Sway logout, black screen and not sddm
As the title states when I logout from Sway I get a black screen which forces me to reboot. Sway can't seem to find SDDM. I have the git version installed. I have both KDE and Sway installed, from a fresh boot I can choose between Sway and KDE. But, if I logout of Sway and try to switch to KDE when I logout it's just a black blank screen. Any advice?
Kernel: 6.1.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=146f5d62-3abb-4ed6-84cf-0e1ac8936861 rw rootflags=subvol=@
quiet
cryptdevice=UUID=1cdf6896-92c1-47d9-98a9-255f57d2b573:luks-1cdf6896-92c1-47d9-98a9-255f57d2b573
root=/dev/mapper/luks-1cdf6896-92c1-47d9-98a9-255f57d2b573 quiet splash
resume=/dev/mapper/luks-0742a68e-ecb1-42ea-847b-793b11e10579 loglevel=3
wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.90
date: 03/17/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3954 high: 4675 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3739 4: 3800 5: 3800 6: 3800 7: 4675 8: 4669 9: 3721 10: 3800 11: 3800
12: 4675 13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121604
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1,DP-3,HDMI-A-1 bus-ID: 2d:00.0 chip-ID: 1002:73bf
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Acer XZ342CK serial: <filter> built: 2020
res: 3440x1440 dpi: 110 gamma: 1.2 size: 797x334mm (31.38x13.15")
diag: 864mm (34") modes: max: 3440x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 15.0.7 DRM 3.49 6.1.8-zen1-1-zen) direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.1.8-zen1-1-zen running: yes
lanes: 1 port: e000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 3.91 TiB used: 378.81 GiB (9.5%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Smart Modular Tech.
model: SHPP41-2000GM size: 1.82 TiB block-size: physical: 512 B
rev: 51060A20 temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 26.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Leven model: JAJS600M2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6A3 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 378.81 GiB (20.7%)
mapped: luks-1cdf6896-92c1-47d9-98a9-255f57d2b573
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
used: 378.81 GiB (20.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-0742a68e-ecb1-42ea-847b-793b11e10579
System Temperatures: cpu: 67.2 C mobo: 23.2 C gpu: amdgpu temp: 49.0 C
mem: 52.0 C
Fan Speeds (RPM): fan-2: 1470 fan-3: 1511 fan-5: 1578 fan-6: 1544
gpu: amdgpu fan: 0
Processes: 444 Uptime: 1h 11m wakeups: 0 Memory: 31.27 GiB
used: 6.3 GiB (20.1%) Init: systemd v: 252 default: graphical
pkgs: 2195 libs: 585 tools: octopi,pamac,paru,yay Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date:     2023-01-28
Last full system update: 2023-01-29 ↻
Welcome :slight_smile:
I never logged out, I just reboot/restart to get the grub window and change to other DE.
Maybe a translation problem, what do you do exactly?
A friend of mine recently installed the dragonized edition, and they as well as me both faced weird issues with logging out. A lot of weird stuff starts to happen, like sddm not showing, and other stuff when logging back in. I think KDE or SDDM or both don't like when somebody logs out.
Are you logging out via wayland-logout? I have never had issues with it, though I'm using greetd
Yes, I originally installed KDE dragonized ISO. I then added all sway with wayland packages, etc including all the Sway packages that garuda includes with the Sway ISO.
Sway works perfect just like the sway garuda ISO except for when I logout.
I like switching DE's from KDE wayland and Sway. But, when I logout of Sway I get a blank screen and doesn't show SDDM if I want to go back to KDE wayland.
Again for me as a layman, it's not two DE's as dual boot, but a mix of KDE and Sway?
I'm not sure if this will work. SDDM does not fully support Wayland (planned support in upcoming release 0.20: Greeter on Wayland - rebased by aleixpol · Pull Request #1393 · sddm/sddm · GitHub), and Sway does not support login managers at all (Add swayrun command to exec sway using a login shell by electrickite · Pull Request #3634 · swaywm/sway · GitHub).
Is it a TTY, or no shell at all? Can you switch to a different TTY?
Did you set up the config for it? SDDM - ArchWiki
I'll try this later on, " Did you set up the config for it? SDDM - ArchWiki"
As of right now if I'm in KDE I can logout and get the SDDM login manager and switch to Sway just fine, it's only if I'm in Sway and logout I get a blank screen.
I've tried to get a command prompt without any luck and I just end up having to do a hard reboot.
I'm new to Sway and use KDE for productivity at the moment, and in my spare time I switch to Sway to learn and eventually go to Sway full time.
Another thing you can try to get this working is just switch from SDDM to Greetd. Greetd works fine with Sway.
