"superproductivity" failed to build
hi,
So I am trying to 'build' this package "superproductivity" from pamac...
during the build process, there was an error
Building superproductivity...
Cloning superproductivity build files...
==> Making package: superproductivity 6.4.0-1 (Monday 03 May 2021 02:21:37 PM)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
  -> Downloading superproductivity-6.4.0.tar.gz...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
100   137  100   137    0     0     56      0  0:00:02  0:00:02 --:--:--    56
  0     0    0     0    0     0      0      0 --:--:--  0:00:02 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:03 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:04 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:05 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:06 --:--:--     0
100 18527    0 18527    0     0   2417      0 --:--:--  0:00:07 --:--:--  3649
100 1008k    0 1008k    0     0   117k      0 --:--:--  0:00:08 --:--:--  204k
100 4749k    0 4749k    0     0   523k      0 --:--:--  0:00:09 --:--:-- 1077k
  -> Found superproductivity.desktop
  -> Found superproductivity.sh
==> Validating source files with md5sums...
    superproductivity-6.4.0.tar.gz ... Passed
    superproductivity.desktop ... Passed
    superproductivity.sh ... Passed
==> Removing existing $srcdir/ directory...
==> Extracting sources...
  -> Extracting superproductivity-6.4.0.tar.gz with bsdtar
==> Starting prepare()...
==> Starting build()...
yarn install v1.22.10
[1/4] Resolving packages...
warning Resolution field "webpack@4.44.2" is incompatible with requested version "webpack@4.44.1"
[2/4] Fetching packages...
info fsevents@2.3.1: The platform "linux" is incompatible with this module.
info "fsevents@2.3.1" is an optional dependency and failed compatibility check. Excluding it from installation.
info fsevents@1.2.13: The platform "linux" is incompatible with this module.
info "fsevents@1.2.13" is an optional dependency and failed compatibility check. Excluding it from installation.
info fsevents@2.1.3: The platform "linux" is incompatible with this module.
info "fsevents@2.1.3" is an optional dependency and failed compatibility check. Excluding it from installation.
[3/4] Linking dependencies...
warning "@angular-builders/custom-webpack > @angular-devkit/build-angular@0.1002.1" has incorrect peer dependency "@angular/compiler-cli@^10.0.0".
warning "@angular-builders/custom-webpack > @angular-devkit/build-angular > @ngtools/webpack@10.2.1" has incorrect peer dependency "@angular/compiler-cli@^10.0.0".
warning " > @angular-eslint/builder@1.1.0" has unmet peer dependency "@angular-devkit/architect@~0.1001.4 || ~0.1100.1".
warning " > @angular-eslint/schematics@1.1.0" has unmet peer dependency "@angular-devkit/core@*".
warning " > @angular-eslint/schematics@1.1.0" has unmet peer dependency "@angular-devkit/schematics@*".
warning " > @ngrx/data@10.1.2" has incorrect peer dependency "@angular/common@^10.0.0".
warning " > @ngrx/data@10.1.2" has incorrect peer dependency "@angular/core@^10.0.0".
warning " > @ngrx/data@10.1.2" has incorrect peer dependency "@ngrx/store@10.1.2".
warning " > @ngrx/effects@10.1.2" has incorrect peer dependency "@angular/core@^10.0.0".
warning " > @ngrx/effects@10.1.2" has incorrect peer dependency "@ngrx/store@10.1.2".
warning " > @ngrx/entity@10.1.2" has incorrect peer dependency "@angular/core@^10.0.0".
warning " > @ngrx/entity@10.1.2" has incorrect peer dependency "@ngrx/store@10.1.2".
warning "@ngrx/schematics > @angular/core@10.2.4" has incorrect peer dependency "zone.js@~0.10.3".
warning " > @ngrx/store@10.1.1" has incorrect peer dependency "@angular/core@^10.0.0".
warning " > @ngrx/store-devtools@10.1.2" has incorrect peer dependency "@ngrx/store@10.1.2".
warning " > angular2-promise-buttons@4.0.10" has incorrect peer dependency "@angular/common@^9.0.4".
warning " > angular2-promise-buttons@4.0.10" has incorrect peer dependency "@angular/core@^9.0.4".
