Synfig Studio SIGSEGV
Hello
I’ve installed synfigstudio (currently 1.4.5-1) from the official repository but have troubles getting it to run. The application simply terminated with a SIGSEGV.
Sadly there also isn’t a lot of info in the log, besides synfig not finding mod_libavcodec.
╰─λ synfigstudio
synfig studio -- starting up application...
synfig(3983) [17:27:12] info: Starting Subsystem "Sound"
synfig(3983) [17:27:13] info: Starting Subsystem "Types"
synfig(3983) [17:27:13] info: Starting Subsystem "Rendering"
synfig(3983) [17:27:13] info: rendering threads 16
synfig(3983) [17:27:13] info: Starting Subsystem "Modules"
synfig(3983) [17:27:13] info: Starting Subsystem "Layers"
synfig(3983) [17:27:13] info: Starting Subsystem "Targets"
synfig(3983) [17:27:13] info: Starting Subsystem "Importers"
synfig(3983) [17:27:13] info: Starting Subsystem "Cairo Importers"
synfig(3983) [17:27:13] info: Starting Subsystem "Thread Pool"
synfig(3983) [17:27:13] warning: Cannot open ./synfig_modules.cfg
synfig(3983) [17:27:13] warning: Cannot open /home/vinci/.local/share/synfig/synfig_modules.cfg
synfig(3983) [17:27:13] info: Loading modules from /etc/synfig_modules.cfg
synfig(3983) [17:27:13] info: Loading lyr_std..
synfig(3983) [17:27:13] info: Attempting to register "lyr_std"
synfig(3983) [17:27:13] info: Found module "lyr_std"
synfig(3983) [17:27:13] info: Success for "lyr_std"
synfig(3983) [17:27:13] info: Loading lyr_freetype..
synfig(3983) [17:27:13] info: Attempting to register "lyr_freetype"
synfig(3983) [17:27:13] info: Found module "lyr_freetype"
synfig(3983) [17:27:13] info: Initializing FreeType...
synfig(3983) [17:27:13] info: Success for "lyr_freetype"
synfig(3983) [17:27:13] info: Loading mod_geometry..
synfig(3983) [17:27:13] info: Attempting to register "mod_geometry"
synfig(3983) [17:27:13] info: Found module "mod_geometry"
synfig(3983) [17:27:13] info: Success for "mod_geometry"
synfig(3983) [17:27:13] info: Loading mod_gradient..
synfig(3983) [17:27:13] info: Attempting to register "mod_gradient"
synfig(3983) [17:27:13] info: Found module "mod_gradient"
synfig(3983) [17:27:13] info: Success for "mod_gradient"
synfig(3983) [17:27:13] info: Loading mod_particle..
synfig(3983) [17:27:13] info: Attempting to register "mod_particle"
synfig(3983) [17:27:13] info: Found module "mod_particle"
synfig(3983) [17:27:13] info: Success for "mod_particle"
synfig(3983) [17:27:13] info: Loading mod_example..
synfig(3983) [17:27:13] info: Attempting to register "mod_example"
synfig(3983) [17:27:13] info: Found module "mod_example"
synfig(3983) [17:27:13] info: Success for "mod_example"
synfig(3983) [17:27:13] info: Loading mod_gif..
synfig(3983) [17:27:13] info: Attempting to register "mod_gif"
synfig(3983) [17:27:13] info: Found module "mod_gif"
synfig(3983) [17:27:13] info: Success for "mod_gif"
synfig(3983) [17:27:13] info: Loading mod_imagemagick..
synfig(3983) [17:27:13] info: Attempting to register "mod_imagemagick"
synfig(3983) [17:27:13] info: Found module "mod_imagemagick"
synfig(3983) [17:27:13] info: Success for "mod_imagemagick"
synfig(3983) [17:27:13] info: Loading mod_magickpp..
synfig(3983) [17:27:13] info: Attempting to register "mod_magickpp"
synfig(3983) [17:27:13] info: Found module "mod_magickpp"
synfig(3983) [17:27:13] info: Success for "mod_magickpp"
synfig(3983) [17:27:13] info: Loading mod_mng..
synfig(3983) [17:27:13] info: Attempting to register "mod_mng"
synfig(3983) [17:27:13] info: Found module "mod_mng"
synfig(3983) [17:27:13] info: Success for "mod_mng"
synfig(3983) [17:27:13] info: Loading mod_noise..
synfig(3983) [17:27:13] info: Attempting to register "mod_noise"
synfig(3983) [17:27:13] info: Found module "mod_noise"
synfig(3983) [17:27:13] info: Success for "mod_noise"
synfig(3983) [17:27:13] info: Loading mod_filter..
