umm... i am using Garuda Sway and want to change between us-colemak and inscipt-hindi such that if i press certain key i should be able to switch between the above-mentioned layouts
Hi, I don't use Sway but the previous thread seems to provide a perfect example in the Arch Wiki link: Sway - ArchWiki (specifically the first example you will see when you follow the link - this example makes use of super + space to switch the language). Of course, change it up however you like.
i found that after the "eye symbol of wlsunsets " where us is written i can left click it and config the required keyboard and it changes when i press shift key.
i am really stupid
