Hello,
I loved the old icons of garuda linux, new update also update my icons. Can you guys please tell me how can I set those old icons? attaching screenshot link of old icons
Hello,
Search for the old icons via KDE Settings, or goto KDE-lok. and search, or look in whatever GUI package manager you're using. I do not remember their name, but @dr460nf1r3 certainly will (as will others).
I don't think the icons have been changed it was called beautyline both before and after the update if my memory serves me right.
If the current icons do not satisfy you you can certainly change them and add new icons go to
settings --> appearance -->icons and select the icons you like or click on the get new icons... button at the bottom right and install new icons as you need.
