my swap was used by system previously but since some days im noticing its not being used
swapon and garuda-inxi output here
swapon --show
NAME TYPE SIZE USED PRIO
/dev/zram0 partition 7.6G 0B 100
/dev/nvme0n1p7 partition 16.8G 0B -2
Kernel: 6.14.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=8cfa510d-8533-4290-a776-520ee1b846b6 rw rootflags=subvol=@
quiet resume=UUID=8b3cc991-5a40-4e12-ad6e-5f4bb09d8645 loglevel=3 ibt=off
Type: Laptop System: HP product: HP Laptop 15s-du1xxx
Mobo: HP model: 85F1 v: 37.30 serial: <superuser required>
part-nu: 45W89PA#ACJ uuid: <superuser required> UEFI: Insyde v: F.67
date: 08/07/2024
ID-1: BAT1 charge: 34.3 Wh (100.0%) condition: 34.3/40.9 Wh (84.0%)
volts: 12.7 min: 11.3 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-10110U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0x100
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 559 min/max: 400/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 559 2: 559 3: 559 4: 559 bogomips: 20799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
chip-ID: 30c9:0035 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2017 res:
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.1-arch1.2
device-ID: 8086:9b41 memory: 7.38 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 25.1.1-arch1.2
device-ID: 8086:9b41 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.1.1-arch1.2 (LLVM
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
API: ALSA v: k6.14.9-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.4 status: active with: 1: pipewire-pulse
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 0bda:b00c
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 56.39 GiB (11.8%)
model: MZVLQ512HALU-000H1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS4NFXV temp: 41.9 C scheme: GPT
ID-1: / raw-size: 233.57 GiB size: 233.57 GiB (100.00%)
used: 56.39 GiB (24.1%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 1.5 GiB size: 1.5 GiB (99.80%)
used: 620 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 233.57 GiB size: 233.57 GiB (100.00%)
ID-4: /var/log raw-size: 233.57 GiB size: 233.57 GiB (100.00%)
ID-5: /var/tmp raw-size: 233.57 GiB size: 233.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.56 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
ID-2: swap-2 type: partition size: 16.76 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 49.0 C pch: 47.0 C mobo: N/A
Memory: total: 8 GiB available: 7.56 GiB used: 3.57 GiB (47.2%)
Processes: 240 Power: uptime: 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1328 libs: 398 tools: octopi,paru Compilers:
inxi: 3.3.38
System install date: 2025-05-21
Last full system update: 2025-06-01
