Running syncthing seems to cause high cpu usage in gnome-shell for some reason for about the last week or so and I'm not sure what to do about it other than not run syncthing. It might have been happening longer than that, but I only became aware of with the system being sluggish since the gnome update.
syncthing off:
gnome shell tends to be less than 15% of cpu core on average.
Syncthing on:
gnome shell tends to be between 30%-50% of cpu core on average.
running "journalctl /usr/bin/gnome-shell --since today":
"Nov 13 18:23:49 ROGGAR gnome-shell[5285]: Timelines with detached actors are not supported. <unnamed>[<Gjs_ui_search_ListSearchResult>:0x55589fe038b0] in animation of duration 200ms but not on stage.
Nov 13 18:23:50 ROGGAR gnome-shell[5285]: Received error from D-Bus search provider org.gnome.Terminal.desktop: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/org/gnome/Terminal/Searc>
Nov 13 18:24:23 ROGGAR gnome-shell[5285]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x7600036
Nov 13 18:27:02 ROGGAR gnome-shell[5285]: JS ERROR: TypeError: this.actor is null
_syncEnabled@resource:///org/gnome/shell/ui/windowManager.js:138:25
onStopped@resource:///org/gnome/shell/ui/windowManager.js:150:35
_makeEaseCallback/<@resource:///org/gnome/shell/ui/environment.js:150:22
_easeActorProperty/<@resource:///org/gnome/shell/ui/environment.js:316:60
_destroyWindowDone@resource:///org/gnome/shell/ui/windowManager.js:1596:21
onStopped@resource:///org/gnome/shell/ui/windowManager.js:1564:39
_easeActor/<@resource:///org/gnome/shell/ui/environment.js:239:64
Nov 13 18:32:46 ROGGAR gnome-shell[5285]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x1e00004
Nov 13 18:35:58 ROGGAR gnome-shell[5285]: (../libsoup/libsoup/soup-message-queue-item.c:46):soup_message_queue_item_destroy: runtime check failed: (soup_message_get_connection (item->msg) == NULL)
Nov 13 18:36:38 ROGGAR gnome-shell[5285]: (../libsoup/libsoup/soup-message-queue-item.c:46):soup_message_queue_item_destroy: runtime check failed: (soup_message_get_connection (item->msg) == NULL)
Nov 13 18:37:08 ROGGAR gnome-shell[5285]: (../libsoup/libsoup/soup-message-queue-item.c:46):soup_message_queue_item_destroy: runtime check failed: (soup_message_get_connection (item->msg) == NULL)
Nov 13 18:37:08 ROGGAR gnome-shell[5285]: (../libsoup/libsoup/soup-message-queue-item.c:46):soup_message_queue_item_destroy: runtime check failed: (soup_message_get_connection (item->msg) == NULL)"
garuda-inxi:
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7e213ff5-2bfe-4fc8-a7e4-355d44341375 rw rootflags=subvol=@
quiet
cryptdevice=UUID=b7fc4c17-2b1b-43b0-af83-fff7d215f624:luks-b7fc4c17-2b1b-43b0-af83-fff7d215f624
root=/dev/mapper/luks-b7fc4c17-2b1b-43b0-af83-fff7d215f624 quiet splash
resume=/dev/mapper/luks-8f173e6c-08d2-4f4b-a9b3-461262a8d70d
systemd.unified_cgroup_hierarchy=0 loglevel=3
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: ASUSTeK product: Zephyrus G GU502DU_GA502DU v: 1.0
Mobo: ASUSTeK model: GU502DU v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GU502DU.306 date: 03/10/2021
ID-1: BAT0 charge: 61.4 Wh (100.0%) condition: 61.4/76.0 Wh (80.9%)
status: not charging
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2700 high: 2944 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2943 2: 2300
3: 2300 4: 2942 5: 2300 6: 2944 7: 2933 8: 2940 bogomips: 36725
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 57.0 C
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x002d built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Vega 10 Graphics
(raven LLVM 14.0.6 DRM 3.48 6.0.8-zen1-1-zen) direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
lanes: 1 port: c000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 5-2:3 chip-ID: 13d3:3530 class-ID: e001 serial: <filter>
Local Storage: total: 1.38 TiB used: 686.82 GiB (48.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3512GJ3 size: 476.94 GiB block-size: physical: 512 B
rev: E8FK11.T temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Crucial model: CT1000P5SSD8
lanes: 4 type: SSD serial: <filter> rev: P4CR311 temp: 50.9 C scheme: GPT
ID-1: / raw-size: 905.73 GiB size: 905.73 GiB (100.00%)
used: 686.82 GiB (75.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b7fc4c17-2b1b-43b0-af83-fff7d215f624
used: 756 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-3: /home raw-size: 905.73 GiB size: 905.73 GiB (100.00%)
ID-4: /var/log raw-size: 905.73 GiB size: 905.73 GiB (100.00%)
ID-5: /var/tmp raw-size: 905.73 GiB size: 905.73 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.16 GiB used: 2.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 25.48 GiB used: 0 KiB (0.0%)
mapped: luks-8f173e6c-08d2-4f4b-a9b3-461262a8d70d
System Temperatures: cpu: 57.2 C mobo: N/A gpu: amdgpu temp: 57.0 C
Fan Speeds (RPM): cpu: 3900
Processes: 400 Uptime: 21h 3m wakeups: 8 Memory: 23.16 GiB
used: 7.3 GiB (31.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2084
pm: pacman pkgs: 2021 libs: 530 tools: pamac,paru pm: flatpak pkgs: 63
Shell: fish v: 3.5.1 running-in: gnome-terminal inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-06-30
Last full system update: 2022-11-12
Failed units: grub-btrfs-snapper.service systemd-oomd.socket
