Switching from EFI GRUB to MBR GRUB to permanently fix the dualboot issue (W11/Garuda)
Hey there,
I made the same grave mistake as many others and dual-boot W11 / Garuda Dr460nized. I also already temporarily fixed my problems with a live-boot of Garuda and an EFI repair via the GUI tool (thx for the nice UX in this regard :).
I am now looking for a more permanent solution and a sanity check in regard to GRUB. My installation is an encrypted LVM Garuda, currently with GRUB “residing”/linked on the W11-SSDs EFI configuration. I can currently work and access said Garuda.
Now, to the actual question - is there a way of re-partitioning my encrypted LVM to provide my Garuda Installation/SSD with its own GRUB MBR so it can finally be freed of its Windows shackles by being bootable independently of W11 or am I just daydreaming something here? I want to avoid a completly new install of Garuda because of all the config I changed already.
If I got this right, having the MBR on-disk should remediate all the overwrite issues from M$ Windows, right?
Thanks in advance >_<
Some more pointers about my setup:
Windows 11: up-to-date, bitlocker: on, efi-boot, internal NVMe SSD(s)
UEFI: secure boot: off, default-boot: W11 (otherwise select Garuda via UEFI)
Garuda: up-to-date, on encrypted LVM, external USB-C NVMe SSD
root=UUID=cc7c5462-adce-4da8-8d92-7dfeecd7e537 rw rootflags=subvol=@
quiet rd.luks.uuid=6cb09db6-5ed4-4df3-bc77-4d1d6a716a8a loglevel=3
Type: Desktop Mobo: ASRock model: X670E Steel Legend
Megatrends LLC. v: 3.16 date: 12/18/2024
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3437 min/max: 545/5737 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3437 2: 3437 3: 3437
4: 3437 5: 3437 6: 3437 7: 3437 8: 3437 9: 3437 10: 3437 11: 3437 12: 3437
13: 3437 14: 3437 15: 3437 16: 3437 17: 3437 18: 3437 19: 3437 20: 3437
21: 3437 22: 3437 23: 3437 24: 3437 bogomips: 225162
Device-1: NVIDIA AD102 [GeForce RTX 4090] driver: nvidia v: 570.144
alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-2,DP-3 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2684 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASRock
empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-1 bus-ID: 16:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 44.0 C
gpu: nvidia,nvidia-nvswitch d-rect: 6000x2880 display-ID: 0
Monitor-1: DP-2 pos: top-right model: AOC Q27G2G3R3B serial: <filter>
built: 2022 res: mode: 2560x1440 hz: 165 scale: 178% (1.78) to: 1440x2560
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-2: DP-3 pos: bottom-l model: Dell AW3423DWF serial: <filter>
built: 2022 res: mode: 3440x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2
size: 800x337mm (31.5x13.27") diag: 868mm (34.2") modes: max: 3440x1440
min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: radeonsi device: 2
drv: nouveau device: 3 drv: swrast gbm: drv: radeonsi surfaceless:
drv: nvidia wayland: drv: nvidia x11: drv: nvidia
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 570.144 device-ID: 10de:2684
surfaces: N/A device: 1 type: integrated-gpu name: AMD Radeon Graphics
(RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 25.0.5-arch1.1
device-ID: 1002:164e surfaces: N/A device: 2 type: cpu name: llvmpipe
Device-1: NVIDIA AD102 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22ba
speed: 16 GT/s lanes: 16 bus-ID: 16:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 16:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Lautsprecher Teufel GmbH CINEBAR ONE
lanes: 1 mode: 1.1 bus-ID: 3-4:4 chip-ID: 2cc2:0027 class-ID: 0300
Device-5: C-Media Schiit Modi 3 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:7
chip-ID: 0d8c:0066 class-ID: 0300
API: ALSA v: k6.14.6-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel 82599ES 10-Gigabit SFI/SFP+ Network driver: ixgbe v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: e000
bus-ID: 02:00.0 chip-ID: 8086:10fb class-ID: 0200
IF: enp2s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: c000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
