↻
Relevant software:       snapper(custom) NetworkManager dracut
I have two systems where this is occurring. The have the same LC-Power monitor in common, once connected with HDMI, once with display port.
Have you tried running in x11 to see if it persists?
Doesn’t look like it does. On X11 everything seems fine, no freezes.
reboot
Just did to boot into X11 and back to Wayland.
If its fine in x11 stay using that :smile:
Sadly X11 does not feel as snappy. If possible I’d rather solve this issue. I’m curious to see if more people will run into this.
Have you looked at what has been updated? If one is the kernel, have you tried to boot on an older one?
I remember getting a black screen once and booting on a previous snapshot and updating again with garuda-update solved the issue.
My little 2 cents.
Try the lts kernel by running :
Believe me, this has solved many sleep wake related issues for in the past. Wouldn’t hurt to try, would it ?
For whatever reason that seemed to have solved my issue… Thanks