synfig(3983) [17:27:13] info: Attempting to register "mod_filter"
synfig(3983) [17:27:13] info: Found module "mod_filter"
synfig(3983) [17:27:13] info: Success for "mod_filter"
synfig(3983) [17:27:13] info: Loading mod_ffmpeg..
synfig(3983) [17:27:13] info: Attempting to register "mod_ffmpeg"
synfig(3983) [17:27:13] info: Found module "mod_ffmpeg"
synfig(3983) [17:27:13] info: Success for "mod_ffmpeg"
synfig(3983) [17:27:13] info: Loading mod_bmp..
synfig(3983) [17:27:13] info: Attempting to register "mod_bmp"
synfig(3983) [17:27:13] info: Found module "mod_bmp"
synfig(3983) [17:27:13] info: Success for "mod_bmp"
synfig(3983) [17:27:13] info: Loading mod_dv..
synfig(3983) [17:27:13] info: Attempting to register "mod_dv"
synfig(3983) [17:27:13] info: Found module "mod_dv"
synfig(3983) [17:27:13] info: Success for "mod_dv"
synfig(3983) [17:27:13] info: Loading mod_png..
synfig(3983) [17:27:13] info: Attempting to register "mod_png"
synfig(3983) [17:27:13] info: Found module "mod_png"
synfig(3983) [17:27:13] info: Success for "mod_png"
synfig(3983) [17:27:13] info: Loading mod_ppm..
synfig(3983) [17:27:13] info: Attempting to register "mod_ppm"
synfig(3983) [17:27:13] info: Found module "mod_ppm"
synfig(3983) [17:27:13] info: Success for "mod_ppm"
synfig(3983) [17:27:13] info: Loading mod_openexr..
synfig(3983) [17:27:13] info: Attempting to register "mod_openexr"
synfig(3983) [17:27:13] info: Found module "mod_openexr"
synfig(3983) [17:27:13] info: Success for "mod_openexr"
synfig(3983) [17:27:13] info: Loading mod_jpeg..
synfig(3983) [17:27:13] info: Attempting to register "mod_jpeg"
synfig(3983) [17:27:13] info: Found module "mod_jpeg"
synfig(3983) [17:27:13] info: Success for "mod_jpeg"
synfig(3983) [17:27:13] info: Loading mod_libavcodec..
synfig(3983) [17:27:13] info: Attempting to register "mod_libavcodec"
synfig(3983) [17:27:13] warning: Unable to find module "mod_libavcodec" (file not found)
synfig(3983) [17:27:13] info: Loading mod_yuv420p..
synfig(3983) [17:27:13] info: Attempting to register "mod_yuv420p"
synfig(3983) [17:27:13] info: Found module "mod_yuv420p"
synfig(3983) [17:27:13] info: Success for "mod_yuv420p"
synfig(3983) [17:27:13] info: Loading mod_svg..
synfig(3983) [17:27:13] info: Attempting to register "mod_svg"
synfig(3983) [17:27:13] info: Found module "mod_svg"
synfig(3983) [17:27:13] info: Success for "mod_svg"
synfig(3983) [17:27:13] info: DONE
synfig(3983) [17:27:13] info: Loading Basic Settings...
synfig(3983) [17:27:13] info: Loading Plugins...
synfig(3983) [17:27:13] info: Loading plugins from /usr/share/synfig/plugins
synfig(3983) [17:27:13] info:    Loading plugin: add-skeleton-simple
synfig(3983) [17:27:13] info:    Loading plugin: lottie-exporter
synfig(3983) [17:27:13] info:    Loading plugin: view-unhide-all-layers
synfig(3983) [17:27:13] info: Loading plugins from /home/vinci/.config/synfig/plugins
synfig(3983) [17:27:13] info: Init UI Manager...
synfig(3983) [17:27:13] info: Init Dock Manager...
synfig(3983) [17:27:13] info: Init State Manager...
synfig(3983) [17:27:13] info: Init Main Window...
synfig(3983) [17:27:13] info: Init Toolbox...
synfig(3983) [17:27:13] info: Init About Dialog...
synfig(3983) [17:27:13] info: Init Tool Options...
synfig(3983) [17:27:13] info: Init History...
synfig(3983) [17:27:13] info: Init Canvases...
synfig(3983) [17:27:13] info: Init Keyframes...
synfig(3983) [17:27:13] info: Init Layers...
synfig(3983) [17:27:13] info: Init Parameters...
synfig(3983) [17:27:13] info: Init MetaData...