bus-ID: 08:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-4: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: b000 bus-ID: 09:00.0
Device-5: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.2:4
IF: enp20s0u1u2 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-12:8 chip-ID: 0e8d:0616
Local Storage: total: 3.69 TiB used: 86.07 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 28.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SFYRS1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 27.9 C
ID-3: /dev/nvme2n1 maj-min: 259:7 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 36.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD PC SN 740 SDDPMQD size: 476.94 GiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> fw-rev: 3108 scheme: GPT
ID-1: / raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
used: 86.04 GiB (18.0%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-6cb09db6-5ed4-4df3-bc77-4d1d6a716a8a
used: 33.5 MiB (34.9%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
ID-3: /home raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-4: /var/log raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 61.88 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
System Temperatures: cpu: 43.5 C mobo: N/A gpu: amdgpu temp: 45.0 C
Memory: total: 64 GiB note: est. available: 61.88 GiB used: 5.89 GiB (9.5%)
Processes: 525 Power: uptime: 1h 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.68 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2341 libs: 592 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date:     2025-04-17
Last full system update: 2025-05-18
One of the issues is not being able to use Secure boot for most Linux installs at least by default; this makes things more complicated with dual boot as well; also having issues with a similar setup and experiencing issues with Bitlocker drives & now encrypted drives working in Garuda. Hoping the changes to KDE in a month or so with the new Beta might help. Much appreciated.
Secure Boot is not a feature. It’s a prison from which only Microsoft has the key. It’s like giving your front door key to a stranger who can then decide whether or not to give you access to your own house. It’s madness.
Fortunately, there are ways to use W11 without Secure Boot.
If you think you can’t live without it, there are also instructions on how to enable it under Arch-based distributions.
Neither of these is correct. These problems are not caused by the operating system.
Even if the operating system were the cause, why should these “problems” be solved by upgrading the Desktop Environment?
They are your own problems because you don’t know enough about Arch and Linux.
Secure boot, tpm, cms are all scams and should all be disabled before even codering putting an OS on the system. As for bitlocker like fast boot no one actually needs them.
I have not dealt with LVM and the procedures for a long time, but I assume that this will not be possible without data loss and reinstallation of Garuda.
That would be pretty sad :\
I dunno if you can just re-partition the lvm like any other structure to make some space for an on-disk GRUB, maybe one of you ppl know though..
Just to clear some things up - I have secure boot disabled (see config description of this post), so there shouldn’t be a possibility of this influencing my problem :slight_smile:
Maybe you can get the necessary info there…
Arch-Wiki - Resizing LVM-on-LUKS
maybe hopefully :wink:
i dont use luks actually. i did resize a free space from 600mb. formated as fat32 and marked as /boot/efi and so on then started live iso chroot in garuda and installed grub on the /dev/sda (your one) partition . updated with dracut and logout correctly . reboot and press on my mobo f8 and boot it without any windows but thats near a year ago.
i do not know if you can do without installing Garuda again.
Below is a link to an script which will back up your configuration files so you can do a reinstall and then restore all your settings.