warning " > codelyzer@6.0.1" has unmet peer dependency "tslint@^5.0.0 || ^6.0.0".
warning " > ngx-date-time-picker-schedule@9.4.13" has incorrect peer dependency "@angular/common@^8.0.0 || ^9.0.0 || ^10.0.0".
warning " > ngx-date-time-picker-schedule@9.4.13" has incorrect peer dependency "@angular/core@^8.0.0 || ^9.0.0 || ^10.0.0".
warning " > ngx-date-time-picker-schedule@9.4.13" has incorrect peer dependency "@angular/cdk@^8.0.0 || ^9.0.0 || ^10.0.0".
warning " > ngx-markdown@10.1.1" has incorrect peer dependency "@angular/common@^10.0.0".
warning " > ngx-markdown@10.1.1" has incorrect peer dependency "@angular/core@^10.0.0".
warning " > ngx-markdown@10.1.1" has incorrect peer dependency "@angular/platform-browser@^10.0.0".
warning " > ngx-markdown@10.1.1" has incorrect peer dependency "zone.js@^0.10.3".
[4/4] Building fresh packages...
success Saved lockfile.
$ cross-env-shell node ./tools/is-skip-postinstall.js --env.SKIP_POST_INSTALL=$SKIP_POST_INSTALL || ngcc --tsconfig src/tsconfig.app.json
undefined
Compiling @angular/core : fesm2015 as esm2015
Compiling @angular/cdk/keycodes : fesm2015 as esm2015
Compiling @angular/animations : fesm2015 as esm2015
Compiling @angular/compiler/testing : fesm2015 as esm2015
Compiling @angular/service-worker/config : fesm2015 as esm2015
Compiling @angular/animations : esm2015 as esm2015
Compiling @angular/animations : main as umd
Compiling @angular/cdk/keycodes : esm2015 as esm2015
Compiling @angular/cdk/keycodes : main as umd
Compiling @angular/service-worker/config : esm2015 as esm2015
Compiling @angular/service-worker/config : main as umd
Compiling @angular/compiler/testing : esm2015 as esm2015
Compiling @angular/compiler/testing : main as umd
Compiling @angular/animations/browser : fesm2015 as esm2015
Compiling @angular/cdk/observers : fesm2015 as esm2015
Compiling @angular/common : fesm2015 as esm2015
Compiling @angular/cdk/collections : fesm2015 as esm2015
Compiling @angular/platform-browser : fesm2015 as esm2015
Compiling @angular/cdk/platform : fesm2015 as esm2015
Compiling @angular/cdk/bidi : fesm2015 as esm2015
Compiling @angular/forms : fesm2015 as esm2015
Compiling @angular/cdk/a11y : fesm2015 as esm2015
Compiling @angular/platform-browser/animations : fesm2015 as esm2015
Compiling @angular/cdk/scrolling : fesm2015 as esm2015
Compiling @angular/cdk/portal : fesm2015 as esm2015
Compiling @angular/cdk/text-field : fesm2015 as esm2015
Compiling @angular/cdk/overlay : fesm2015 as esm2015
Compiling @angular/common/http : fesm2015 as esm2015
Compiling @angular/material/core : fesm2015 as esm2015
Compiling @ngx-formly/core : fesm2015 as esm2015
Compiling @ngrx/store : fesm2015 as esm2015
Compiling @angular/cdk/layout : fesm2015 as esm2015
Compiling @angular/material/form-field : fesm2015 as esm2015
Compiling @angular/material/button : fesm2015 as esm2015
Compiling @ngx-formly/core/select : fesm2015 as esm2015
Compiling @angular/material/checkbox : fesm2015 as esm2015
Compiling @ngx-formly/material/form-field : fesm2015 as esm2015
Compiling @angular/material/input : fesm2015 as esm2015
Compiling @angular/material/select : fesm2015 as esm2015
Compiling @angular/core/testing : fesm2015 as esm2015
Compiling @angular/material/radio : fesm2015 as esm2015
Compiling @angular/platform-browser-dynamic : fesm2015 as esm2015
Compiling @ngrx/effects : fesm2015 as esm2015
Compiling @angular/material/dialog : fesm2015 as esm2015
Compiling @ngx-formly/material/input : fesm2015 as esm2015
Compiling @ngx-formly/material/textarea : fesm2015 as esm2015
Compiling @ngx-formly/material/radio : fesm2015 as esm2015
Compiling @ngx-formly/material/checkbox : fesm2015 as esm2015
Compiling @ngx-formly/material/multicheckbox : fesm2015 as esm2015
Compiling @ngx-formly/material/select : fesm2015 as esm2015
Compiling @angular/material/icon : fesm2015 as esm2015
Compiling @angular/material/tooltip : fesm2015 as esm2015
Compiling @angular/platform-browser/testing : fesm2015 as esm2015
Compiling @angular/material/datepicker : fesm2015 as esm2015
Compiling @angular/material/slider : fesm2015 as esm2015
Compiling @angular/material/slide-toggle : fesm2015 as esm2015
Compiling @angular/cdk/accordion : fesm2015 as esm2015
Compiling @angular/material/divider : fesm2015 as esm2015
Compiling @angular/cdk/stepper : fesm2015 as esm2015
Compiling @angular/cdk/table : fesm2015 as esm2015
Compiling @angular/material/paginator : fesm2015 as esm2015
Compiling @angular/material/sort : fesm2015 as esm2015
Compiling @angular/cdk/tree : fesm2015 as esm2015
Compiling @angular/platform-browser-dynamic/testing : fesm2015 as esm2015
Compiling @angular/platform-server : fesm2015 as esm2015
Compiling @angular/common/testing : fesm2015 as esm2015
Compiling @angular/router : fesm2015 as esm2015
Compiling @ngrx/entity : fesm2015 as esm2015
Compiling @ngx-translate/core : fesm2015 as esm2015
Compiling @ngrx/effects/testing : fesm2015 as esm2015
Compiling @ngrx/store/testing : fesm2015 as esm2015
Compiling @ngx-formly/core/json-schema : fesm2015 as esm2015
Compiling @ngx-formly/material : fesm2015 as esm2015
Compiling @ngx-formly/material/datepicker : fesm2015 as esm2015
Compiling @ngx-formly/material/native-select : fesm2015 as esm2015
Compiling @ngx-formly/material/slider : fesm2015 as esm2015
Compiling @ngx-formly/material/toggle : fesm2015 as esm2015
Compiling ng2-dragula : fesm2015 as esm2015
Compiling ngx-date-time-picker-schedule : fesm2015 as esm2015
Compiling @angular/animations/browser/testing : fesm2015 as esm2015
Compiling @angular/cdk/clipboard : fesm2015 as esm2015
Compiling @angular/cdk/drag-drop : fesm2015 as esm2015
Compiling @angular/common/http/testing : fesm2015 as esm2015
Compiling @angular/material/autocomplete : fesm2015 as esm2015
Compiling @angular/material/badge : fesm2015 as esm2015
Compiling @angular/material/bottom-sheet : fesm2015 as esm2015
Compiling @angular/material/button-toggle : fesm2015 as esm2015
Compiling @angular/material/card : fesm2015 as esm2015
Compiling @angular/material/chips : fesm2015 as esm2015
Compiling @angular/material/expansion : fesm2015 as esm2015
Compiling @angular/material/grid-list : fesm2015 as esm2015
Compiling @angular/material/icon/testing : fesm2015 as esm2015
Compiling @angular/material/list : fesm2015 as esm2015
Compiling @angular/material/menu : fesm2015 as esm2015
Compiling @angular/material/progress-bar : fesm2015 as esm2015
Compiling @angular/material/progress-spinner : fesm2015 as esm2015
Compiling @angular/material/sidenav : fesm2015 as esm2015
Compiling @angular/material/snack-bar : fesm2015 as esm2015
Compiling @angular/material/stepper : fesm2015 as esm2015
Compiling @angular/material/table : fesm2015 as esm2015
Compiling @angular/material/tabs : fesm2015 as esm2015
Compiling @angular/material/toolbar : fesm2015 as esm2015
Compiling @angular/material/tree : fesm2015 as esm2015
Compiling @angular/material-moment-adapter : fesm2015 as esm2015
Compiling @angular/platform-server/testing : fesm2015 as esm2015
Compiling @angular/router/testing : fesm2015 as esm2015
Compiling @angular/service-worker : fesm2015 as esm2015
Compiling @ngrx/data : fesm2015 as esm2015
Compiling @ngrx/store-devtools : fesm2015 as esm2015
Compiling @ngx-translate/http-loader : fesm2015 as esm2015
Compiling angular-material-css-vars : fesm2015 as esm2015
Compiling angular2-promise-buttons : fesm2015 as esm2015
Compiling ng2-charts : fesm2015 as esm2015
Compiling ngx-markdown : fesm2015 as esm2015
Compiling @angular/core : esm2015 as esm2015
Compiling @angular/animations/browser : esm2015 as esm2015
Compiling @angular/core : main as umd
Compiling @angular/animations/browser : main as umd
Compiling @angular/animations/browser/testing : esm2015 as esm2015
Compiling @angular/animations/browser/testing : main as umd
Compiling @angular/common : esm2015 as esm2015
Compiling @angular/common : main as umd
Compiling @angular/cdk/clipboard : esm2015 as esm2015
Compiling @angular/cdk/clipboard : main as umd
Compiling @angular/cdk/platform : esm2015 as esm2015
Compiling @angular/cdk/platform : main as umd
Compiling @angular/cdk/bidi : esm2015 as esm2015
Compiling @angular/cdk/collections : esm2015 as esm2015
Compiling @angular/cdk/bidi : main as umd
Compiling @angular/cdk/collections : main as umd
Compiling @angular/cdk/scrolling : esm2015 as esm2015
Compiling @angular/cdk/scrolling : main as umd
Compiling @angular/cdk/drag-drop : esm2015 as esm2015
Compiling @angular/cdk/drag-drop : main as umd
Compiling @angular/common/http : esm2015 as esm2015
Compiling @angular/common/http/testing : esm2015 as esm2015
Compiling @angular/common/http : main as umd
Compiling @angular/common/http/testing : main as umd
Compiling @angular/cdk/observers : esm2015 as esm2015
Compiling @angular/cdk/observers : main as umd
Compiling @angular/cdk/a11y : esm2015 as esm2015
Compiling @angular/cdk/a11y : main as umd
Compiling @angular/platform-browser : esm2015 as esm2015
Compiling @angular/platform-browser : main as umd
Compiling @angular/platform-browser/animations : esm2015 as esm2015
Compiling @angular/platform-browser/animations : main as umd
Compiling @angular/forms : esm2015 as esm2015
Compiling @angular/material/core : esm2015 as esm2015
Compiling @angular/forms : main as umd
Compiling @angular/material/core : main as umd
Compiling @angular/cdk/portal : esm2015 as esm2015
Compiling @angular/cdk/portal : main as umd
Compiling @angular/cdk/overlay : esm2015 as esm2015
Compiling @angular/cdk/overlay : main as umd
Compiling @angular/material/form-field : esm2015 as esm2015
Compiling @angular/material/autocomplete : esm2015 as esm2015
Compiling @angular/material/form-field : main as umd
Compiling @angular/material/autocomplete : main as umd
Compiling @angular/material/badge : esm2015 as esm2015
Compiling @angular/material/badge : main as umd
Compiling @angular/cdk/layout : esm2015 as esm2015
Compiling @angular/cdk/layout : main as umd
Compiling @angular/material/bottom-sheet : esm2015 as esm2015
Compiling @angular/material/bottom-sheet : main as umd
Compiling @angular/material/button-toggle : esm2015 as esm2015
Compiling @angular/material/button-toggle : main as umd
Compiling @angular/material/card : esm2015 as esm2015
Compiling @angular/material/chips : esm2015 as esm2015
Compiling @angular/material/card : main as umd
Compiling @angular/material/chips : main as umd
Compiling @angular/cdk/accordion : esm2015 as esm2015
Compiling @angular/material/expansion : esm2015 as esm2015
Compiling @angular/cdk/accordion : main as umd
Compiling @angular/material/grid-list : esm2015 as esm2015
Compiling @angular/material/expansion : main as umd
Compiling @angular/material/grid-list : main as umd
Compiling @angular/material/icon : esm2015 as esm2015
Compiling @angular/material/icon : main as umd
Compiling @angular/material/icon/testing : esm2015 as esm2015
Compiling @angular/material/icon/testing : main as umd
Compiling @angular/material/divider : esm2015 as esm2015
Compiling @angular/material/divider : main as umd
Compiling @angular/material/list : esm2015 as esm2015
Compiling @angular/material/menu : esm2015 as esm2015
Compiling @angular/material/list : main as umd
Compiling @angular/material/menu : main as umd
Compiling @angular/material/progress-bar : esm2015 as esm2015
Compiling @angular/material/progress-bar : main as umd
Compiling @angular/material/progress-spinner : esm2015 as esm2015
Compiling @angular/material/progress-spinner : main as umd
Compiling @angular/material/sidenav : esm2015 as esm2015
Compiling @angular/material/sidenav : main as umd
Compiling @angular/material/button : esm2015 as esm2015
Compiling @angular/material/button : main as umd
Compiling @angular/material/snack-bar : esm2015 as esm2015
Compiling @angular/cdk/stepper : esm2015 as esm2015
Compiling @angular/material/snack-bar : main as umd
Compiling @angular/cdk/stepper : main as umd
Compiling @angular/material/stepper : esm2015 as esm2015
Compiling @angular/material/stepper : main as umd
Compiling @angular/cdk/table : esm2015 as esm2015
Compiling @angular/cdk/table : main as umd
Compiling @angular/material/select : esm2015 as esm2015
Compiling @angular/material/select : main as umd
Compiling @angular/material/tooltip : esm2015 as esm2015
Compiling @angular/material/tooltip : main as umd
Compiling @angular/material/paginator : esm2015 as esm2015
Compiling @angular/material/paginator : main as umd
Compiling @angular/material/sort : esm2015 as esm2015
Compiling @angular/material/sort : main as umd
Compiling @angular/material/table : esm2015 as esm2015
Compiling @angular/material/table : main as umd
Compiling @angular/material/tabs : esm2015 as esm2015
Compiling @angular/material/tabs : main as umd
Compiling @angular/material/toolbar : esm2015 as esm2015
Compiling @angular/cdk/tree : esm2015 as esm2015
Compiling @angular/material/toolbar : main as umd
Compiling @angular/cdk/tree : main as umd
Compiling @angular/material/tree : esm2015 as esm2015
Compiling @angular/material/tree : main as umd
Compiling @angular/material-moment-adapter : esm2015 as esm2015
Compiling @angular/material-moment-adapter : main as umd
Compiling @angular/core/testing : esm2015 as esm2015
Compiling @angular/core/testing : main as umd
Compiling @angular/platform-browser-dynamic : esm2015 as esm2015
Compiling @angular/platform-browser-dynamic : main as umd
Compiling @angular/platform-browser/testing : esm2015 as esm2015
Compiling @angular/platform-browser/testing : main as umd
Compiling @angular/platform-browser-dynamic/testing : esm2015 as esm2015
Compiling @angular/platform-browser-dynamic/testing : main as umd
Compiling @angular/platform-server : esm2015 as esm2015
Compiling @angular/platform-server/testing : esm2015 as esm2015
Compiling @angular/platform-server : main as umd
Compiling @angular/platform-server/testing : main as umd
Compiling @angular/common/testing : esm2015 as esm2015
Compiling @angular/common/testing : main as umd
Compiling @angular/router : esm2015 as esm2015
Compiling @angular/router : main as umd
Compiling @angular/router/testing : esm2015 as esm2015
Compiling @angular/router/testing : main as umd
Compiling @angular/service-worker : esm2015 as esm2015
Compiling @angular/service-worker : main as umd
Compiling @ngrx/store : esm2015 as esm2015
Compiling @ngrx/store : main as umd
Compiling @ngrx/entity : esm2015 as esm2015
Compiling @ngrx/effects : esm2015 as esm2015
Compiling @ngrx/entity : main as umd
Compiling @ngrx/effects : main as umd
Compiling @ngrx/data : esm2015 as esm2015
Compiling @ngrx/data : main as umd
Compiling @ngrx/effects/testing : fesm5 as esm5
Compiling @ngrx/effects/testing : esm2015 as esm2015
Compiling @ngrx/effects/testing : esm5 as esm5
Compiling @ngrx/effects/testing : main as umd
Compiling @ngrx/store/testing : fesm5 as esm5
Compiling @ngrx/store/testing : esm2015 as esm2015
Compiling @ngrx/store/testing : esm5 as esm5
Compiling @ngrx/store/testing : main as umd
Compiling @ngrx/store-devtools : esm2015 as esm2015
Compiling @ngrx/store-devtools : main as umd
Compiling @ngx-formly/core : fesm5 as esm5
Compiling @ngx-formly/core : esm2015 as esm2015
Compiling @ngx-formly/core : esm5 as esm5
Compiling @ngx-formly/core : main as umd
Compiling @ngx-formly/core/json-schema : fesm5 as esm5
Compiling @ngx-formly/core/json-schema : esm2015 as esm2015
Compiling @ngx-formly/core/json-schema : esm5 as esm5
Compiling @ngx-formly/core/json-schema : main as umd
Compiling @ngx-formly/material/form-field : fesm5 as esm5
Compiling @ngx-formly/material/form-field : esm2015 as esm2015
Compiling @ngx-formly/material/form-field : esm5 as esm5
Compiling @angular/cdk/text-field : esm2015 as esm2015
Compiling @ngx-formly/material/form-field : main as umd
Compiling @angular/cdk/text-field : main as umd
Compiling @angular/material/input : esm2015 as esm2015
Compiling @angular/material/input : main as umd
Compiling @ngx-formly/material/input : fesm5 as esm5
Compiling @ngx-formly/material/input : esm2015 as esm2015
Compiling @ngx-formly/material/input : esm5 as esm5
Compiling @ngx-formly/material/input : main as umd
Compiling @ngx-formly/material/textarea : fesm5 as esm5
Compiling @ngx-formly/material/textarea : esm2015 as esm2015
Compiling @ngx-formly/material/textarea : esm5 as esm5
Compiling @ngx-formly/material/textarea : main as umd
Compiling @ngx-formly/core/select : fesm5 as esm5
Compiling @ngx-formly/core/select : esm2015 as esm2015
Compiling @ngx-formly/core/select : esm5 as esm5
Compiling @ngx-formly/core/select : main as umd
Compiling @angular/material/radio : esm2015 as esm2015
Compiling @angular/material/radio : main as umd
Compiling @ngx-formly/material/radio : fesm5 as esm5
Compiling @ngx-formly/material/radio : esm2015 as esm2015
Compiling @ngx-formly/material/radio : esm5 as esm5
Compiling @ngx-formly/material/radio : main as umd
Compiling @angular/material/checkbox : esm2015 as esm2015
Compiling @angular/material/checkbox : main as umd
Compiling @ngx-formly/material/checkbox : fesm5 as esm5
Compiling @ngx-formly/material/checkbox : esm2015 as esm2015
Compiling @ngx-formly/material/checkbox : esm5 as esm5
Compiling @ngx-formly/material/checkbox : main as umd
Compiling @ngx-formly/material/multicheckbox : esm2015 as esm2015
Compiling @ngx-formly/material/multicheckbox : fesm5 as esm5
Compiling @ngx-formly/material/multicheckbox : esm5 as esm5
Compiling @ngx-formly/material/multicheckbox : main as umd
Compiling @ngx-formly/material/select : esm2015 as esm2015
Compiling @ngx-formly/material/select : fesm5 as esm5
Compiling @ngx-formly/material/select : esm5 as esm5
Compiling @ngx-formly/material/select : main as umd
Compiling @ngx-formly/material : fesm5 as esm5
Compiling @ngx-formly/material : esm2015 as esm2015
Compiling @ngx-formly/material : esm5 as esm5
Compiling @ngx-formly/material : main as umd
Compiling @angular/material/dialog : esm2015 as esm2015
Compiling @angular/material/dialog : main as umd
Compiling @angular/material/datepicker : esm2015 as esm2015
Compiling @angular/material/datepicker : main as umd
Compiling @ngx-formly/material/datepicker : fesm5 as esm5
Compiling @ngx-formly/material/datepicker : esm2015 as esm2015
Compiling @ngx-formly/material/datepicker : esm5 as esm5
Compiling @ngx-formly/material/datepicker : main as umd
Compiling @ngx-formly/material/native-select : fesm5 as esm5
Compiling @ngx-formly/material/native-select : esm2015 as esm2015
Compiling @ngx-formly/material/native-select : esm5 as esm5
Compiling @ngx-formly/material/native-select : main as umd
Compiling @angular/material/slider : esm2015 as esm2015
Compiling @angular/material/slider : main as umd
Compiling @ngx-formly/material/slider : fesm5 as esm5
Compiling @ngx-formly/material/slider : esm2015 as esm2015
Compiling @ngx-formly/material/slider : esm5 as esm5
Compiling @ngx-formly/material/slider : main as umd
Compiling @angular/material/slide-toggle : esm2015 as esm2015
Compiling @angular/material/slide-toggle : main as umd
Compiling @ngx-formly/material/toggle : fesm5 as esm5
Compiling @ngx-formly/material/toggle : esm2015 as esm2015
Compiling @ngx-formly/material/toggle : esm5 as esm5
Compiling @ngx-formly/material/toggle : main as umd
Compiling @ngx-translate/core : esm2015 as esm2015
Compiling @ngx-translate/core : main as umd
Compiling @ngx-translate/http-loader : esm2015 as esm2015
Compiling @ngx-translate/http-loader : main as umd
Compiling angular-material-css-vars : esm2015 as esm2015
Compiling angular-material-css-vars : main as umd
Compiling angular2-promise-buttons : esm2015 as esm2015
Compiling angular2-promise-buttons : main as umd
Compiling ng2-charts : esm2015 as esm2015
Compiling ng2-charts : main as umd
Compiling ng2-dragula : fesm5 as esm5
Compiling ng2-dragula : esm2015 as esm2015
Compiling ng2-dragula : esm5 as esm5
Compiling ng2-dragula : main as umd
Compiling ngx-date-time-picker-schedule : fesm5 as esm5
Compiling ngx-date-time-picker-schedule : esm2015 as esm2015
Compiling ngx-date-time-picker-schedule : esm5 as esm5
Compiling ngx-date-time-picker-schedule : main as umd
Compiling ngx-markdown : esm2015 as esm2015
Compiling ngx-markdown : main as umd
Done in 190.14s.
yarn run v1.22.10
$ ng build --prod
Loading extra-webpack.config.js
chunk {} runtime.f8acce36d38b4573bc3e.js, runtime.f8acce36d38b4573bc3e.js.map (runtime) 1.51 kB [entry] [rendered]
chunk {1} main.ecc1f4c1695042f9ddf2.js, main.ecc1f4c1695042f9ddf2.js.map (main) 182 bytes [initial] [rendered]
chunk {2} polyfills.daa958bbf787056501cb.js, polyfills.daa958bbf787056501cb.js.map (polyfills) 189 bytes [initial] [rendered]
chunk {3} styles.17459155b437e272b9db.css, styles.17459155b437e272b9db.css.map (styles) 194 kB [initial] [rendered]
Date: 2021-05-03T08:55:42.798Z - Hash: 69218a20d62933052fc1 - Time: 35432ms
WARNING in /var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/src/app/core-ui/side-nav/side-nav.component.scss exceeded maximum budget. Budget 6 kB was not met by 179 bytes with a total of 6.17 kB.
WARNING in /var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/src/app/pages/daily-summary/daily-summary.component.scss exceeded maximum budget. Budget 6 kB was not met by 189 bytes with a total of 6.18 kB.
WARNING in /var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/src/app/features/tasks/task/task.component.scss exceeded maximum budget. Budget 6 kB was not met by 9.91 kB with a total of 15.9 kB.
ERROR in node_modules/electron/electron.d.ts:6647:21 - error TS2694: Namespace 'NodeJS' has no exported member 'Require'.
6647     require: NodeJS.Require;
error Command failed with exit code 1.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
  • electron-builder  version=22.9.1 os=5.11.16-zen1-1-zen
  • loaded configuration  file=/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/electron-builder.yaml
  • packaging       platform=linux arch=x64 electron=12.0.6 appOutDir=app-builds/linux-unpacked
  • copying Electron  source=/usr/bin destination=/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/app-builds/linux-unpacked
  ⨯ EACCES: permission denied, copyfile '/usr/bin/rscsi' -> '/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/app-builds/linux-unpacked/rscsi'  stackTrace=
        Error: EACCES: permission denied, copyfile '/usr/bin/rscsi' -> '/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/app-builds/linux-unpacked/rscsi'
        at processImmediate (node:internal/timers:464:21)
        From previous event:
        at walk (/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/node_modules/builder-util/src/fs.ts:75:51)
        at unpack (/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/node_modules/app-builder-lib/src/electron/ElectronFramework.ts:173:5)
        at LinuxPackager.doPack (/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/node_modules/app-builder-lib/src/platformPackager.ts:174:5)
        at LinuxPackager.pack (/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/node_modules/app-builder-lib/src/platformPackager.ts:115:5)
        at Packager.doBuild (/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/node_modules/app-builder-lib/src/packager.ts:444:9)
        at executeFinally (/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/node_modules/builder-util/src/promise.ts:12:14)
        at Packager._build (/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/node_modules/app-builder-lib/src/packager.ts:373:31)
        at Packager.build (/var/tmp/pamac-build-dibakarg/superproductivity/src/super-productivity-6.4.0/node_modules/app-builder-lib/src/packager.ts:337:12)
==> ERROR: A failure occurred in build().
    Aborting...
Now pamac is stuck in aborting for the last 15 mins..
what to do?
It is an electron app (made out of javascript and HTML, the same stuff websites are made of), the functionality is just as same as what you would expect when you open it in web browser. You can simply visit app.superproductivity.com, click on settings, connect with a Sync provider (Like Google Drive) to persist your tasks and todos across devices if that is what stopping you from using the web browser version of it.
If you had built the package the correct way AUR (en) - superproductivity you would of read the commentss its out of date, other users have reported the problem it does not work, for others it does not build.
Try the bin version or the git version, never ever try to build packages blind always go to the AUR web page check out the comments bbefore attempting to build any AUR package,
Don’t feel bad its a very common mistake. In the instance you have 3 choices to choose from.
Epoch commented on 2021-04-08 04:26
It’s out of date and now doesn’t work at all. It stays on the loading screen indefinitely and needs to be killed.
jvalecillos commented on 2021-02-17 11:33
Bumped to version 6.4.0
Tio commented on 2020-11-05 12:02
Error:
error Command failed with signal "SIGABRT".
  • electron-builder  version=22.9.1 os=5.4.72-1-MANJARO
  • loaded configuration  file=/var/tmp/pamac-build-tio/superproductivity/src/super-productivity-6.0.1/electron-builder.yaml
  • packaging       platform=linux arch=x64 electron=10.1.5 appOutDir=app-builds/linux-unpacked
  • copying Electron  source=/usr/lib/electron destination=/var/tmp/pamac-build-tio/superproductivity/src/super-productivity-6.0.1/app-builds/linux-unpacked
  ⨯ Application entry file "electron/main.js" in the "/var/tmp/pamac-build-tio/superproductivity/src/super-productivity-6.0.1/app-builds/linux-unpacked/resources/app.asar" does not exist. Seems like a wrong configuration.  stackTrace=
        Error: Application entry file "electron/main.js" in the "/var/tmp/pamac-build-tio/superproductivity/src/super-productivity-6.0.1/app-builds/linux-unpacked/resources/app.asar" does not exist. Seems like a wrong configuration.
        at error (/var/tmp/pamac-build-tio/superproductivity/src/super-productivity-6.0.1/node_modules/app-builder-lib/src/asar/asarFileChecker.ts:7:12)
        at checkFileInArchive (/var/tmp/pamac-build-tio/superproductivity/src/super-productivity-6.0.1/node_modules/app-builder-lib/src/asar/asarFileChecker.ts:33:11)
    Aborting...
Show More…
Garuda does not oficually support snap.
I am glad that it doesn't support snap. I have edited my answer.
