Yes. I have done those two.
All right try to reboot and see if it works.
IT WORKS!! My PC is back to normal. Thank you so so so much! Thank you for helping me!
Thatās great news
. Do remember that updating your system would lead you stuck at initramfs error again so read this thread in itās entirety to understand why this is happening and how to avoid it. (itās not long)
I am going to read it right now. Thank you again for your help! I hope you will have a wonderful day!
I am going to mark your first answer as solution.
Sure, if you find yourself stuck somewhere you can reach out ![]()
I was wondering...if I wait few days (updating my system can wait few days), will the bug in plymouth-git be solved? Or updating now and then getting the rude stuck at initramfs solved is the only way to update my system?
I'd not wait for an update with the fix.
The issue was reported by a user in our forum a few days ago, but it seems that so far it has not been taken into consideration... So it will take time.
I'd rather replace plymouth-git with plymouth or simply override it removing the splash boot parameter. Better to keep your system up to date...
So if I understand it, all I need to do to avoid any errors is:
sudo pacman -S plymouth
To replace the -git version and then I can garuda-update and restart?
after
you would have to update your initramfs following this post
Then you should update.
Okay, I am doing it.
What is dracut-rebuild? I don't have that command. ![]()
Can you give me your garuda-inxi I will give correct steps accordingly
garuda-inxi:
Kernel: 6.3.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=e1fd8aa5-3909-4e25-beac-5e11b1b3a928 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: STRIX B250G GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0809
date: 07/07/2017
Device-1: hidpp_battery_0 model: Logitech Wireless KeyboarWir serial: N/A
charge: 50% (should be ignored) rechargeable: yes status: N/A
Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF2
desc: 1x6 MiB
Speed (MHz): avg: 3700 high: 3702 min/max: 800/3800 scaling:
driver: intel_pstate governor: performance cores: 1: 3701 2: 3700 3: 3700
4: 3702 bogomips: 27199
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Screen-1: 0 s-res: 5520x1163 s-dpi: 88 s-size: 1594x335mm (62.76x13.19")
s-diag: 1629mm (64.13")
Monitor-1: DP-1 pos: top-left res: 1680x1050 dpi: 91
size: 470x300mm (18.5x11.81") diag: 558mm (21.95") modes: N/A
Monitor-2: HDMI-0 pos: primary,bottom-c res: 1920x1080 hz: 60 dpi: 82
Monitor-3: HDMI-1 pos: bottom-r res: 1920x1080 hz: 60 dpi: 82
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: Kingston HyperX Cloud II Wireless
lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 0951:1718 class-ID: 0300
API: ALSA v: k6.3.5-zen1-1-zen status: kernel-api
IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
Local Storage: total: 1.02 TiB used: 181.2 GiB (17.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37120G
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 87RA scheme: GPT
model: WD10EZRZ-00HTKB0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
used: 105.27 GiB (94.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-4: /var/log raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 2.19 GiB (14.1%)
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 26%
Processes: 315 Uptime: 2h 20m wakeups: 22 Memory: available: 15.56 GiB
used: 6.96 GiB (44.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1768 pm: dpkg
pkgs: 0 pm: pacman pkgs: 1754 libs: 410 tools: octopi,paru pm: snap pkgs: 14
inxi: 3.3.27
System install date: 2021-10-22
Last full system update: 2023-06-30
Is partially upgraded: Yes
Failed units: postgresql.service
Oh so you are still on mkinitcpio to generate your initramfs. Here:
to switch from plymouth-git to plymouth -
sudo plymouth-set-default-theme -R dr460nized
This will both set the default dr460nized theme as your boot splash and rebuild your initramfs
Thatās the command to regenerate initramfs for systems using dracut. We switched from using mkinitcpio to dracut for generating initramfs. It automatically detects what needs to be in the initramfs for your system unlike mkinitcpio that generates a generic initramfs. This means less modules to load on boot and thus faster bootups.
If you wish to know more about it or switch to dracut here:
Thanks for the info! I updated to dracut. I did the things, now I am going to update my system. Will be back soon with info.
Finally after an hour I could free up some space. Now, when I garuda-update, there is an error:
How can I force it to install all packages no matter what conflicts?
post the full output of garuda-update let's have a look at it. Also can you post your updated garuda-inxi just once more?
I solved it. I though it would be the situation with ALL packages. I followed this ARCH docs to "force update" that package and as it turns out no other package reports conflict.
Can you still post the output of
grep '2023-07-04' /var/log/pacman.log | tb
to be on the safe side.
