Hi all,
Since mid-January, I've begun to have issues with my suspend-then-hibernate functionality. I was hoping that the latest systemd update might resolve my issue, but no luck.
On my system, suspending (i.e. systemctl suspend) and hibernating (i.e. systemctl hibernate) both work completely as expected. With suspend, my system instantly suspends. I'm able to suspend to either s2idle or deep depending on my choice of configuration. With hibernate, my system displays the lock screen for a few seconds before hibernating and powering off.
However, suspend-then-hibernate (i.e. systemctl suspend-then-hibernate) does not work correctly. When I use suspend-then-hibernate, my system displays a black screen with a visible cursor for about a minute before suspending. When resuming-- from both suspend or hibernate states via suspend-then-hibernate-- my system displays the black screen with visible cursor for 3-5 minutes before displaying the lock screen. The visible cursor responds to mouse input during this, but I am unable to switch to a virtual terminal.
My current sleep.conf is as below. The file is unchanged from December, when suspend-then-hibernate worked correctly.
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it under the
# terms of the GNU Lesser General Public License as published by the Free
# Software Foundation; either version 2.1 of the License, or (at your option)
# any later version.
# Entries in this file show the compile time defaults. Local configuration
# should be created by either modifying this file, or by creating "drop-ins" in
# the sleep.conf.d/ subdirectory. The latter is generally recommended.
# Defaults can be restored by simply deleting this file and all drop-ins.
# See systemd-sleep.conf(5) for details.
[Sleep]
AllowSuspend=yes
AllowHibernation=yes
AllowSuspendThenHibernate=yes
AllowHybridSleep=no
#SuspendMode=
#SuspendState=mem standby freeze
HibernateMode=platform shutdown
HibernateState=disk
#HybridSleepMode=suspend platform shutdown
HybridSleepState=disk
HibernateDelaySec=2700sec
#HibernateDelaySec=90sec
And my garuda-inxi is as follows. I have additionally tested this using the linux and linux-lts kernels, in case the issue was somehow related to linux-zen.
Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=79593c2e-62f0-445f-9116-964cb89e34c7 rw rootflags=subvol=@
resume=UUID=84ac06b1-8de9-4d06-ab37-23866ae6d543 loglevel=3
mem_sleep_default=deep nvme.noacpi=1 i915.enable_psr=1
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 info: latte-dock
Type: Laptop System: Framework product: Laptop v: AA
Mobo: Framework model: FRANBMCP0A v: AA serial: <superuser required>
UEFI: INSYDE v: 03.10 date: 07/19/2022
ID-1: BAT1 charge: 39.8 Wh (79.4%) condition: 50.1/55.0 Wh (91.0%)
volts: 16.1 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: discharging cycles: 109
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2018 high: 2400 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 2400 3: 1137
4: 607 5: 2400 6: 2400 7: 2400 8: 2400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63")
s-diag: 716mm (28.19")
Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res: 2256x1504
hz: 60 dpi: 201 gamma: 1.2 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
ratio: 3:2 modes: 2256x1504
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
chip-ID: 8086:a0c8 class-ID: 0403
Sound API: ALSA v: k6.2.8-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725
IF: wlp170s0 state: up mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-10:4 chip-ID: 8087:0032 class-ID: e001
address: <filter>
Local Storage: total: 465.76 GiB used: 210.57 GiB (45.2%)
model: WDBRPG5000ANC-WRSN size: 465.76 GiB block-size: physical: 512 B
rev: 111130WD temp: 44.9 C scheme: GPT
ID-1: / raw-size: 398.98 GiB size: 398.98 GiB (100.00%)
used: 210.54 GiB (52.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 34.7 MiB (11.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 398.98 GiB size: 398.98 GiB (100.00%)
ID-4: /var/log raw-size: 398.98 GiB size: 398.98 GiB (100.00%)
ID-5: /var/tmp raw-size: 398.98 GiB size: 398.98 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.14 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 32.23 GiB used: 0 KiB (0.0%)
priority: 5 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 358 Uptime: 44m wakeups: 58992 Memory: 31.14 GiB
used: 6.91 GiB (22.2%) Init: systemd v: 253 default: graphical
pkgs: 2137 libs: 553 tools: octopi,paru,yay Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
System install date: 2022-01-09
Last full system update: 2023-03-30 ↻
Relevant software: snapper tlp NetworkManager dracut
Failed units: root-resume.service
