Servus,
I recently got a new laptop and moved the disc with the Garuda i3wm over to the new laptop. Everything worked fine, I just decided to reinstall all packages via Garuda Assistant. After the restart the taskbar disappeared. I have restarted the GIU and the system several times, updated the packages and used the recovery mode, all of which did not help. The taskbar has disappeared so far.
root=UUID=4b1797ec-dffc-4ccc-894e-8da976f739c3 rw rootflags=subvol=@
quiet resume=UUID=ecf746e7-7ab4-4992-9c2a-bc8bb8900f74 loglevel=3 ibt=off
Desktop: Sway v: 0.4 tools: swayidle avail: swaylock vt: 1 lm: greetd
Type: Laptop System: LENOVO product: 20UES1K600 v: ThinkPad T14 Gen 1
Mobo: LENOVO model: 20UES1K600 v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20UE_BU_Think_FM_ThinkPad
T14 Gen 1 uuid: <superuser required> UEFI: LENOVO v: R1BET78W(1.47 )
date: 03/26/2024
ID-1: BAT0 charge: 37.0 Wh (83.0%) condition: 44.6/50.5 Wh (88.3%)
volts: 12.4 min: 11.6 model: LGC 5B10W139 type: Li-poly serial: <filter>
status: not charging cycles: 142
Info: model: AMD Ryzen 5 PRO 4650U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
microcode: 0x8600109
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1574 high: 2100 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 2100
3: 1400 4: 1400 5: 2100 6: 1400 7: 1400 8: 1400 9: 2100 10: 1400 11: 1400
12: 1400 bogomips: 50304
Device-1: AMD Renoir [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1
empty: DP-1,DP-2 bus-ID: 08:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 40.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:2 chip-ID: 04f2:b6d0
Display: wayland server: Xwayland v: 24.1.0 compositor: Sway v: 0.4
driver: gpu: amdgpu d-rect: 3840x1080 display-ID: 1
Monitor-1: HDMI-A-1 pos: right model: BenQ RL2755 serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2 scale: 1
Monitor-2: eDP-1 pos: primary,left model: LG Display 0x05fa built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 scale: 1
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.2-arch1.1
device-ID: 1002:1636 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 08:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.2.0 status: off with: 1: pipewire-pulse
status: off 2: wireplumber status: off 3: pipewire-alsa type: plugin
port: 3400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
port: 2000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 6-4:3 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 10c
Local Storage: total: 596.18 GiB used: 65.24 GiB (10.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM128GDHTNG-8310A size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 80070C00 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: SK Hynix
model: HFS512GD9TNI-L2B0B size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11720C10 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 101.94 GiB size: 101.94 GiB (100.00%)
used: 65.24 GiB (64.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 101.94 GiB size: 101.94 GiB (100.00%)
ID-4: /var/log raw-size: 101.94 GiB size: 101.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 101.94 GiB size: 101.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 22.7 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 50.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 24 GiB note: est. available: 22.7 GiB used: 2.7 GiB (11.9%)
Processes: 318 Power: uptime: 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.07 GiB Init: systemd v: 256
Packages: pm: pacman pkgs: 1515 libs: 419 tools: pacseek,paru,yay
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: foot inxi: 3.3.35
System install date: 2024-05-06
Last full system update: 2024-07-01
Relevant software: snapper tlp NetworkManager dracut
Here a screenshot:
LG