synfig(3983) [17:27:13] info: Init Library...
synfig(3983) [17:27:13] info: Init Info...
synfig(3983) [17:27:13] info: Init Navigator...
synfig(3983) [17:27:13] info: Init SoundWave...
synfig(3983) [17:27:13] info: Init Timetrack...
synfig(3983) [17:27:13] info: Init Curve Editor...
synfig(3983) [17:27:13] info: Init Layer Sets...
synfig(3983) [17:27:13] info: Init Color Dialog...
synfig(3983) [17:27:13] info: Init Gradient Dialog...
synfig(3983) [17:27:13] info: Init DeviceTracker...
fish: Job 1, 'synfigstudio' terminated by signal SIGSEGV (Address boundary error)
Any ideas what might be causing this?
  Kernel: 6.13.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=176e2eb1-85ad-4c01-ab84-b95ea4631894 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.0 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Desktop Mobo: Micro-Star model: PRO B650-S WIFI (MS-7E26) v: 1.0
    Megatrends LLC. v: 1.20 date: 07/12/2023
  Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 4400 min/max: 400/5050 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 4400 2: 4400 3: 4400
    4: 4400 5: 4400 6: 4400 7: 4400 8: 4400 9: 4400 10: 4400 11: 4400 12: 4400
    13: 4400 14: 4400 15: 4400 16: 4400 bogomips: 134407
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: PC Partner / Sapphire
    built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1
    empty: DP-2, DVI-D-1, HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0
    chip-ID: 1002:67df class-ID: 0300 temp: 52.0 C
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
    empty: DP-3, DP-4, DP-5, HDMI-A-3, Writeback-1 bus-ID: 10:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 46.0 C
  Monitor-1: DP-1 model: UWQHD-100-C built: 2019 res: mode: 3440x1440
    hz: 100 scale: 100% (1) dpi: 109 gamma: 1.2 size: 795x334mm (31.3x13.15")
    diag: 869mm (34.2") modes: max: 3440x1440 min: 720x400
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 480 Graphics
    (radeonsi polaris10 LLVM 19.1.7 DRM 3.59 6.13.2-zen1-1-zen)
    device-ID: 1002:67df memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 8 device: 0 type: discrete-gpu name: AMD
    Radeon RX 480 Graphics (RADV POLARIS10) driver: N/A device-ID: 1002:67df
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: PC Partner / Sapphire driver: snd_hda_intel
    chip-ID: 1002:aaf0 class-ID: 0403
    Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:1640
    speed: 16 GT/s lanes: 16 bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.13.2-zen1-1-zen status: kernel-api tools: N/A
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
  IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0d:00.0 chip-ID: 14c3:0608
  IF: wlp13s0 state: down mac: <filter>
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.1:4
    rfk-block: hardware: no software: no address: <filter> bt-v: 4.0 lmp-v: 6
  Device-2: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 0e8d:0608
  Report: ID: hci1 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 931.51 GiB used: 485.4 GiB (52.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXE7 temp: 40.9 C
    used: 485.4 GiB (52.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 30.51 GiB used: 181.5 MiB (0.6%)
  System Temperatures: cpu: 57.4 C mobo: 36.5 C
  GPU: device: amdgpu temp: 46.0 C device: amdgpu temp: 54.0 C fan: 771
    watts: 40.06
  Memory: total: 32 GiB note: est. available: 30.51 GiB used: 6.09 GiB (20.0%)
  Processes: 395 Power: uptime: 23m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 2163 libs: 469 tools: pamac,paru Compilers:
    clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
Garuda (2.6.26-1.1):
  System install date:     2023-04-17
  Last full system update: 2025-02-13
  Failed units:            vpnagentd.service
/edit
synfig itself seems to run fine, at least it shows me --help
Please do not move threads back to the wrong category after mods have already moved your thread to the right spot. Thanks.
I’m sorry, I didn’t knowingly move anything? Maybe that was the edit?
Looks bad for you: synfigstudio, synfigstudio-git, synfigstudio-dev and the flatpak version of synfigstudio do not work - neither on Garuda, nor on EnOS nor on KDE neon (all KDE/QT). Possibly the reason for this is that it is a GTK application.
Everywhere with all versions the same error in the same place:
You can ignore this warning, it has nothing to do with the crash:
The only way to start the application w/o issues is with sudo rights:
sudo synfigstudio
:warning: For security reasons, I advise against starting applications with sudo rights. Do this at your own risk! :warning:
Edit: The cause is wayland. :person_facepalming:
Switch to an x11 session, then it works. :smiley:
