Hello guys, i have been looking for a solution to this issue for a while, the issue has to do with my display resolution. When i was using windows in the past, i had the resolution options for 1920x1080 and another higher resolution which i don't remember. but on this operating system, the highest is 1366x768 which makes the UI huge which is a problem for me since i need screen space for art, the not sketch area takes up too much space and a lot of space is wasted on other software where you cant resize stuff.
I have tried using the tool Xrandr, but the resolution option disappears (though i must state that it doesn't change anything visually unlike in windows where element sizes changed so i have a feeling it might not be working either) after restart and the display scaling thing in Xrandr for zooming in or out kinda works but the desktop UI elements inconsistently break and this scaling doesn't save either. For an example in element breaking, the bottom dock in KDE is no longer in the bottom but in the most randomest of places.
Commands i have run till now
xrandr --output eDP --scale 1.1x1.1
xrandr --newmode 1920x1080 173.00 1920 2048 2248 2576 1080 1088 1120 -hsync +vsync
xrandr --addmode eDP 1920x1080
xrandr --display eDP 1920x1080
I must mention that I have looked in several threads related to display but it seems that no one seems to be having the same issue as me, the closest was someone having a wrong display resolution on SDDM (my sddm display seems to be of the accurate resolution since it isn't overly huge)
So i must ask you guys, what should i be doing to solve my problem?
Garuda -inxi output below
Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6f366281-6886-4c4d-9474-7c3ceb081de0 rw rootflags=subvol=@
resume=UUID=1d580518-df5e-4cc6-a1ad-674e176b1ed9 loglevel=3 ibt=off
Type: Laptop System: Hewlett-Packard product: HP 247 G8 Notebook PC v: N/A
Mobo: Hewlett-Packard model: 8908 v: 58.19 serial: <superuser required>
UEFI: AMI v: F.11 date: 09/29/2021
ID-1: BAT0 charge: 36.8 Wh (100.0%) condition: 36.8/36.8 Wh (100.0%)
volts: 12.9 min: 11.3 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Info: model: AMD Ryzen 3 5300U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2463 high: 2600 min/max: 1400/3900 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1504 2: 2600
3: 2600 4: 2600 5: 2600 6: 2600 7: 2600 8: 2600 bogomips: 41520
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 43.0 C
Device-2: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 0408:5365
class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1412 built: 2019
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1366x768 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.10-zen2-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 0bda:b00c
Local Storage: total: 476.94 GiB used: 24.44 GiB (5.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: ABSSDNVMe512GB size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: EDFB00.7 temp: 32.9 C scheme: GPT
used: 24.44 GiB (5.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.11 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.2 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 263 Uptime: 12m wakeups: 1 Memory: total: 8 GiB note: est.
available: 7.11 GiB used: 2.53 GiB (35.5%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1928 libs: 529 tools: octopi,pamac,paru
inxi: 3.3.28
System install date: 2023-08-13
Last full system update: 2023-08-13
