[SOLVED]
Hello Garuda users. what do y'all use for redshift alternatives on sway? i have sway installe now, with a program that does the same thing as redshift, but i can't remember what it is and i need to reinstall to a new drive.
Please read the following template before requesting assistance
Kernel: 6.2.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c0f5137a-1d39-42ce-8afd-4d4c588d946e rw [email protected]
loglevel=3 ibt=off
Desktop: sway v: 1.8.1 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Desktop Mobo: Gigabyte model: Z590 AORUS ELITE AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F3
date: 01/20/2021
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3854 high: 4666 min/max: 800/5100 scaling:
driver: intel_pstate governor: performance cores: 1: 3800 2: 3800 3: 3800
4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 4666 12: 3800
13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121596
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: Sapphire
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:73ef
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: sway v: 1.8.1 driver: gpu: amdgpu display-ID: 1
Monitor-1: HDMI-A-1 model: HP VH240a serial: <filter> built: 2020
res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 scale: 1
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 1-5:3 bus-ID: 00:1f.3 chip-ID: 8888:1234 chip-ID: 8086:f0c8
class-ID: 0300 serial: <filter> class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: FDUCE PRO AUDIO MADE type: USB driver: snd-usb-audio
Sound API: ALSA v: k6.2.6-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
bus-ID: 1-14:8 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 2.3 TiB used: 281.01 GiB (11.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
type: SSD serial: <filter> rev: 2B6Q
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk
model: Cruzer Glide 3.0 size: 29.06 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 464.17 GiB size: 464.17 GiB (100.00%)
used: 281 GiB (60.5%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 13.6 MiB (2.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 464.17 GiB size: 464.17 GiB (100.00%)
ID-4: /var/log raw-size: 464.17 GiB size: 464.17 GiB (100.00%)
ID-5: /var/tmp raw-size: 464.17 GiB size: 464.17 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.22 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 32.0 C
Processes: 399 Uptime: 45m wakeups: 0 Memory: 31.22 GiB
used: 3.11 GiB (9.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1589
libs: 400 tools: gnome-software,pamac,paru pm: flatpak pkgs: 0 Shell: fish
v: 3.6.0 default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-11-06
Last full system update: 2023-03-14
Relevant software: snapper(custom) NetworkManager mkinitcpio
