I use sxhkd to change the brightness of my keyboard and display, I only used my hdimi display for a while, and now the backlight folder is empty, anyone now what caused this and how to fix it? I use Garuda on a 2012 Macbook Pro.
I will post garuda-inxi when I get the chance
My sxhkd config
/home/manuel/.config/sxhkd/sxhkdrc
XF86MonBrightnessUp
sudo xbacklight -inc +5
XF86MonBrightnessDown
sudo xbacklight -inc -5
XF86AudioRaiseVolume
pactl set-sink-volume 0 +5%;pamixer --get-volume-human | dzen2 -p 1
XF86AudioLowerVolume
pactl set-sink-volume 0 -5%;pamixer --get-volume-human | dzen2 -p 1
XF86AudioMute
pactl set-sink-mute 0 toggle;pamixer --get-volume-human | dzen2 -p 1
XF86KbdBrightnessUp
sudo xbacklight -ctrl smc::kbd_backlight -inc 5
XF86KbdBrightnessDown
sudo xbacklight -ctrl smc::kbd_backlight -dec 5
XF86Eject
eject
super XF86Eject
flameshot launcher
SGS
18 January 2023 15:22
#2
Use live ISO, please.
Summary
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
How to search for solutions the right way | Garuda Linux wiki
Garuda Inxi Output
Kernel: 6.1.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=4099c804-740b-4c2b-be89-691b4c6c569a rw
[email protected] rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=7a2bef2e-2051-49ea-b2c2-476cfbd79f28
loglevel=3 sdhci.debug_quirks2=4 ibt=off
Desktop: dwm v: 6.3 vt: 1 dm: LightDM v: 1.32.0
Type: Laptop System: Apple product: MacBookPro9,2 v: 1.0
serial: <superuser required> Chassis: type: 10
v: Mac-6F01561E16C75D06 serial: <superuser required>
Mobo: Apple model: Mac-6F01561E16C75D06 v: MacBookPro9,2
serial: <superuser required> UEFI: Apple v: 425.0.0.0.0
date: 10/26/2021
ID-1: BAT0 charge: 32.0 Wh (65.7%)
condition: 48.7/62.9 Wh (77.4%) volts: 11.0 min: 10.9
model: SMP bq20z451 type: Li-ion serial: N/A
status: discharging cycles: 401
Info: model: Intel Core i5-3210M bits: 64 type: MT MCP
arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15
process: Intel 22nm family: 6 model-id: 0x3A (58)
stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled
cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2954 high: 3021 min/max: 1200/3100
scaling: driver: intel_cpufreq governor: performance cores:
1: 2894 2: 3021 3: 2893 4: 3008 bogomips: 19953
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vmx
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm
built: 2012-13 ports: active: LVDS-1 empty: DP-1, DP-2,
DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Apple FaceTime HD Camera type: USB
driver: uvcvideo bus-ID: 1-1.1:3 chip-ID: 05ac:8509
Display: server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
driver: X: loaded: intel unloaded: modesetting,vesa
alternate: fbdev dri: crocus gpu: i915 display-ID: :0
Screen-1: 0 s-res: 1280x800 s-dpi: 96
s-size: 338x211mm (13.31x8.31") s-diag: 398mm (15.69")
Monitor-1: LVDS-1 mapped: LVDS1 model: Apple 0x9cc5
built: 2009 res: 1280x800 hz: 60 dpi: 112 gamma: 1.2
size: 290x180mm (11.42x7.09") diag: 337mm (13.3")
ratio: 16:10 modes: 1280x800
API: OpenGL v: 4.2 Mesa 22.3.2 renderer: Mesa Intel HD
Graphics 4000 (IVB GT2) direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound API: ALSA v: k6.1.4-zen2-1-zen running: yes
Sound Server-1: JACK v: 1.9.21 running: no
Sound Server-2: PulseAudio v: 16.1 running: yes
Sound Server-3: PipeWire v: 0.3.63 running: no
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe
driver: tg3 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: N/A bus-ID: 01:00.0 chip-ID: 14e4:16b4 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n
vendor: Apple AirPort Extreme driver: wl v: kernel
modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14e4:4331 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB
driver: btusb v: 0.8 bus-ID: 2-1.8.1.3:9 chip-ID: 05ac:821d
class-ID: fe01
Report: bt-adapter ID: hci0 rfk-id: 1 state: up
address: <filter>
Local Storage: total: 931.51 GiB used: 385.75 GiB (41.4%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial
model: CT1000MX500SSD1 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 033 temp: 36 C scheme: GPT
ID-1: / raw-size: 922.99 GiB size: 922.99 GiB (100.00%)
used: 385.68 GiB (41.8%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
