Synology Drive client stopped working
Hi,
I’ve been using Synology drive desktop client successfully for about a month backing up my computer to my NAS. Package is from the Chaotic-AUR built by Garuda Builder.
Today it hung when I tried to change the backup settings so I forced it to quit. Now the UI doesn’t start. When I launch the program I get a system notification that the client is running and its showing online in the NAS web app so it is working, but I cant change anything.
I tried reinstalling it and then doing a system update (computer had been on for a week to do the backup) but no change.
I found the discussion on the AUR package here and followed the instructions there to edit .bashrc but the issue wasn’t resolved. Again, it was working perfectly fine today.
Garuda-inxi
  Kernel: 6.14.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
    root=UUID=e7454ee6-b5e4-487a-b0dc-d8af91efa048 rw rootflags=subvol=@ quiet loglevel=3
    amdgpu.ppfeaturemask=0xffffffff ibt=off
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0 wm: kwin_wayland vt: 1
  Type: Desktop Mobo: ASRock model: B650M PG Riptide serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.11 date: 10/21/2022
  Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check
    built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x61 (97) stepping: 2
    microcode: 0xA601209
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 5483 min/max: 400/5575 boost: enabled scaling: driver: amd-pstate-epp
    governor: performance cores: 1: 5483 2: 5483 3: 5483 4: 5483 5: 5483 6: 5483 7: 5483 8: 5483
    9: 5483 10: 5483 11: 5483 12: 5483 13: 5483 14: 5483 15: 5483 16: 5483 bogomips: 143730
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900 XTX/7900 GRE/7900M]
    vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
    process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
    empty: DP-1, DP-2, HDMI-A-1, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
  Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:5 chip-ID: 046d:08e5 class-ID: 0102
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-3 model: 32M2V serial: <filter> built: 2022 res: mode: 3840x2160 hz: 144
    scale: 100% (1) dpi: 138 gamma: 1.2 size: 709x399mm (27.91x15.71") diag: 814mm (32") ratio: 16:9
    modes: max: 3840x2160 min: 640x480
    gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi navi31 LLVM 19.1.7 DRM 3.61
    6.14.6-zen1-1-zen) device-ID: 1002:744c memory: 19.53 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.313 layers: 12 device: 0 type: discrete-gpu name: AMD Radeon RX 7900 XT
    (RADV NAVI31) driver: mesa radv v: 25.0.5-arch1.1 device-ID: 1002:744c surfaces: N/A device: 1
    type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.5-arch1.1 (LLVM
    gpu: corectrl,radeontop wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: ASRock
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.6
  Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
  Device-4: Elgato Systems GmbH Wave:1 driver: snd-usb-audio type: USB rev: 2.0 speed: 1
2 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 0fd9:006e class-ID: fe01 serial: <filter>
  API: ALSA v: k6.14.6-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-11:4 chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1 lmp-v: 10 status:
  Local Storage: total: 1.82 TiB used: 1.68 TiB (92.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T700SSD5 size: 1.82 TiB
    block-size: physical: 512 B logical: 512 B speed: 126 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: PACR5101 temp: 41.9 C scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.68 TiB (92.3%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.68 TiB (92.3%) fs: btrfs
  ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.68 TiB (92.3%) fs: btrfs
  ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.68 TiB (92.3%) fs: btrfs
  ID-1: swap-1 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 16 dev: /dev/zram0
  System Temperatures: cpu: 51.0 C mobo: 33.8 C gpu: amdgpu temp: 47.0 C mem: 58.0 C
  Memory: total: 32 GiB note: est. available: 31.05 GiB used: 6.69 GiB (21.5%)
  Processes: 390 Power: uptime: 6m states: freeze,mem,disk suspend: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.4 GiB
  Packages: 1981 pm: pacman pkgs: 1976 libs: 533 tools: octopi,paru,yay pm: flatpak pkgs: 5
    Compilers: clang: 19.1.7 gcc: 15.1.1 Client: shell wrapper v: 5.2.37-release inxi: 3.3.38
  System install date:     2023-10-29
  Last full system update: 2025-05-11
  Failed units:            fancontrol.service
I fixed it by uninstalling it, deleting the folder /home/user/.SynologyDrive, reinstalling Synology Drive and restarting.
