When I do a System Update from the Garuda Assistant, I get these warnings:
warning: kvantum-theme-sweet-git: local (r212.ab6a7d3-3) is newer than chaotic-aur (r212.ab6a7d3-1)
warning: sweet-kde-git: local (r212.ab6a7d3-3) is newer than chaotic-aur (r212.ab6a7d3-1)
If I run Refresh Mirrorlist before, it does not change. If I run Refresh Mirrorlist before, and I change country from mine (Spain) to the first option, Worldwide, it does not change.
I thought I had to let you know. I am so sorry if this post is wrong or inadequate.
System: Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ccb67658-1e21-4b0f-b3fb-2d3914c7f62a rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B250-PLUS v: Rev X.0x serial: <filter> UEFI-[Legacy]: American Megatrends
v: 0304 date: 11/14/2016
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545 serial: <filter>
CPU: Info: Quad Core model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57600
Speed: 4179 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4179 2: 4100 3: 4147 4: 4096 5: 4145 6: 4159 7: 4148
8: 4120
Graphics: Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5912
Device-2: NVIDIA GP107 [GeForce GTX 1050] vendor: ASUSTeK driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
Screen-1: 0 s-res: 6400x1440 s-dpi: 91 s-size: 1786x401mm (70.3x15.8") s-diag: 1830mm (72.1")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 92 size: 708x398mm (27.9x15.7") diag: 812mm (32")
Monitor-2: HDMI-1-1 res: 1920x1080 dpi: 96 size: 509x286mm (20.0x11.3") diag: 584mm (23")
Monitor-3: DP-1-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A driver: r8169
v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus-ID: 1-1:2
Drives: Local Storage: total: 14.1 TiB used: 197.69 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G1B0A-00H9H0 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 10WD scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM005-2DP166 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5980 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Desktop size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 040B scheme: GPT
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital model: WD30EZRZ-00Z5HB0 size: 2.73 TiB block-size:
physical: 4096 B logical: 4096 B type: HDD rpm: 5400 serial: <filter> rev: 1065 scheme: MBR
Partition: ID-1: / raw-size: 449.26 GiB size: 449.26 GiB (100.00%) used: 197.69 GiB (44.0%) fs: btrfs block-size: 4096 B
dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 449.26 GiB size: 449.26 GiB (100.00%) used: 197.69 GiB (44.0%) fs: btrfs block-size: 4096 B
ID-3: /var/log raw-size: 449.26 GiB size: 449.26 GiB (100.00%) used: 197.69 GiB (44.0%) fs: btrfs
block-size: 4096 B dev: /dev/sda4 maj-min: 8:4
ID-4: /var/tmp raw-size: 449.26 GiB size: 449.26 GiB (100.00%) used: 197.69 GiB (44.0%) fs: btrfs
ID-1: swap-1 type: zram size: 15.49 GiB used: 2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 45 C
Info: Processes: 278 Uptime: 8m wakeups: 2 Memory: 15.49 GiB used: 4.63 GiB (29.9%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: apt: 0 pacman: 1378 lib: 334 Shell: fish v: 3.3.1 default: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.08