used: 70.7 MiB (23.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.99 GiB size: 922.99 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 922.99 GiB
size: 922.99 GiB (100.00%) used: 385.68 GiB (41.8%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 922.99 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 3.74 GiB
used: 552.2 MiB (14.4%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.23 GiB
used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 64.0 C mobo: N/A
Processes: 247 Uptime: 12m wakeups: 3 Memory: 3.74 GiB
used: 2.08 GiB (55.5%) Init: systemd v: 252
default: multi-user tool: systemctl Compilers: gcc: 12.2.0
clang: 14.0.6 Packages: 2923 pm: dpkg pkgs: 0 pm: pacman
pkgs: 2900 libs: 574
tools: gnome-software,octopi,pamac,paru,trizen,yay
pm: flatpak pkgs: 23 Shell: fish v: 3.5.1
running-in: alacritty inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-04-24
Last full system update: 2023-01-11 ↻
Is partially upgraded: Yes
Bring your system fully up to date:
garuda-update
Then reboot. If that doesn't resolve the issue, please re-post the garuda-inxi
afterward.
New garuda-inxi
Kernel: 6.1.6-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4099c804-740b-4c2b-be89-691b4c6c569a rw [email protected]
resume=UUID=7a2bef2e-2051-49ea-b2c2-476cfbd79f28 loglevel=3
Desktop: dwm v: 6.3 vt: 1 dm: LightDM v: 1.32.0 Distro: Garuda Linux
serial: <superuser required> Chassis: type: 10 v: Mac-6F01561E16C75D06
serial: <superuser required> UEFI: Apple v: 425.0.0.0.0 date: 10/26/2021
ID-1: BAT0 charge: 42.2 Wh (85.1%) condition: 49.6/62.9 Wh (78.9%)
volts: 12.4 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: charging cycles: 402
Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
Speed (MHz): avg: 2990 high: 3024 min/max: 1200/3100 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2972 2: 3011 3: 3024
4: 2953 bogomips: 19954
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3,
VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
Display: server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7 driver: X:
loaded: intel unloaded: modesetting,vesa alternate: fbdev dri: crocus
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: Apple 0x9cc5 built: 2009
res: 1280x800 hz: 60 dpi: 112 gamma: 1.2 size: 290x180mm (11.42x7.09")
diag: 337mm (13.3") ratio: 16:10 modes: 1280x800
API: OpenGL v: 4.2 Mesa 22.3.3 renderer: Mesa Intel HD Graphics 4000 (IVB
Sound API: ALSA v: k6.1.6-zen1-2-zen running: yes
Sound Server-3: PipeWire v: 0.3.64 running: no
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 2-1.8.1.3:9 chip-ID: 05ac:821d class-ID: fe01
Local Storage: total: 931.51 GiB used: 400.31 GiB (43.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 033 temp: 37 C scheme: GPT
used: 400.24 GiB (43.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 922.99 GiB size: 922.99 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.99 GiB size: 922.99 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.74 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8.23 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 68.0 C mobo: N/A
Processes: 206 Uptime: 1m wakeups: 2 Memory: 3.74 GiB
used: 778.5 MiB (20.3%) Init: systemd v: 252 default: multi-user
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 2927 pm: dpkg
pkgs: 0 pm: pacman pkgs: 2904 libs: 574
tools: gnome-software,octopi,pamac,paru,trizen,yay pm: flatpak pkgs: 23
Shell: fish v: 3.6.0 running-in: alacritty inxi: 3.3.24
Garuda (2.6.14-1):
Last full system update: 2023-01-18 ↻
The brightness does seem to change depending if it's turned on with the lid open or closed.
are you sure it's caused by that arandr change? Is it reproducible? Have you tried xrandr --listmonitors
? Anything of interest in dmesg? What if you try to set the brightness via xrandr --brightness
While writing this I noticed that my brightness folder is also empty, are you sure there was a file in there before?
I'm not sure if it was caused by arandr, and there was definitley a file there before, as xbacklight and gbacklight both worked a while ago. xrandr -brightness just changes gamma, not backlight.
