Sweet Theme in Terminal
The default sweet theme in Konsole does render the color 1 with very little contrast to its background.
Just a heads-up, I simply changed mine to #697388, before and after:
I am not looking for support, I just think this could be changed to a sensible default.
Thanks a lot for all you are doing :slight_smile:
Actually something I also noticed since quite a while. Taking notes, will probably be adding this @FGD ? :eyes:
It's in the process of being improved!
Need to go upstream to fix this. Hopefully they will accept the PR.
Since this is in Sweet Theme's maintainers hands now, I consider this thread as closed.
You can all go in there and LIKE the PR or comment about how much you want it. :smiley: Maybe he will merge it faster then.
@anon71037787 Eliver, who maintains the Theme, has merged the color change and seems quite happy himself!