Its called ‘transfuse’
#transfuse (script to backup KDE configuration)
#   curl -O https://gitlab.com/cscs/transfuse/-/raw/main/transfuse     #
#chmod +x transfuse                                                    #
#./transfuse -b `user`                                                #
#./transfuse -p `user`                                                #
#./transfuse -pr `package`                                             #
#   TRANSFUSE                                                          #
#   A Script to Backup and Restore KDE Plasma Desktop Configurations   #
#   Usage: transfuse [option] [USER/PATIENT]                           #
#   Options:                                                           #
#    -h   --help                                      show this help   #
#    -b   --backup USER               copy and compress USER configs   #
#    -bt  --backupt USER                 backup USER appearance only   #
#    -BR  --backuproot                           backup root configs   #
#    -C   --copy USER                       copy but do not compress   #
#    -Ct  --copyt USER                     copy USER appearance only   #
#    -c   --compress                         compress copied configs   #
#    -p   --pkglists              create lists of installed packages * #
#    -pr  --pkgrestore                   install native package list * #
#    -pra --pkgrestorealien               install alien package list * #
#    -r   --restore PATIENT             restore configs /to/ PATIENT   #
#   Environment Variable       TR_COVER=1       Skip wallpaper steps   #
#   Environment Variable       TR_CHART=1        More verbose output   #
#   Environment Variable       TR_USECP=1          Use cp over rsync   #
#   (*) pkg* options require pacman package manager or an AUR helper   #
i hope this helps
Thanks for the script! Does this include changes like Screen configuration (HDR settings, active ICM profiles, multi-screen orientation), window behavior (like disabled animations, changed window frame) and Desktop app setup (taskbar, widgets etc.) for my setup?
First off - congrats on getting that to work :slight_smile: This sounds pretty risky without a backup and the moment I got kind of a full backup of my garuda setup I could just skip this and reinstall completly from scratch + recover my old system instead if I am not mistaken? (I haven’t researched this yet)
Thx :wink: yeah i have it done on my Firecuda SSD with Hyprland and KDE. I cloned my partitions to the SSD and installed Grub and it worked. I did also for getting sure the nvme out and it booted from the external SSD. Yes Backups are very important please safe your important files anyway. I never trying the transfuse script so i cant say anything about it.
Your Harddrives are both GPT so it can work with Efi but you wrote you want a MBR Grub? Why ? MBR is a Partition Table and can cause boot error if the bios is not set to legancy or Ahci. It mean you have to delete the whole drive and so on… i would not recommend it if you using your system and is no need for plug in older Pc`s. I checked my Firecuda its on GPT too :wink:
If you use secure boot with Microsoft’s keys, sure…but these days it’s pretty easy to create and enroll custom keys. :wink:
Just because Microsoft’s implementation of secure boot is such a train wreck doesn’t necessarily mean secure boot itself is a bad idea. It’s probably outside the scope of many common threat models, but what secure boot protects against is the so-called “evil maid attack.” Evil maid attack - Wikipedia
You may be thinking of something else…BitLocker provides disk encryption, kind of like LUKS for Windows. BitLocker - Wikipedia
No I know exactly what it is, just wouldn’t trust MicroSOUR not to lock me out of my files.
My post was meant in the context of Windows/Microsoft (dual boot). Of course Secure Boot can be a good thing in itself. Just not if MS is on board and via Windows is also able to fiddle with it or determine what is a legitimate key and what is not.
I think you can only have one EFI partition? Otherwise I dunno why garuda would default to installing into the Windows one in the installation process o.O
I dont know how you use your Harddrives it was meant by using a efi partiton on each harddrive.
Example:
  1. Nvme with windows on the disk . (own efi partition)
  2. SDD with Garuda on the Disk (own efi partition)
  3. SDD with other Linux on the Disk.(own efi partitiom)
So i can choose with F Key to choose which Harddrive to use to boot. Same menu as it shows your USB Pendrive in my case i press F8 and get the list 1. nvme 2. SDD 3. SDD 4. USB Pendrive 5. Lan . So if windows update their Efi it isnt destroy an other Efi for booting issues . You can do more Efi partitions but this is more for advanced Users :wink: :wink: :wink:
I did choose the Garuda Disk as main Boot drive in the Bios . Updated the Grub and it found the other installations and added it to the boot list.
I kinda feel offended by this :face_with_tongue:
But thanks for the clarification :slight_smile:
:rofl:
sorry for that wasnt meant by it. I have two efi partitions and garuda and windwows on one disk but i know how i do it my way. I dont know if it works on other PC Setups and i dont will be the ass who destroyed someones Computer if they dont have any Backups.
I can tell you for sure how i did it but no blame afterwards :laughing:
